Question about Maytag Microwave Ovens
My microwavw won't heat - Maytag Microwave Ovens
  • 42 Answers
If the light comes on when you open the door the fuse is okay. If the timer seems okay, there is some life. The three things that fail are the high voltage transformer, cap and diode. The capactor - large metal can - is first choise to fail followed by the diode and then transformer. These parts work at around 2000 volts or more depending on size of the oven and should not be replaced or approached unless one is skilled in this type of repair. These can be leathel parts to handle. Also improper repairs can cause excessive radiation leaks.......... take it to a qualified repair shop.
Posted on Apr 08, 2011
My lg microwavwe wont stop running but doesnt heat.when you press it says door
You may have either a defective door switch, or the latch assembly is not properly activating the switches.
Jan 26, 2017 | Microwave Ovens
HOW TO FIX MICROWAVW TOUCH BUTTONS?
If the touch pad and circuit board are two separate components, I'd check all the connectors, ribbon cables, etc. , between the two. Sometimes removing and re-plugging in a cable will fix the problem.
If it's all one unit, there are companies that fix them. Current price is about $39.
May 10, 2016 | Microwave Ovens
LG microwavw won't turn on
I agree, most likely the fuse.
Apr 20, 2014 | LG LMV2053 Microwave Oven
GE JVM 1653WH01 over range microwavw: Hetas food but light, internal fan and turntable only work intermittently.
A relay sometimes gets bad connections inside and needs replacing. The door switches turn everything on and off, likeely one of the switches is bad
Nov 24, 2013 | GE JVM1542 Microwave Oven
How many watts hot point microwavw m#rvm1435wd001
Your RVM1435 microwave is rated at 950 Watts for cooking. Total watts will be slightly higher as the power used for the display, clock, etc. are not counted for cook power. Here are the rest of the common specifications.
I hope this helps - please rate my reply. Thanks.
May 20, 2011 | Microwave Ovens
What size fuse would i need to replace in a emerson microwavw mw#8992rd
It is critical to use exactly the same fuse type and value that was taken out.
Mar 04, 2011 | Emerson MW8102SS 1100 Watts Microwave Oven
Hi, The microwavw heats up and F3 shows on the LCD and wont work until after a while. Thanks
Make and odel please.
Error code F3 on many models of microwave oven means a problem with the touch panel, (tact switches).
Replace the switch panel to fix the fault.
Hope this helps.
Jan 18, 2011 | Microwave Ovens
The microwavw make a electrical sound now it run but not warm
sounds like you magnatron shorted. you should call for service. find a shop you can bring it to. its alot cheaper then having a tech. come to you.
Feb 26, 2010 | Whirlpool Microwave Ovens
Microwavw will not heat food
replace the magnetron of your unit.
Sep 08, 2009 | Microwave Ovens
Microwave Ovens Logo
22 people viewed this question
Top Maytag Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Maytag Microwave Oven Expert? Answer questions, earn points and help others
