Question about GE Dishwashers
GE potscrubber 1200. Fills only partway with water. Holding down float switch makes no difference. Is there another water level control somewhere?
    Sergeant:
    Champion:
  • 202 Answers
Hi... No there is no another control ....The main control board time fills it!! So that means you have a bad valve ....If I were you I would get a new water valve
Posted on Apr 08, 2011
  • Nathan Van Boven Apr 08, 2011
    That float that your talking about is a safety !!
I have a GE washing machine that the water does not turn off once it reaches the appropriate level. Last night it overflowed and flooded 3 rooms.
You have a bad water level sensor.
Look inside washer and check if anything is holding a float sensor down. If not, the sensor is bad or its connection to the control board is loose or not connected.
Jul 04, 2016 | GE Washing Machines
I have a auto chlor model a4 dishwasher and when I push the fill button it only fills for 3 seconds and stops and if I fill it up by holding the button down and run it threw it's cycle when it goes into...
Hi John,
This sounds like a misadjusted water level sensor. This is a commercial dishwasher but the principles are the same. I would check the water level sensor to make sure that there is no debris under it or a leveling sensor bent causing the machine to think it is at the proper water level to begin washing when it is not. This may be a mechanical lever float type switch or an actual electronic sensor that will detect where the water level is. Most household DW's will have the mechanical float switch that will float with the water level and shut off the fill solenoid when the proper level is reached. You are having to defeat this process by holding the button in to override either a faulty sensor (replace it) or a misadjusted float switch. These would be the too most likely causes of this problem. I hope this helps!
Jun 04, 2014 | Dishwashers
Ge potscrubber 800
GE Potscubber 800
Issue: No water.
What works:
- Dishwasher appears to operate normally, just does not call water.
- Water valve works
Suspected:
- Float / float switch
Needed:
How to test float switch
Jun 01, 2013 | GE 24 in. GSD3400G Built-in Dishwasher
My GE Dishwasher model GSD1300N10WW doesn't clean dishes,glasses and silverware. Everything has a film on it. I think the tower sprayer might not be popping up but cannot tell.water does spray from the...
Hi
If the water inlet valve is fine and it fills with water then the issue seems to be with the float switch assembly that is bad and should be replaced. Float assembly is found inside the dishwasher's tub, on the bottom. The water that fills the dishwasher lifts the float, and when it reaches a certain level, it acts as a trigger for the float switch. The float triggers the float switch to shut off, thereby shutting off the flow of water into the dishwasher. A defective switch may interfere with dishwasher's filling and/or draining ability. Use voltmeter to test the switch. Set the device to the ohms setting x 1. Take each probe and touch them to one switch terminal each. This should produce a reading of either zero or infinity. Continue to touch the probes to the terminals, and press down on the switch's button. The reading should change to the opposite extreme. If the switch fails either of these tests, you should replace it. Hope this helps...please post back for further assistance.
Daniel
Aug 04, 2011 | Maytag Dishwasher
Dishes are not clean glasses are cloudy
Hi
Daniel
Aug 01, 2011 | GE 24 in. Profile PDW7880G Built-in...
My husband installed our dishwasher a Westinghouse 905 and it fills with water but then floods our kitchen!! If we turn it off it drains out properly so we are not sure what to do next. Any help would be...
Hello!
"floods the kitchen"... do you mean it overfills, or that it fills, the water valve shuts off, and then while running it leaks out?
Perhaps the water level control float that is on the inside of the machine is stuck or there is packing material inside it for shipping???
The float valve would be on the bottom of the tub and probably looks about the size of a hockey puck and has to move freely up and down to detect the level of water. If the water level were to get too high, the valve will float up and release a micro switch that it controls with a little shaft that runs down through a small opening in the bottom of the tub.
Check to see that it moves freely up and down... you likely will be able to hear a bit of a "click" of a micro switch.
If the float was stuck, it probably is safe to try to run the dishwasher again... but stand by just in case !!!!
Hope this was the problem and now it works !!!
/denis
Dec 15, 2010 | Westinghouse 24 in. MDP531 RF...
GE Potscrubber disher - water leaks out while filling
I would try removing the cover and make sure the float isn't sticking. On mine the float pushes on a rod that goes through the tub to a micro switch. When you hit it, it probably frees it up for a while. Hope that helps.
Jan 21, 2010 | GE Dishwashers
Water not coming into dishwasher
Without knowing the model number of your GE dishwasher, but some dishwashers don't notice when the float / float switch is stuck. That could cause the dish washer to move through all the cycles but never have water flow into the dishwasher. That would be the first place I would look. But please post back here with what you find (plus the model number of your dishwasher) before ou rate me level of helpfulness, OK?
May 09, 2009 | Dishwashers
Skips 1st water fill ?
There are two possible reasons for the situation as you describe it: 1. Water-inlet valve The water-inlet valve lets water enter the machine. If this valve is defective, you need to completely replace it. It's usually located behind the lower access panel on the left or right side. It's the device with the main water line (usually copper) from the house, a rubber tube to the dishwasher, and two wires attached to it.
2. Float switch The float switch is a small electrical switch that's located right below the dishwasher "floor." Above the switch, on the inside of the dishwasher, is a plastic cylinder that floats up as water fills the dishwasher. If this switch is defective, or if the plastic float gets caught or trapped in the raised position, the water can't enter the dishwasher. If the float switch is defective, you need to replace it.
If you are mechanically inclined you can repair either of these but if you are not you will have to hire it done. Now that you know it is one of two problems you can tell the repairman ahead of time and get a price on the repair. Then shop around for the best price.
May 08, 2009 | Maytag Dishwasher
GE wcxr1070a washing machine. fills with water
Check the water level switch and the plastic tubing to the switch.
Sometimes soap scum stops up the plastic hose and the water level switch does not close to send power to the timer.
If the plastic hose is good and the water level fills and stops replace the water level switch.
Mar 21, 2009 | GE WCXR1070A
Dishwashers Logo
231 people viewed this question
Top GE Dishwashers Experts
Mike
Oloyede Monsuru
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
