Question about Lexmark X4650 InkJet Printer
Need help with printer. question marks on grey canister
  • 3,530 Answers
Welcome to Fixya
Just re-install the software drivers of your printer and issue will be resolved.
Thank you for using Fixya!
If you need further help, reach me via phone at https://www.6ya.com/expert/elixirjose_00375ea24bd8141b
Posted on Apr 08, 2011
Hose attachment
Not sure if you're referring to the wands or the swivel neck?
Here are 2 examples, if these help then great, if not then can you give more information?
http://tinyurl.com/grey-wands
http://tinyurl.com/grey-neck
Nov 06, 2013 | Electrolux Lux 5500 Canister Vacuum
It is printing a grey strip on the left hand side of the page
This actually sounds like the mylar belt on the fuser is tearing, If you've found any greyish looking material coming out then this is your issue and you'll need to replace the fuser.
or
It could be as simple as a defective toner, pull the toner out and open the flap that exposes the drum and see if the drum is wiped clean or if the very same mark is on it, if so then replace bad toner cartridge... hope this helps and if so please mark Fixya...
Jun 25, 2010 | HP LaserJet 3330 All-In-One Printer
My canon phtocopier 2016 (error 007)this film roller is ok and all unit reassembled but green handle (paper jam removal is broken)
On the fixing roller, on his left side there must be small white/grey marking, if it isnt there the film isnt ok. E007 means that sensor canot detect that small white/grey mark. If the pressure is ok, no mater to broken handle it should work.
Jun 22, 2010 | Office Equipment & Supplies
1300 Printer prints roller marks only on one side. have tried cleaning roller & changing cartridge.
If it is not the cartridge check the fuser. Open the back access cover shine a light in and look for wear marks on the grey fuser film. If it is worn the fuser film is worn it should be replaced.
Jun 09, 2010 | HP LaserJet 1300 Printer
Paper jamming
I would clean the rollers on the tray and make sure you are using fresh/clean paper. You can clean the rollers with a air canister, simply pull the paper drawer out and look for the grey/tan rollers.
May 03, 2010 | Brother MFC-7440N Laser Printer
My HP LJ 4 is printing Grey roller type marks. Not diagonal it's like a rectangle across the the width of the paper about 1 1/2 wide then a space about 1/4 then the Grey again. Any help would be gr
Sounds like dirty rollers or perhaps a bad print cartridge. If you have another ctg to replace try it first if lines are still there check the rollers inside the machine where the paper is fed. Use the sheet to match where the marks are to the rollers on the machine. When you find them clean with alcohol and let dry then try again. there are also paper feed tires that are inside the paper tray that could be dirty also.
Hope this helps
TankMurdock
Apr 24, 2009 | HP Office Equipment & Supplies
Grey marks and shadow images on copies
Drum, cleaning blade, and PCR need replacing, and most likely the developer as well. This is not something that can be done by an end-user. Fuser could be causing a portion of this problem as well. The machine basically needs it's 60K maintenance performed.
Mar 23, 2009 | Ricoh Aficio 2018D All-In-One Laser...
My printer- Brother HL1250- is making grey streaks on the paper
More than likely the grey streaks are from dirty fuser rollers open the fuser area and insect the fuser rollers i think they should be grey take silicone lubricant and wiat ntil rollers cool down and clean with a coton cloth do not scrape with anything sharp if this does not work then you ned to remove the glass platen and clean the optics( mirror and lens with tissue and glass cleaner wen machine is not hot also insect expsoure lamp( do not touh lamps because the oil from your hands will cause the lamp to get extremly hot and burn out good luck
One other thought is there could be marks from the stripper fingers at the fuser section look for build up of toner on them if so clean with q tip and alcohol
Dec 04, 2008 | Brother HL 1440 Laser Printer
Model 116 hose clog?
http://geeksquad.fixya.com/ThreadView.aspx?prdid=109459&thid=699656
Posted by rfrazelle on Jun 23, 2008
My old canister model 116 followed with numbers 2839580 marked Kenmore 3.9 with power-mate, worked fine until the bag got overly full. I have changed the bag, cleaned the filter, and removed a nasty hair/fur/dust clog :-p from the lower metal tube of the power mate. It now has very weak suction and won't pick up anything. I suspect a clog in the grey plastic flexible tubing attached to the canister but cannot get it apart. Advice?
RJ
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Kenmore 22313 Bagged Canister Vacuum. The best way to find a clog in an electric hose is to use a steel ball or a large marble to place inside the hose and to let it so threw as far as it can to determine where the hose clog is. Once you have determined where the hose clog is then you can use a small end of a broom handle of take an old wire coat hanger and place a hook on the end and try to pull the clog out of the electric hose – the electric hose is very expensive so try not to damage the hose in any way, shape or form. Or another way is that id you have another canister vacuum you can try to pull the clog apart by using two vacuums turned on and running. If you are successful then run the round marble or steel ball thru the hose again and the clog should be cleared.
http://www.sears.com/ Customer Service 1-800-4-MY-HOME 1-800-469-4663
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jun 23, 2008 | Kenmore 22313 Bagged Canister Vacuum
Laserjet 2300d
Probally fuser needs replacing, they come out easy it is a the hot bit at rear, these just click out after removing rear door, upper heat roller will be marked if this is causing your problem
Another way to tell if it is crtridge or fuser (tt is one of these two) is to stop a print half way by opening cover when paper is halfway threw insides of printer (timeing, timeing). Then pull out cart see paper under it that is printed but not yet fused (rubs off) if no mark present then it gets on paper when it goes threw fuser, if mark is present then it is the cart.
Oct 20, 2007 | HP LaserJet 2300d Printer
Lexmark X4650 InkJet Printer Logo
115 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
