Question about Garden
I have a bolens tiller 21A-250h765 I will prime it 3 times and then pull the rope it starts up and then dies after a couple of seconds Its like its not getting any gas after the intial prime stage
Benimur
  • 6966 Answers
SOURCE: ard Broom leaf blower, pull rope problem
Like most mechanical problems, your concern would require the disassembly for visual inspection. Offhand, the problem could be a loose nut or lock. If you have not performed a similar repair before, then perhaps it is best for you to make use of a repair manual or at least an exploded diagram to give you an idea how the parts are interconnected. If you would be uncomfortable performing a DIY (do-it-yourself), then perhaps your best bet would be to seek the services of a qualified professional.
A simplified repair sheet may be of additional help.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Posted on Oct 31, 2008
SOURCE: toro personal pace mower 5 yrs old only runs 10-15 seconds.
Was gasoline left in the tank during off season? Sometimes gas will break down and clog the jets in the carb. The priming bypasses the carb so when you put fuel in by pumping the bulb it runs, but dies becasue no additional fuel is coming through the carb after the primed fuel is burned off. Sounds like you need to clean the jets in the carb and in the future, use Stabil in gasoline to keep it from breaking down.
Posted on Jun 30, 2009
garing
  • 998 Answers
SOURCE: My 550 series Bolens lawnmower won't start. When
keep pushing the prime button
Posted on Aug 08, 2009
  • 14 Answers
SOURCE: Bolens 4.5 Briggs and Stratton: I prime the carb
Be sure the fuel is fresh....meaning, fresh from the gas station. IF that doesn't fix it, replace the carb.
Posted on Oct 08, 2009
SOURCE: push mower starts, then dies, ad nauseum
i have a 21",4,5 hp yard machine with a briggs
Posted on Aug 26, 2010
How do you start it/
Check:
- Gas in gas tank
- Oil level correct.
- Tiller drive in off/disengaged position.
Start procedure:
- Fuel selector - ON
- Ignition switch - On
- Choke - On
- Throttle position - Slow
- SAFETY - No children within 10 feet/
Pull Starter rope......
Repeat 3 - 5 times only.
If engine starts, release choke as required until engine runs smoothly.
If no start,
- set Choke to OFF, Throttle to FULL,
- pull starter rope 3 - 5 times only.
- if start, reduce throttle to obtain smooth idle
- if No start, start check for:
- Spark at plug
- Fuel in the jug
May 22, 2015 | Garden
I have a bolen snow blower with a 208cc engine that runs for 5 minutes then quits seems to lose compresion
you may want to try and see if your cylinder walls are scratched when it loses compression try using som oil in the cylinder and see if the compression comes back up. if so then you may have a scratch cylinder. if compression does not come up then look at the valves to see if they are seating right. if not then you may have to do a valve job.
Jan 26, 2015 | Bolens 158 cc 24" Front-Tine Tiller CARB...
Yard Machines rototiller front tine- having problems starting
Sounds like you are either losing your "prime" or your carb needs either, cleaning, rebuilding with a kit. Probably a cleaning will do it. Watch U Tube there are wonderful people who film the whole process from tear down, to replacement. Com'on! Get into it its easy and it don't take long. Then you'll always know how to do it!
May 04, 2010 | Yard Machines Tecumseh 148cc Front Tine...
Starting rope won't rewind
There are two or three screws that hold the retract assembly on to the engine cover. Take these off, and pull the retract off. First, try to turn the pulley on the inside in the direction that the rope would turn it if you you were pulling it out. Will it rewind? If not, there is a screw on the top of this assembly, that's covered up with a sticker. you'll need to remove this screw, and pull the pulley out. There will be a spring on the inside of this. check the spring to see if it's broken. If not, and it's just come loose, put it back into the slot that holds it, and wind it up enough to get it back together. turn the spring in the direction that the rope would pull it out, until it won't go any more. Hold it, and reinsert the rope, tie a couple of good knots in the end, trim the excess, and let it retract the rope into the assembly. Put the assembly back on your engine, and you're good to go.
Feb 09, 2010 | Yard Machines Tecumseh 148cc Front Tine...
Is there a choke setting and throttle setting for best results in getting the MTD yarde amchine started?
Most of the small outdoor power equipment that I have used takes the following to start:
1. Prime 6-8 times, or whatever the manual calls for.
2. Choke the carb to full choke.
3. Pull starter rope. It may sputter and die.
4. After it sputters and dies, put the choke on 1/2. Pull a time or 2 more and should start. Run like that 10 seconds or so, then take choke all the way off.
Oct 30, 2009 | Mtd Garden
The best way to start cold husqv leaf blower 145
Oct 30, 2009 | Husqvarna Backpack Blower 155 145 Starter...
Starter rope too hard to pull on Yard Machine By MTD
Not sure if this will help. Don't want to sound like a **** but....Have you made sure nothing is caught or jammed inside it. This could make it hard to start with the cord..
May 19, 2009 | Troy-Bilt Pony Garden Tiller
I have a Bolens 6.0 OHV tiller M# 21A-332C163 and S# 1C283K40098. It will start on first pull but only run 2 or 3 mintues then quites. You then have to choke it to restart it then again it will only run...
Has it sat with gas in it ? if so carburetor needs cleaned,The other thing could be water in gas look in tank for something that looks like a bubble floating in bottom of tank if you see one its water you remove tank clean out then if carburetor has bowl you must remove carburetor bowl clean out water.
May 04, 2009 | Garden
Garden Logo
129 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
