Question about Vacuums
How do I replace the worn brush strips on the roller?
  • 42 Answers
Just replace the whole beater bar, the end that has the belt contact area is must likely worn and the end bearings are full of hair and trash and dust. Find a local shop or go on-line to source the new bar. Replace the belt at this time and give it a fresh bag too.
Posted on Apr 08, 2011
My 2 year old Dyson roller head keeps sticking and won't turn unless I bang it several times. Can the roller be worn and needs replacing?
Hello, this is Ava with Think Crucial.
There are a number of reasons why your brush roller has stopped moving. General maintenance to your vacuum is crucial and will help it work at peak performance.
First things first lets focus on the brush roller. Unplug the vacuum and turn it on its side. Look for any noticeable clumps of debris or hair strands that may be caught in the brush roller. Remove these obstructions, probably best to do so with a scissor if it's hair or long pieces of carpet fibers. After removing the debris try manually rotating the brush roller to uncover other hidden clogs. Another thing to take note of is the condition of the bristles on the roll itself. Are they loose or worn down? These are signs that your brush roller is in need of replacing.
While checking out your brush roll you might as well take a look at your vacuums belt. Your belt should be replaced about every three months. After regular usage, the belt will stretch out, lessening the tension on the brush roller. Lesser tension diminishes the brush roller's turn rate and speed. If the belt feels loose then it certainly is affecting your vacuums suction as well as your brush roll not moving at all.
You can purchase a wide variety of high quality Dyson replacement parts for your Dyson vacuum direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
https://www.thinkcrucial.com/search?type=product&q=dyson
I hope this was helpful.
Ava B.
Think Crucial Customer Care
http://www.thinkcrucial.com/
Dec 14, 2016 | Dyson Vacuums
Brush won't spin on hoover wind tunnel bag less upright when on carpet, belts are fine
The belts may look fine but may be stretched and worn. Replace them. Make sure brush spins free. Idler pulley should tighten belt tension when handle is released
Jul 25, 2014 | Hoover U6630-900 WindTunnel Bagless...
My 1 Year Old Sebo X4 was lowering itself to hardwood floor with no air gap. Sebo Support agreed with my repair shop that a new (blue) brush roller would fix the problem by replacing the 'worn" brush (same...
No not quite. For a start, the stiff bristles on the blue roller can last a few years before requiring to be replaced.
The SEBO sensor wheel adjusts to the height required - unless of course the microchip board has been tampered with. If it hasn't been tampered with. If the central wheel is excessively dirty then it could be that the SEBO isn't lowering the height properly. However, the X series is great at cleaning hard floors in general - i it is not designed for the brush roll to fully hit the floor, thus as you suggest crushing the bristles. It is designed, as you recognise quite correctly to skid across a hard floor lightly as there is a squeegee rubber strip built in at the back of the roller bar that scoops all dirt into the central vacuum path. The front plate also lends this job. You are not being conned - however check that the rubber squeegee strip has not worn away - SEBO do sell the strips and they are easy to slide into via the press release door at the side of the brush roll.
If the SEBO has died then its a possibility that there is a microchip function that gone wrong it. Some more information would be good to know here as it could be a number of things such as the cord cables coming away at the handle.
Oct 30, 2013 | Vacuums
How much does it cost to have dyson animal service
HI there I am a technition in Australia and I charge $88 for a service on a dyson DC07. Basically for that I strip the machine right down, clean the airways, service the motor and the clutch. I check the brush roller bearings and disassemle the radix unit and clear it out. I also change filters and belts where necessary. After about 5 years the bearings in the brush roller are worn too so I generally change those too.
Hope this helps.
Happy Vacuuming
Jan 25, 2011 | Dyson DC07 Animal Bagless Upright Cyclonic...
Just purchased this Dyson dc24 today. brush doesn't spin after gettin tangled in a cord. removed the cord from the brush OK. I have several times: removed the brush and replaced it OK. pushed the red...
When you removed the brush roller dod you examine the end of the actual roller that is opposite from the removal opening. There is a gear that the roller fits over that may have gotten stripped when it became tangled. Check that the gear has not rounded off and look inside the roller bar to see if the area where the gear fits into may have gotten stripped as well. You might try to operate the vacuum without the roller brush installed for a few seconds just to see if the gear turns. When I say gear, it is actually a somall "post" about 1-2" long that the roller brush fits over. Hope this helps!
Dec 17, 2010 | Dyson Ball DC24 Bagless Upright Vacuum
The electric powerhead for my Beam Central vac shakes or vibrates as I vacuum.Cannot find an obvious problem. Brush strips are not worn.
The brush roller itself may be warped, or the bearings may be starting to wear out.
Replacing the brush roller may solve the entire problem.
Good luck.
Mark
Nov 09, 2010 | Beam Industries Vacuums
How to replace Simplicity vac brush roll strips?
The caps will come out of the end of the metal roller. They can be difficult if it's been a long time as dirt and grime can build up. Try sticking a flat head screwdriver in and gently twisting to get the caps to slide out.
Jul 16, 2009 | Riccar Vacuums
Dyson DC07 brush roller is worn and won't make contact with the carpet anymore. I need to replace the brush roller but don't know how...HELP?
Buy the brush over the web etc..
To take the brush out
1 - Take the outer covering - uese a penny to turn the yellow srews
2 - Slide the black brush out from the assembly - Try the non belt side first.
3- Slide the belt out of the brush.
4 - Take brush out - Replace it with new one.
May 09, 2009 | Dyson DC07 Allergy Blue/Turquoise Bagless...
My purple and red Dyson has become hard to push. Could a belt have broken?
It's simple to tell if a belt has broken. Just switch the machine on and have a look (look, don't feel) to see if the brush roller is rotating. If it is, then the belt is not broken.
Depending on how much use your machine has had, it's quite likely that the brushes on the brush roller are worn to the point where you need a new brush roller.  Most vacuum cleaners rely on rotation of the brush roller to pull them along, so if the bristles are too short this doesn't happen.
I hope this helps. Please remember to rate this response.
Mar 11, 2009 | Dyson DC07 Animal Bagless Upright Cyclonic...
Vacuums Logo
27 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
