What is the difference between a dvd player assy, and a dvd main cba with dvd mechanism. my dvd player has gone out on my tv and i want to order a new dvd player. is this possible and where can i get it from. the tv is a emerson ld195emx
  • Vernon Johnson
    Vernon Johnson Apr 08, 2011
    thank you have been very informative
  • 4,889 Answers
The DVD player CBA is a the small drive like assembly that goes into the tv to perform the functions of the DVD player. This tv is so old that it would be very very hard to find a replacement. Even if you manage to locate one It would not be less than 100$. The best way forward would be to buy a DVD player assembly. I have been to an electrnonics store recently and they were selling the basic version(2.1) of Philips home theater system for about 100$!A decent Philips DVD player should cost you about 60$ .
Posted on Apr 08, 2011
  • eagle338
    eagle338 Apr 08, 2011
    You are most welcome. Thank you for using Fixya!
What is the NBA CBA limit this year?
For the 2011-2012 season, the CBA limit is $58.044 million. This is subject to change from year to year based on different conditions with the players.
Feb 06, 2013 | Basketball
My dvd player is hooked up to t.v. but only plays movies in black/white
How is the DVD player connected to the TV? If you are using component video, check that the cables are connected correctly.
If you switch the order on two of the cables, the black and white result is common. So double-check that the red, blue and green connections (RPbPy) have been connected to both devices in the same order. Next try a different set of component video cables, in case one of the wires is damaged.
If possible, try a different type of connection to rule out a damaged input/output. Connect the TV to a different DVD player or the DVD player to another TV, if possible, to rule out similar damage.
Please add a comment with the connection type for additional support. I hope this helps.
Oct 07, 2012 | Vizio L37 Television
INSTALL DVD PLAYER TO MY TV AND ITURN ON THE DVD TO PLAY AND DID NOT COME ON
Try double checking your connection on both ends (from the dvd player and to your tv). Be sure the colors of the cable (e.g. red, white, yellow) are inserted in the correct place (according to color) on both the dvd player and the tv. Also check to make sure when you turn your dvd player on and the tv on that your tv is on the correct input. The tv usually shows which input is being used where the cables are connected (e.g. audio/video 1, hdmi 1, etc). If the tv does not specify the different inputs where the cables are inserted, use the tv remote to go through the different inputs by pressing the input button until you have either selected the correct one or gone through all of the available inputs. Be sure to allow enough time (10-15 seconds) for each input to register any kind of signal, and also be sure that the dvd player is on before searching through the inputs.
Feb 28, 2011 | Onkyo DV-SP302 Progressive Scan DVD Player
Unit fell on the floor and now gets stuck while "Reading Disk .." after hitting play. Can hear the mechanism start and stop continually but never gets past the reading disk stage. Perhaps...
1. Open unit as if you were loading a disc.
2. Locate laser lens and sliding lens assy.
3. Take a non-conductive material (wood, plastic) and try moving the laser assy. along the track.
NOTE: you may have to be a bit heavy-handed to make the laser assy. move.
4. Move it in one direction but only far enough to free the jammed laser mechanism
5. Reinstall a DVD and press "play"
Nov 08, 2010 | Panasonic DVD-LS86 Portable DVD Player
Dear sire I have symbol LS2208 handheld scanner (serial cable) but when connected in com port in a regular PC it do not power on .
you're going to either connect it to a com port that provides power, or get a different cable that allows you to connect an external power supply to it.
CBA-R01-S07PAR RS232 Cable assy, 50-14000-009R 220V PS,
or get a usb cable - program the scanner to USB, This will provide the power.
CBA-U01-S07ZAR-B
but only if you have an operating system that recognizes USB
Sep 23, 2010 | Symbol LS2208-7AZK0100S Handheld
Tv desn't turn on,power light just flashes ten times and then stops and then again
Error Indication Information
Error No. Error Information ERROR DESCRIPTION LAMP LED OSD LAMP OFF
(Note 3) (Note 4)
POWER LED TEMP LED
Note:
1.When any of the above errors has occurred, the LED will flash as shown above every 5 seconds.
2.When two or more errors have occurred at the same time, the LED will light up or flash as shown above, and then
change to another every 5 seconds in turn.
3.Warning OSD appears when the Air Filter is clogged 90%, accumulated operation time of the Lamp reaches 5000 hours,
or accumulated operation time of the Air Filter reaches 400 hours.
4.LAMP OFF: The LED will flash right after the Lamp goes off.
5.IC2301 is mounted on LCD Main C.B.A. which is included in the Projection Unit.
6.IC6001 is mounted on TV Main C.B.A.
Clogged air filter
more than 90%
15)
16)
17)
18)
1)
2)
3)
4)
5)
6)
7)
11)
8)
9)
10)
12)
13)
14)
- flashes 5 times -
every 5 seconds
IC2301(pin82) detects the clogged air filter, then indicates the
error when the air filter is clogged 90%.
Front Fan stop or
Lamp Fan stop
flashes orange
once every
5 seconds
IC2301(pin12) detects the Front FAN stop or Lamp
FAN stop, then indicates the error when the Front FAN
or Lamp FAN is stopped.
Lamp Cover open
Temperature Sensor
short or open
flashes orange
twice every
5 seconds
flashes orange
3 times every
5 seconds
flashes green for
140 seconds.
flashing red for
60 seconds.
light up red.
flashes once
every 5 seconds
flashes once
every 5 seconds
flashes red for
10 minutes
flashes once
every 5 seconds
Abnormal
Temperature
flashes twice
every 5 seconds
flashes twice
every 5 seconds
Request for Lamp
Replacement - - lights up
Power Ballast Error
(abnormal
Lamp voltage)
flashes 3 times
every 5 seconds
Power Ballast Error
(abnormal
temperature)
flashes 4 times
every 5 seconds
Power Ballast Error
(other causes) - -
Request for Filter
Cleaning -
Abnormal Voltage
on 16 V line of
LCD Main C.B.A.
flashes twice
every 5 seconds
flashes twice
every 5 seconds
Abnormal Voltage
on 14 V line of
LCD Main C.B.A.
flashes 3 times
every 5 seconds
flashes 3 times
every 5 seconds
Abnormal Voltage
on 7 V line of
LCD Main C.B.A.
flashes 4 times
every 5 seconds
flashes 4 times
every 5 seconds
IC2301(pin76) detects the Lamp Cover Unit condition
(open or close), then indicates the error when the
Lamp Cover Unit is open.
IC6001(pin85) detects the Duct FAN stop, then
indicates the error when the Duct FAN is stopped.
IC2301(pin74 and 75) detects open or short of the Temperature
Sensor (R2911) on Front Thermistor C.B.A., then indicates the
error when Temperature Sensor is open or shorted.
(The error is not detected for 1 minute after Lamp ON.)
IC2301(pin74 and 75) detects the temperature attached near
the Front FAN by the Temperature Sensor (R2911) on Front
Thermistor C.B.A., then indicates the error when the
temperature becomes more than 43 C (109 F).
IC6001(pin86 and 87) detects open or short of the
Temperature Sensor (R2901) on Lamp Thermistor C.B.A.,
then indicates the error when Temperature Sensor is open or
shorted.
(The error is not detected for 4 minutes after Lamp ON.)
the Lamp by the Temperature Sensor (R2901) on Lamp
temperature becomes more than 60 C (140 F).
IC2301(pin11) detects the error of LCD Power C.B.A.,
then indicates the error when the temperature fuse
(117 C)(243 F) in LCD Power C.B.A. is open.
IC2301(pin11) detects the error of LCD Power C.B.A. and Lamp,
then indicates the error when an inner malfunction of LCD Power
C.B.A. occurs, the Lamp voltage becomes more than 130V or
less than 30V, Lamp current becomes more than 5A, or the Lamp
is cracked.
IC2301(pin11) detects the error of the Lamp, then indicates the
error when the Lamp is short-circuit.
IC2301(pin48) detects +16V line voltage on LCD Main
C.B.A., then indicates the error when the voltage
becomes less than +13V.
IC2301(pin47) detects +14V line voltage on LCD Main
becomes less than +11V.
IC2301(pin45) detects +7V line voltage on LCD Main
becomes less than +5.7V.
IC2301(pin44) detects +3.3V line voltage on LCD Main
becomes less than +2.5V.
flashes 3 times
every 5 seconds
flashes 4 times
every 5 seconds
Abnormal Voltage
on 3.3 V line of
LCD Main C.B.A.
- flashes 5 times
every 5 seconds
Forced cooling
The failure of Lamp
light up
Temperature Sensor
short or open
Abnormal
Temperature
Duct Fan stop -
When accumulated operation time of the the Lamp reaches
5000 hours, OSD (replacing the Lamp) appears on the screen.
Note: The Lamp time is stored in EEPROM (IC2305).
When accumulated operation time of the Air Filter reaches 400
hours, OSD (cleaning the Air Filter) appears on the screen.
Note: The Filter time is stored in EEPROM (IC2305).
During forced cooling, this indication is indicated.
IC2301 (pin11) detects the failure of light up processing of
the Lamp, then the POWER LED is changed as follows.
1) POWER LED flashes green for 140 seconds (while turning on).
2) POWER LED flashes red for 60 seconds (while cooling).
3) POWER LED lights up red (standby).
Note: If the Lamp will not light after attempting turning on the
power 2 or 3 times, the Lamp, the LCD Power C.B.A. or the
LCD Main C.B.A. may be defective.
Error Symptom Problem Possible Solutio
May 30, 2010 | Panasonic Viera TH-50PX80U Plasma TV
Need wiring diagram for DVD PLAYER ASSY DL-06LS-M1
i'm trying to hook up a dvd player to my lcd tv.i can play a movie through the tv but i cant record tv on to the dvd player.i only have antenna tv can you please solve this problem for me.
Jan 15, 2010 | Akai LCT3201TD 32 in. LCD Television
My LG SUPERMULTI dvd player mod RC797T
This sounds most likely like a bad mech assy (bad laser) only drawback is that LG does not sell just the laser but the entire mech as a whole (laser motor and case) which I belive runs around 140 to 160 from Andrews electronics
Oct 13, 2008 | Televison & Video
My dvdplayer wont playdvd
Try a different DVD If that doesnt work then try a music CD. If that dosent work then in sorry but the laser Mechanism has gone bad and it would cost more to repair the DVD player then replace it.
Thanks for reading!
Apr 22, 2008 | Cyberhome CH-DVD 300 DVD Player
DVD loader mechanism
It is called the slider assy. The slider moves the laser assy back to home or start position. It is a small belt underneath or there is gunk or hair in the gear mechanism. A very common problem with CD/DVD players/recorders. Very good though that you saw it was not comming back to home place. I wish I had a manual to assist you but I do not. Im telling you the most common problems with the slider mechanism. Good Lck
Oct 08, 2006 | Sanyo DVW-6000 DVD Player/VCR
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
