Question about Samsung Televison & Video
COLOR PROBLEM ON MY SAMSUNG DLP - Samsung Televison & Video
  • 1,238 Answers
Good day
your problem is in the color wheel..because when the color wheel malfunction or out of timing the color of the screen is not good
color wheel is available at the market you can buy it to eBay.com or amazon.com
replacing of color wheel is D.I.Y. its easy for you to perform
watch this video to guide you the proper procedure
thank you and good luck..
Posted on Apr 08, 2011
  • bonifacio gomez
    bonifacio gomez Apr 08, 2011
    I'm sorry sir...very very sorry I insert the wrong video..that video is for power supply repair sorry I hope you understand..the site below ,,,that's the correct video sorry again
    http://www.youtube.com/watch?v=Cx4pbNjsx...
Samsung DLP R&R Color wheel Model #HLR5078w
Samsung's digital light projection (DLP) televisions use a spinning color wheel to create the colors that are seen on the screen. If the color wheel becomes misaligned during use, it will become damaged and have to be replaced. Replacing the color wheel on a Samsung DLP television can be done at home, once a compatible-sized color wheel has been bought from a TV supply store.Replacing the color wheel yourself will void any Samsung warranty that might be in place, but is the only solution for getting the TV working again in as short a time as possible.
Put on the anti-static grounding strap to keep static electricity from damaging the internal components of the Samsung DLP TV. Turn the Samsung around so that the back is facing you. Make sure the Samsung is unplugged from the AC socket.
Use the Phillips screwdriver to remove all of the screws from the back panel. Put the screws aside. Pull off the back panel.
Loosen the two screws from each side of the projection bulb's case. Pull the projection bulb out. Put the projection bulb aside. Use the Phillips screwdriver to remove the two screws from the left side panel. Pull the side panel and the circuit board attached to it out carefully and put it down so that the cables attached to it have not been pulled out.
Take a picture of the power cable's position with the digital camera so that you can put it back correctly later. Pull the power cable out from inside of the Samsung's case so that the center panel is free to be pulled out. Remove the two large headed screws from the center panel with the Phillips screwdriver. Remove the top two screws holding the panel to the plastic case using the Phillips screwdriver.
5
Slowly slide the center unit out a few inches. Take a picture of the projector lens' positioning with the digital camera so that you can put it back correctly later. Unplug the two cables from the left side of the center panel. Unscrew the sensor switch using the Phillips screwdriver. Slide the center panel completely out of the Samsung and put it down on the clean cloth. Blow off the color wheel assembly with the compressed air.
6
Use the tweezers to remove the green plug from the top of the color wheel cover. Use the tweezers to remove the two cables at the side that are coming from the color wheel. Use the Phillips jeweler's screwdriver to remove the screws from the top, front and back of the color wheel cover. Slide the color wheel cover straight up to expose the color wheel.
7
Use the Phillips screwdriver to remove the three screws holding the color wheel to the color wheel assembly. Lift the color wheel up and out of the color wheel assembly and discard it.
8
Position the replacement color wheel in the color wheel assembly. Reassemble the color wheel and reassemble the color wheel assembly. Put the color wheel assembly back into position in the rear of the Samsung DLP TV. Reassemble the Samsung DLP TV. Plug the Samsung DLP TV back in for power. Turn the Samsung on and enjoy seeing the colors displayed properly again now that you have replaced the color wheel.
May 02, 2010 | Samsung HLR5064W DLP Projection TV
I HAVE A DLP SAMSUNG 52" T.V. IT TURNS OFF BY ITSELF EVERY THIRTY MINUTES. CAN YOU TELL ME WHAT THE PROBLEM IS?
Has it been getting loader lately? (fan noise)
if so check link it could be the common fault described below
Samsung Color Wheel
http://www.jangro.com/electronics/samsung-dlp-replace-color-wheel/
Nov 24, 2009 | Samsung DLP HL-P5663W 56" TV
I have a samsung dlp that makes a horrible buzzing sound and it turns off, all the lights blink and the color flashes in and out.
The problem is likely the color wheel paste the link attached for more info
Samsung Color Wheel
Sep 28, 2009 | Samsung DLP HL-P5663W 56" TV
No color and flashing screen on DLP
Jenn
I have the same problem, do you think it is the color wheel
Thanks Joe
Jul 02, 2009 | Samsung DLP HL-P5663W 56" TV
Color wheel for Samsung HLR5688WX DLP TV
5
6
7
8
Jun 30, 2009 | Samsung HLR5688W 56" Rear Projection HDTV
Samsung HL-R6167W DLP color problem/buzzing noise
My 3 yr old Samsung DLP has the same buzzing noise, had a tech out today and he said "color wheel". Thank goodness I purchased that expensive warranty, This is my 4th repair in 3 years.
Dec 24, 2007 | Samsung DLP HL-P5663W 56" TV
Televison & Video Logo
115 people viewed this question
Jerry Greenberg
Jerry Greenberg
