Question about Health & Beauty
Only led in coming on even after full battery charged
  • 29 Answers
Service your phone and change the ic if needed
Posted on Apr 08, 2011
WORX BATTERY CHARGER. when i PUT THE CHARGER ON THE GREEN LIGHT COMES ON.
Mike, The red LED is suppose to be on when you insert battery, the LED will go green when battery is charged. Look in your manual, Pg. 11 charging instructions. Check the attached links,manual,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
http://pdfstream.manualsonline.com/7/72bd8a7a-cf98-43d4-92b7-a15bc78eb6bb.pdf
Battery Driven String Trimmers
How to Check Li ion Battery
Jul 15, 2016 | Worx Gt Wg151.5 18v Cordless Electric...
18v 12 cordless trimmer/edger. Why won't it start?
the trimmers switch may be faulty.
CHARGING THE BATTERY PACK
Battery packs for this tool are shipped in a low charge condition
to prevent possible problems. Therefore, you should
charge them until the green LED on the front of the charger
comes on.
NOTE: Batteries will not reach full charge the first time they
are charged. Allow several cycles (operation followed by
recharging) for them to become fully charged.
CHARGING A COOL BATTERY PACK
See Figure 3.
If battery pack is within normal temperature range, the red
LED on charger will come on.
NOTE: If the charger does not charge the battery pack
under normal circumstances, return both the battery pack and
charger to your nearest Ryobi Authorized Service Center for
electrical check.
n Charge the battery pack only with the charger provided.
n Make sure the power supply is normal household
voltage, 120 volts, 60 Hz, AC only.
n Connect the charger to the power supply.
n Place the battery pack in the charger aligning raised rib
on the battery pack with the groove in the charger.
n Press down on the battery pack to be sure contacts on
the battery pack engage properly with contacts in the
charger.
n Normally the red LED on charger will come on. This
indicates the charger is in fast charging mode.
n Red LED should remain on for approximately 1 hour
then the green LED will come on. Green LED on
indicates battery pack is fully charged and charger is
in maintenance charge mode.
NOTE: The green LED will remain on until the
battery pack is removed from the charger or charger is
disconnected from the power supply.
n If both yellow and green LEDs come on, this indicates
a deeply discharged or defective battery pack.
Allow the battery pack to remain in the charger for 15
to 30 minutes. When the battery pack reaches normal
voltage range, the red LED should come on. If the
red LED does not come on after 30 minutes, this may
indicate a defective battery pack and should be
replaced.
n After normal usage, a minimum of 1 hour of charging time
is required to fully recharge battery pack.
n The battery pack will become slightly warm to the
touch while charging. This is normal and does not
indicate a problem.
n Do not place the charger and battery pack in an area of
extreme heat or cold. They will work best at normal room
temperature.
NOTE: The charger and battery pack should be placed
in a location where the temperature is more than 50°F
but less than 100°F.
n When batteries become fully charged, unplug the
charger from power supply and remove the battery
pack.
Source(s):http://toolboyworld.com/eBay/Ryobi_P110/...
Jan 23, 2016 | Ryobi Garden
Why did weed eater just stop working?
Take note: The battery pack will not reach full charge capacity on the first few charges. The break-in period requires 4 to 5 charging cycles, where the battery pack is completely discharged ( no motor sound or tool motion) and then fully recharged. During the break-in period the battery needs to be charged 5 or more hours continuously. The green LED light on the charger will come on in 3-5 hours,this is normal, Continue to leave the battery pack chargingvfor a total of 5 hours or more. After the break-in period, a full recharge is indicated on the charger when the green LED light is lit. Note: Do not charge battery in areas lower than 50 degrees or higher than 80 degrees. Looks like this will need to be charged in the house. I found all this information on page 14 in your manual.
Jul 18, 2015 | Garden
Black decker cordless drill ldx120 runs for a second and shuts off, battery fully charged and the led light comes on and is bright.
The brushes on the motor may be worn . The battery may have several bad cells in it. The led lite only needs 2 volts for full brightness.
Jan 17, 2014 | Drills
New out of the box wont power on
Hi.. Let me try to help you if I can... I'd like you to check a few things,
1) Open battery cover on handset & make sure that the battery pack is installed correctly, and not upside down. Also make sure the little wires that come from battery pack are plugged into the tiny jacks of the phone (usualy red & black wires) in handset is fully attached & pushed snuggly into the handset... and if No wires, check to ensure the part that does connect the battery to handset is not covered with a plastic film of tape or paper as right from a manufacturer they sometimes do that to preserve length of battery until product is sold to you..
2) Check the bottom of the handset phone, that sit in the cradle of the electric part of the recharger, and make sure there is nothing like plastic or paper covering the connections between the bottom of the handset and the charger. Make sure there is a full on connection for a full charge to the handset. As with some cordelss phones Ive had the red LED light will not come on if there is something blocking a full connection for a charge.. The red LED light on base, only comes on when the electricity is flowing into the handset. The slightest tilt not allowing handset a full charge, wont give it a FULL charge.
3) You say " NEW. Out Of The Box" I hope when you connected the battery pack into the handset, and made sure it was connected right, you then allowed handset to charge at least a FULL 12 -24 hours before trying to use your new cordless phone. as the batteries right out of the box, are rarely already fully charged when any cordless phone is bought and then it does need 12 - 24 hours for a FIRST FULL CHARGE...
If you can check all 3 of these questions, and let me know how things are back on this posting, if you stilll can not solve the problem after a full charge to battery, I may have some other ideas that can help.
Good Luck
Stevie
Feb 14, 2010 | Uniden Cordless Phone
I have a question about the JDSU battery pack. i have an HST 3000 battery pack. The connector for the charger was broken, i replaced the connector and the batteries. when i charge the unit the red LED is...
Had a similar problem, it shouldn't take that long to charge. Try reseting the battery gauge, you'll find this under Power management. Only reset when you think the battery is full.
Feb 05, 2010 | Computers & Internet
Power led is red
which means that ur battery is charging,it needs 1-2 hrs to be full charged so even after 2hrs it shows red which says that problem vit battery/ charging module better take to service center
Nov 06, 2009 | Toshiba Satellite A205-S5880 Notebook
Power problem
Seeing as you notice that your battery life is half, this most likely means your battery is no longer able to hold a charge, or a full charge. It could also mean the battery is defective.
If your laptop is still under warranty, the manufacturer may replace it. If not, you'll have to buy a new battery, unless you always keep it plugged in anyways.
Mar 23, 2009 | Dell Inspiron 600M Notebook
Batery lamp always on
No sir, u can't set anything manual in that. Its a hard wired program and can't be re-programmed electronically.
Dec 08, 2008 | Acer Aspire 5100 Notebook
Red LED stays on
Sounds like the rechargeable batteries are aged out, and no longer able to develop a full charge, and soon will be needing replacement.
A repair center might likely do it for you for a fee, but see "Self Repair" on site:
http://www.fixya.com/support/t961386-change_battery_in_norelco_5841xl_razor
Good Luck GB_C
May 06, 2008 | Norelco Reflex 5841 XL Electric Shaver
Health & Beauty Logo
13 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
