Question about Whirlpool Freezers
My whirlpool chest freezer runs but does not freeze?
  • 6,993 Answers
Fan problem is one of the most common reasons for the freezer to start failing, this is called "frost free failure." Ice can build up on the evaporator coils over time, and this ice builds up until it starts blocking the fan. The fan is responsible for circulating cold air throughout the freezer, so if it is blocked the freezer will not be able to freeze any food. You can usually check this by removing an access panel in the back of the freezer to inspect the coils. If ice is built up on the coils, a hairdryer can assist in defrosting them.
It's also possible that the fan is not running at all. If the fan is burned out or the motor isn't running, cold air can't circulate through the freezer and everything will melt. You can normally hear the fan motor switch on and off from time to time. Listen for it and if you can't hear it coming on for an extended period of time, the motor may need repair or replacement. The wires connecting to the fan may be the problem, preventing the fan from receiving electricity.
Several other problems could be keeping your freezer from freezing:
There could be leaks in one or several of the hoses in the refrigerator, which results in the cold air being lost instead of circulating properly throughout the fridge and freezer.
If you have the freezer so full that the cold air can't circulate, your food will thaw even though the freezer isn't malfunctioning. Always leave some space open in the freezer and try to not store food right up against the cooling vents.
The thermostat might have shorted out, which means the freezer can't accurately determine how cold it is. If this is the case, the refrigerator would probably not be working, either.
If your defrost drain becomes clogged, the water in the line will just refreeze over and over again, which could damage the lines as well as the fan. Always check the drain and make sure no sludge is building up in it if you have a self-defrosting refrigerator.
Always try to keep the freezer door closed for long periods of time. The more the door is opened, the more warm air is let in and cold air is released. If the door is opened frequently, the freezer could be warming faster than the fridge can cool it, which will thaw your food.
I hope this helps........
Best regards.
Posted on Apr 14, 2011
MODEL AFG 5496-C FREEZER WHICH BUTTON SHOULD BE LIT WHEN SWITCHED ON TO FREEZE
Green light means that freezer is connected to the mains/electric
Red means that your freezer has not reached minimum working freezing temperature, this is not good news, something may be wrong with your freezer, get it checked by a competent person.
yellow light means that you have switched the fast freeze button on. This yellow switch allows the freezer to run continuously so that the frozen food you brought home from shopping can freeze up quicker. You must not leave this light on for more than 3 hours. It will cause you to waste a lot of electric and will place a lot of stress on the working component in the fridge.
Feb 10, 2015 | Whirlpool 10 cu. ft. / 283 liter Chest...
I have whirpool chest freezer defrosted and off for 4 months then turned on 2 red lights going motor is running but not freezing turned up temp to coldest tempurature with amber light on stil the motor...
Since the motor is running, the compressor it is connected to must also be running. The compressor is the thing that provides the cooling under normal circumstances. The only thing I can think of as to why you are not getting cooling is that the refrigerant charge has leaked out of the system. I don't know anything about the red lights you mention.
Aug 25, 2014 | Whirlpool 10 cu. ft. / 283 liter Chest...
I need the owners manual for the estate chest freezer model no. tcf1510ew00, or if someone could just tell me the temp settings for each number? it shows on the side that 4 is i guess the freezing point...
The numbers are generic and don't mean a thing. They are there to make you feel like you have control. Anything under 1 should be very much frozen. If it is not then you have T-stat problem and should address that. Chest freezers run at -25f on average if the freezer has enough product in it. The more food in the freezer the better and more efficiently it will run.
Apr 10, 2014 | Whirlpool 10 cu. ft. Chest Freezer...
My whirlpool chest freezer not freezing at all
it not freezing because it cooling system must be damaged,you bought another cooling machine it has mini size and it fixed at the point of older cooling placce.
Mar 22, 2013 | Whirlpool 14.8 cu. ft. / 419 liter Chest...
The standby light is still on
Are you sure it is a standby light? Usually the orange light is showing you it is in fast freeze. Try switching the orange button off and monitor the temperature. The freezer should cycle on and off, not run continuously.
Apr 15, 2012 | Whirlpool 10 cu. ft. / 283 liter Chest...
One side of freezer has stopped freezing... bottom is not frozen
You have either got a blockage in the system or there is a leak. My bet it is a leak. Seen this many times on the whirlpool.
May 28, 2010 | Whirlpool 14.8 cu. ft. / 419 liter Chest...
Chest freezer not freezing on bottom
Sounds like a circulation problem. Does it have a fan inside the freezer. Should be bdhind the floor or one of the wall panels. There should be a vent for the air to circulat through. If so check to make sure it's running when the compressor runs.
Aug 19, 2009 | Whirlpool 10 cu. ft. Chest Freezer...
Freezer not freezing
Hi!!!you have a seal system problem..
Jan 03, 2009 | Frigidaire 15 cu. ft. / 425 liter Chest...
Freezers Logo
267 people viewed this question
Top Whirlpool Freezers Experts
Charles T Nevin
Charles T Nevin
christian nielsen
AJMAL KHAN
Are you a Whirlpool Freezer Expert? Answer questions, earn points and help others
