Question about Bosch Nexxt Premium WFMC6400UC Front Load Washer
How do you remove and replace the main rubber seal around the front of the washer?
  • Bosch Master
  • 2,605 Answers
Welcome to FixYa.
The process you are inquiring about is actually not all that involved...once you see how it's done.
Having said that, I think the best method to serve you is to provide a link from you-tube which will literally "show you" how it is done.
http://www.youtube.com/watch?v=OPmNtO-QAcU
It is a bit of a challenge to fasten the gasket to the inner part of the drum and make sure not to mix up the front retaining ring with the rear one...they are different in diameter.
Good luck and thank you for choosing FixYa.
Regards,
Macmarkus :)
Posted on Apr 08, 2011
4 Suggested Answers
SOURCE: Front Door Seal/Baffle Replacement
I need to replace a baffle from inside my Elite HE3T. Do you have directions? Only 1 came off but when I order the new one apparently it only comes in 3, so show I replace the other 2 as well? (if I can figure out how)
Of course the part did not come with any! And Sears customer service is of no help and the technical people have not responded to me.
Thanks,
Posted on Aug 27, 2008
  • 7 Answers
SOURCE: how do you remove the rubber seal in a front load
There is a spring band on thr fromt lip of the seal and the seal closest to the tub.To remive use a flat slim tool to lightly pry up on the band and it till pop off.Same with the inner band.
Posted on Oct 01, 2009
  • 155 Answers
SOURCE: need to remove the rubber seal from my lg front load wahser
why replace seal just clean it much easier there are some really good cleaners on the market but if you realy want to replace remove wire band around seal you will see this around the outer diameter with a tension spring attached pry of carefully lift the top and do the same at other end make sure to turn of power take very good note so you will know how to put back together
Posted on Nov 12, 2009
Front load washer door seal is detached
The seal appears to be spring reinforced. you may need to remove the door partially and rewrap the spring around seal. or if broken or cracked try to replace or fix with a sheet rubber and rubber cement. May be an old bike tube!? hehe
Mar 02, 2013 | Washing Machines
HOW TO REMOVE RUBBER SEAL
ok if you look around the front of the rubber seal you will see a wire holding it in place on the wire there is a spring if you pull the spring off with a pair of pliers the door seal will just pull off the cabinet then take off the lid and you will see the wire that goes around the door seal where its held onto the drum some have a screw on it and some just pull off then give the seal a good pull from the front of the machine it will pull off quite easy then just push the new seal into place and replace the wire thankyou
Jan 23, 2011 | Hotpoint Aquarius WMA56 Front Load Washer
Need to remove the rubber seal from my lg front load wahser
Nov 12, 2009 | Washing Machines
After my washer spends the rubber comes
Do you mean the door seal has come loose.
Disconnect the machine from the power. Open top hatch by removing two screws in the back and sliding top lid back and up to remove.
Check down from the top of the machine and feel around the door seal. Make sure there are no holes or tears in the seal. Try and refit seal. there is a metal ring around the drum and also around the front panel where the door seal joins. Make sure the are tight and fit in properly.
Let me know if I didnt understand the problem.
Good luck.
Ash
Oct 22, 2009 | Samsung WF448AAP Front Load Washer
Rubber gasket
Feel around the seal, in the groove behind the seal face. You'll find a spring at the bottom. With a small screwdriver, lever the spring over the seal face. Work the steel ring off. Fold the seal inside the washer. Unplug the washer, Remove the door, and set aside. Locate your panel screws and remove the front, exposing the drum and basket. There are usually additional screws under the dispenser trays too. Disconnect the door lock wires. Locate the other spring/ring assembly on the outer drum, and remove. Orient your new seal properly and reassemble. The only difference on the reassembly is that, when you are putting the rings back on, start 180 degrees from the spring, and work the ring back on until you get to the spring. Carefully lever the spring back over the seal face, being careful not to damage your new seal.
Best regards, --W/D--
Aug 08, 2009 | GE Energy Star WCVH6260F Front Load Washer
LG FRont Load Washer Dryer WD-1256RD filling up with lint
If you have not done it already, replace the lint filter. Follow instructions on manual. The lint filter access should be on front side of machine.
Other users had same problem on this model, I quote:
"I've only had it 2 weeks so far. It seems to be collecting lint/fluff all around the rubber door lining"
Source here.
Sometimes there may be too much lint if you use excessive softener and detergent.
Feb 08, 2009 | LG WD-12124RD Front Load Washer
Leaking door due to the wire ring that holds rubber seal
Bosch Nexxt 500 WFMC3301 Front Load Washer how
to get the metal ring back on.
This video will show you how to change a door seal on this Bosch front loader washing machine and also how to replace the metal rings.
we have all bosch repairs in our channel.
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
Oct 06, 2008 | Bosch Nexxt 500 WFMC3301 Front Load Washer
Door seal wont drain
I would suggest using a blunt object to clear the drainage holes in the rubber seal. I'd advise against removing the seal for this problem. LG has special pliers to remove the spring loaded wire from around the front of the door seal and another for the larger size one where the rubber seal attaches to the outer drum. The second one is much harder to reattach, even somewhat difficult with the washer's front off if you do not have the special pliers.
Aug 23, 2008 | LG WM2487H Front Load Washer
Thanks,
Jul 16, 2008 | Kenmore Elite 45986 Front Load Washer
LG WD-1021-WF Front Loader Washing Mashing
Not a hard task if you coat rims with liquid detergent before trying to install new seal.
Using thumb go slowly around rim working seal all the way back.
Replacing main spring can be done by working bottom to top and then hold left side of spring in place while you pull right side in with long nose pliers.A couple of minutes difficult work and your 90% done.
Care is required so as not to puncture seal,
Main point is to ensure seal is fully seated before applying spring.
Having machine laid on its back makes the job so much easier.
This job took an hour and 30 minutes, the hour spent checking the internet first.
Good luck
Kevin
Jun 20, 2008 | LG WD-1280FHD Front Load Washer
Bosch Nexxt Premium WFMC6400UC Front Load Washer Logo
407 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Craig Butler
Craig Butler
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
