Got a netgear usb wireless adaptor, it won't assign an IP address for this computer. Where do I set the DHCP to assign an address automatically?
  • 32,281 Answers
Open Control Panel - Network Connections then right click on the Wireless Network (USB wireless adapter) and then click on Properties. Then in "This connection uses the following items" scroll down to Internet Protocol (TCP/IP) then click on Properties and in the General tab select "Obtain an IP address automatically" also select "Obtain an DNS address automatically" Then click OK
Posted on Apr 07, 2011
How to connect my self and make my IP address ?
you can set your laptop up to detect ip address automatically in its network settings. if you had provided the operating system it would have helped to narrow down how to do this. If you had told us how you plan to connect to the router this also would have been helpful. Are you connecting via blue cat5 ethernet cable or via wireless. If it is wireless your laptop should detect the wireless network and you can ask it to connect to it. If the wireless link is encrypted you need to log into the router via ethernet cable and look for the securirty settings on the wireless and find out what the encryption code is. Usually the router will use what is called an internal IP address range. the subnet is usually class c being 255.255.255.0 and the ip address default gateway IP address is usually either 10.0.0.1 or 198.168.0.1 and this can be put into the browser to log into the router. When you set the laptop to automatically obtain the IP address the Wireless Router has a DHCP server that manages the leases of IP addresses to computers connected to it. However if you are connecting the Wireless Router into an existing network with another router you will need to set the IP address to the next IP address eg 10.0.0.1 on existing router make second router 10.0.0.2> if you have a DCHP server on the wireless turn it off if you have a DCHP server on the existing router otherwise you have confusion as to which DHCP server to listen too on your network.Make sure the DHCP router does not allocate at least the first 10 addresses eg 10.0.0.1 to 10.0.0.10 to allow for the routers and printers on your network that may need dedicated IP addresses (Static IP addresses)
Feb 07, 2015 | D-Link dlinkgo Wireless N 150 Router...
Tip
IP Conflicts in a work place
An IP address conflict occurs when two computers on a LAN or the Internet have been assigned the same IP. IP conflicts between two computers normally render either one or both of them unusable for network operations.
How IP Address Conflicts Happen
Two computers can acquire conflicting IP addresses in any of several ways:
· A system administrator assigns two computers on the LAN the same Static IP Address.
· A system administrator assigns a computer a static IP address within the local network's DHCP range (dynamic IP range), and the same address is automatically assigned by the LAN DHCP server.
· A malfunction in the network's DHCP server allows the same dynamic address to automatically be assigned to multiple computers.
· An ISP accidentally assigns two customers the same IP address (either statically or dynamically).
· A mobile computer is put into standby / hibernate mode and then awakened later.
Note that other forms of IP conflicts can also occur on a network. For example, one computer may experience an IP address conflict with itself if that computer is configured with multiple Network Adapters. System administrators may also create IP conflicts by accidentally connecting two ports of a network switch or router to each other.
Recognizing IP Address Conflicts
On most Microsoft Windows computers, if you attempt to set a fixed (static) IP address that is already active on the local network, you will receive the following pop-up error message:
The static IP address that was just configured is already in use on the network. Please reconfigure a different IP address.
On newer Microsoft Windows computers having dynamic IP conflicts, you should receive a balloon error message in the Taskbar as soon as the operating system detects the issue:
There is an IP address conflict with another system on the network.
Sometimes, especially on older Windows computers, a message similar to the following may instead appear in a pop-up window:
The system has detected a conflict for IP address...
On Mac or Linux computers, a similar message will normally appear on screen.
Resolving IP Address Conflicts
Try the following remedies for IP conflicts:
1. For networks where IP addresses are fixed (statically assigned), ensure each local host is configured with a unique IP address.
2. If your computer has a dynamically assigned address, releasing and renewing its IP address can workaround IP address conflicts.
3. If your home router is believed to have a faulty DHCP server causing IP conflicts on the home network, upgrading the router firmware may resolve this problem.
on Nov 24, 2010 | Computers & Internet
Wrt54g2 dhcp problem
You must enable the DHCP setting on wireless router if you've configured the computer's wireless adapter to obtain an IP address automatically. If not you will get the "failed to acquire an IP address" error when you try to connect to wireless network! Also don't forget to configure big enough IP range on router's DHCP setting, because the router won't be able to assign IP to 6 computers if you only configured 5 IP space on router.
May 18, 2011 | Computers & Internet
Need to set up wireless router
you have two ways:-
  1. DHCP (Dynamic Host Control Protocol)
  2. Manual entry of settings in wireless adapter properties.
1.DHCP:-
In DHCP method you dont have to enter any settings on the wireless adapter. The wireless network which you are connecting will automatically assign an IP Address to you. But to use DHCP it must be supported by your wireless network.
This method is mostly used over wireless Connection in small networks connecting 2-200 computers. In this method you have to obtain the following information from your connection provider.
  • IP address (Its format is "xxx.xxx.xxx.xxx")
  • Default gateway address (very important)
  • Primary and secondary DNS (If not given then you can use "8.8.8.8" as primary DNS and "8.8.4.4" as Secondary DNS...thats free DNS service from google and its very fast)
  • Subnet Mask (not needed mostly...automatically generated)
Sep 25, 2010 | NetGear WNR2000 Wireless Router
I have a MacIntosh computer and wanted to install NetGear WGPS606 54 Mbps Wireless Print Server w/4 Port Switch to serve a Canon Pixma MP830. The hangup is the IP address assigned to the printer. I had...
You can assign ip with 2 method 1 is manually and other is automatic .
If you set manualy ip you must need to set gateway as your printers and other computer's gateway.
Subnetmask is same in all system.
For example if your netgear lan ip is 192.168.1.1 then your printer ip 192.168.1.5 sunet mask as 255.255.255.0 and gateway is 192.168.1.1
Other computer's ip 192.168.1.6 subnet mask 255.255.255.0 gateway 192.168.1.1
Make sure the printer driver installed and it is in network.
IF you want ip from netgear then you need to enable dhcp in it.
Connect your router to computer with ethernet cable then you can access it with following default link.
http://192.168.1.1 or
http://192.168.0.1 or
http://192.168.15.1
or
http://192.168.2.1
If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it.
Then it ask for user name and password.
Type user as "admin" and password as "admin" or "password" or blank.
Then you can see configuration page of router.
Then click on dhcp then enable save settings and restart netgear.
Then in printer set ip get automatic from router.
Let me know if you need further assistance.
Thanks for using FixYa.
Jul 14, 2010 | Computers & Internet
Netgear DGN 2000 won't connect to internet by cable / wifi works
Might I suggest looking at the routers configuration. This can be done by typing in 192.168.1.1 into your web browser. Typically the default log in is: User Admin, Password is password. You want DHCP set on. Save all your settings. Then reset to factory default. There should be a reset button on the router. This will reset it to when it was new- any changes you made will be gone.
Oct 11, 2009 | NetGear DGN2000-100NAS Router
How do I get the right DNS?
WEll the easiest way is to make sure your WGR is set up as a DHCP server you will find this in its settings. Also make sure that you PC's network settings have DHCP assigned IP address and also DHCP assigned DNS settings jere is a clip of what they should look like
Hope this help[s you
Aug 18, 2009 | NetGear WGR614 54 Mbps Wireless Router -...
Wireless connection problem
When you say "IP and DNS settings are correct", can you define what "correct" is? IP and DNS settings change depending on the wireless network they're using, so one setting will not work for all networks. The most "correct" setting you can have is probably DHCP - which is called "Obtain IP address automatically" and the same for DNS. If your laptop has any statically assigned IP information, make a note of what they are, and then change it to DHCP and see if you have better luck. If you have statically assigned IP information, it will allow you to connect to the wireless network, but not provide internet access because your IP scheme and DNS settings are wrong. It sounds like the scenario you're describing.
May 17, 2009 | Dell Inspiron 8000 Notebook
Netgear SmartWizard Help
Is there an option to use a dynamically assigned IP address (also called DHCP)?
That's most likely the option you need, almost all home Internet providers use DHCP to assign the information you are asking for automatically to your Internet connected device (in this case, your router).
Let me know what options are available to you if neither Automatic or DHCP is.
Thanks!
Mar 29, 2009 | NetGear WGR614 Wireless Router
Connection problems
Is wireless connection enabled in your routers wireless settings and not encrypted in any way until a connection is established. Make sure your router is set to enable DHCP, as this will give your wireless card an IP address automatically. Ensure your card is set to obtain an ip address automatically. If not look in your routers setup(normally by typing 192.168.2.1, in your internet browser) to see what IP address and DNS address it has given your connected pc (eg 192.168.2.3). Then go into your cards properties and use the IP address 192.168.2.4, but the same DNS address(probably 255.255.255.0); then re start the wireless pc and the router if neccasary. If you still get no connection, ensure wireless light is on; on your router, and you have no obstacles in the way of the signal. If you are using WEP encryption it is normally a Shared key setting rather than an open key setting. Please reate this solution.
Nov 20, 2006 | NetGear Wireless-G USB Adapter...
Computers & Internet Logo
80 people viewed this question
David Payne
David Payne
