Question about XO Vision X348NT Car Video Player
I'll do the preset on the radio and they will stay until I shut off the ignition, once I turn the car back on none of the presets are there what do I need to do differently with the wire combos?
    Renaissance:
    An user who is expert in 3 categories / brands.
  • XO Vision Master
  • 2,226 Answers
Make sure the yellow wire is going to a constant power source. The yellow wire needs to have power going to it even when the key is turned off.
Posted on Apr 08, 2011
KD-R805 does not store clock settings
first of all you must be able to check out a few things like do you know how to set your clock for the kd-r805. if you can check to see if you set your clock and set your presets for radio station to be saved. set your clock and set all your station presets once done. Once you have done that turn off the car wait about 60 seconds then turn your car back on to power up the radio and see what happens to your clock and presets . if your clock and presets are not still saved this means that who ever did the radio install has the yellow memory wire connected to switch ignition and not constant battery wire from the factory harness. have someone fix it. If the clock and station presets are still save then it was that you don't know how to program the clock.. how to program your model radios clock .......
STEP 1 : TURN ON POWER TO RADIO
STEP 2 : PRESS AND HOLD MENU UNTIL THE MAIN MENU IS SHOW ON RADIO SCREEN PRESS AND TURN THE VOLUME KNOB TO MOVE THROUGH THE MENU ( YOU MUST CANCEL THE DEMO FIRST TO BE ABLE TO PROGRAM THE CLOCK).
STEP 3: TO SET THE CLOCK SELECT THE CLOCK IN THE MAIN MENU SETTING ROTATE THE VOLUME KNOB AND PRESS IT ONCE TO SELECT THE CLOCK SETTING.
STEP 4: ADJUST THE HOURS AND THEN PRESS THE VOLUME KNOB TO MOVE ON TO THE SECONDS .
STEP 5 : THEN SELECT 12HR OR 24HR TO BE DISPLAYED
STEP 6 : RETURN TO THE PREVIOUS MENU BY HITTING (BACK BUTTON)
STEP :7 TO EXIT SETUP OR MENU HIT THE (MENU BUTTON)
radiorepair@www.windowtintingin239.com
Oct 26, 2013 | Car Audio & Video
How do I enter the code I'm my blaupunkt car radio
Switch On Ignition (No Need To Start Engine)
Press & Hold Preset " AS " and
Switch Radio On - Display Shows
" SAFE " And Then Shows " 10 - - - - "
Press preset " 1 " repeatedly for 1st Digit
Press preset " 2 " repeatedly for 2nd Digit
Press preset " 3 " repeatedly for 3rd Digit
Press preset " 4 " repeatedly for 4th Digit
If the correct code number is now shown
Press & Hold Preset " AS " Until the Unit Beeps
Apr 04, 2013 | Car Audio & Video
Bush radio ne3116 - i cannot preset channels
Choose the required station with up/down arrow buttons, press SELECT.Press and hold PRESET button until number flashes.Quickly scroll through preset channels with arrow buttons.When required preset chosen, press SELECT.
Voila: station saved!
Took me about 15 minutes to figure it out, as bought radio second-hand with no instructions, and none on internet, until now!
Sep 14, 2011 | Audio Players & Recorders
I got an Audi TT Turbo Model 2000 The radio Bose Audi concert is giving safe on the screen and nothing else what should I click on to reset the radio so I can put the code.Thanks
  1. Turn on radio. The radio display shows "SAFE".
  2. Press the FM2 and RDS buttons simultaneously and hold until "1000" shows on the display. Release the buttons. Do NOT press these buttons again, otherwise the radio will consider "1000" to be the code.
  3. Use Preset buttons 1 ... 4 to enter the four-digit code number from your radio card. Preset button 1 corresponds to the first digit, Preset button 2 corresponds to the second digit, etc. Each press of the button increments the number by 1.
  4. Once the code shown on the display is correct, press the FM2 and RDS buttons simultaneously and hold until the word "SAFE" appears in the display, then release the buttons.
  5. The radio should unlock and be usable shortly afterwards.
  6. If an incorrect code is entered, the word "SAFE" appears, first flashing and then continuously. You can repeat the above steps to unlock the radio once more, the number of attempts will be shown in the display. If an incorrect code is entered again, you radio will be locked for about one hour. After one hour - the radio must stay on and the key must remain in the ignition lock - if the display goes out, the you can repeat the above procedure to unlock again. The cycle - two attempts, one hour lock-up - still applies.
May 29, 2011 | 2001 Audi TT
Unlock procedure for vw/audi
audi gamma cc type
1e2fb0f.jpg The following is the procedure to re-activate the radio if the display shows "SAFE". It is important that the procedure be followed in the correct order.
  2. Press the FM1 and AM buttons simultaneously and hold until "1000" shows on the display. Release the buttons. Do NOT press these buttons again, otherwise the radio will consider "1000" to be the code.
  4. Once the code shown on the display is correct, press the FM1 and AM buttons simultaneously and hold until the word "SAFE" appears in the display, then release the buttons.
  7. If you lose your radio code, contact your Audi dealer.
audi delta
  2. Press the FM1/2 and DX buttons simultaneously and hold until "1000" shows on the display. Release the buttons. Do NOT press these buttons again, otherwise the radio will consider "1000" to be the code.
  4. Once the code shown on the display is correct, press the FM1/2 and DX buttons simultaneously and hold until the word "SAFE" appears in the display, then release the buttons.
Mar 29, 2010 | 1997 Audi A4
Cant enter radio code
Ford Code Entry Instructions
Once the unit has been turned on the display will show ' CODE - - - -'
Press preset [ 1 ] repeatedly for the first digit
Press preset [ 2 ] repeatedly for the second digit
Press preset [ 3 ] repeatedly for the third digit
Press preset [ 4 ] repeatedly for the third digit
To save the code press the [ 5 ] key to accept.
The set should now operate
Nov 09, 2009 | 2001 Ford Focus
Mitsubishi Lancer 2004 Radio Code Not Working
Use the first four radio station preset buttons to enter the code.
1: Push radio preset#1 until first digit of your code appears.
2: Push radio preset#2 until second digit of your code appears.
3: Push radio preset#3 until third digit of your code appears.
4: Push radio preset#4 until fourth digit of your code appears.
5: Push either tape or cd button.
What to do if your radio says OFF instead of CODE
(Courtesy of mittech)
If your radio says OFF it means you entered the wrong radio code three times. To get it to say CODE again do the following.
1:Turn the key to on or accessory.
2:Push the power button so that the radio display says OFF.
3:Let the car sit for 1 hour.
4:The radio display will go blank.
5:Turn the radio on and it will say CODE again.
Sep 04, 2009 | Infinity Reference 1211a Car Audio...
I brought my son a 1997 Audi, and the radio is in safe mode, can anyonr help me get the code?
  2. Press the P.Scan and RBDS buttons simultaneously and hold until "1000" shows on the display. Release the buttons. Do NOT press these buttons again, otherwise the radio will consider "1000" to be the code.
  4. Once the code shown on the display is correct, press the P.Scan and RBDS buttons simultaneously and hold until the word "SAFE" appears in the display, then release the buttons.
Jun 22, 2009 | 2002 Audi A6
Radio presets?
select radio station then select which number you want to preset station to and press and hold until you hear the unit beep,also preset station will flash once aswell as the beep,station should be preset into your headunit,goodluck.
Nov 29, 2008 | Pioneer Car Audio & Video
Radio Station Presets wont hold
hi girlygirl 1
the problem is your ignition and your permanant battery live wires are the wrong way round all you have to do is remove the stereo and you will usually see a red wire plug into another red wire and a yellow wire into another yellow wire all you have to do is change the red to the yellow and the yellow to the red and it will hold the memories fine hope that helps !
Nov 19, 2008 | Pioneer DEH-2000MP MP3 CD AM/FM Car Stereo...
XO Vision X348NT Car Video Player Logo
54 people viewed this question
Top XO Vision Car Audio & Video Experts
Jose Velazquez
Jose Velazquez
mega_mind
Are you a XO Vision Car Audio and Video Expert? Answer questions, earn points and help others
