Question about Mtd 22" Yard Machine Push Mower
Model 11B-084c06290012 Type of oil Streight 30
Model 11B-084c06290012 Type of oil Streight 30 weight or what? and how much oil?
What type of oil filter do I need for a lawn tractor 24H.P. 46" mower Model #28857
Any good 30 SAE weight is recommended for grass mowers..if used with a snow blower use a good multi viscosity 10-30 or 5-30 ould be fine..good luck..
Jun 27, 2015 | Craftsman 21 Hp 42" Deck, Ys 4500 Lawn...
What type of oil for yard machine 16.5
30 weight oil only it will say thirty weight on bottle do not use 10 w 30
Sep 02, 2014 | Yard Machines 13AN775S000 500cc 16.5 HP...
Dont know what type of oil to use
Put straight 30 weight motor oil in it. Not 10W30 or any multi-viscosity oil. Straight 30 weight motor oil. If you're doing a complete oil change, then you may want to use Synthetic 30 weight, which will last longer between oil changes and also make your engine last longer (but it costs more too). Best of luck to you.
James
Sep 12, 2011 | Toro Power Lawn Mower
In changing 2005 Harley Heritage Model FLSTCI fork oil, how many ounces of fork oil should I use? What does wet or dry mean?
I'm sorry but I don't have the specs on the quantity and type of fork oil for your year and model bike. I work on the older bikes that the dealers will no longer service. But, I can describe the difference between the "wet" and "dry" conditions of the fork assembly. If you take the front forks apart, clean them out, and put them back together with no oil in them, they are considered "dry". For a simple drain and refill type oil change on them where you don't get all the oil out of them, they are considered "wet". I hope this helps, You can call you local dealer's service department and they should tell you the quantity and viscosity of the oil that goes in the front forks on your machine. They'll tell you something like 6 ounces of "Type E" oil, for example. Harley-Davidson uses these types of specs to describe their oils. If you go to a website for fork oil, like PJ1, they may give a cross reference or equivalency chart for converting H-D "Type E" to their oil. I think that would be their 30 weight oil. If the front end seems too "stiff" with 30 weight, you can drop down to 20 weight. I think Honda makes a 25 weight but not sure. Your Harley won't mind the Honda oil. BG.
Good Luck
Steve
Aug 23, 2011 | 2005 Harley Davidson FLSTC - FLSTCI...
What oil type do I need for an Ingersoll Rand type 30 model 253?
I've seen a lot of different oils used. I like IR's t-30 all season. use a compressor oil if at all possible. A 30 weight non-detergent is a minimum.
Aug 18, 2011 | Air Tools & Compressors
Does anyone know what type of oil should be used in the Governor of the Generaq Model QS-7.5G Generator? Aquick response would be greatly appreciated. Thanks, Arno.
As a general rule the type of oil used depends on the normal ambient temperature. However, the normal weight oil is 30 W HD.
Oct 26, 2010 | Electronics - Others
Need manual for Remington Limb & Trim 8, Model #AQ53938. No problems, just lost the manual. Need to know oil weight, etc. Thanks.
I tried the numbers you provided and none crossed.
I went here:
Remington.com
http://www.desaparts.com/index.htm
  • Type "YourModelNo" into the "Model #:" window, then click search.
  • Click the YourModelNo - Remington Electric Chain Saw "View Model" link.
  • Click “View Owners Manual” or "View Illustrated Parts Breakdown" link.
The most complete owners manual is "M15012US (and several others)" viewed as explainewd above. Page 9 discusses oil weights. Standard bar oil is 30 weight non detergent with addatives to help it adhere to the bar. That would be my recommendation. HTH
Lou
Jan 15, 2010 | Remington Garden
Lost the manual. What type of oil do you put in? Chainsaw or 10/30 motor oil?
The manual says 30 weight engine oil. I'd use bar oil (30 weight with stuff added to help it stay on the bar and chain) available at most home centers and hardwares. HTH
Lou
Oct 18, 2009 | Remington Polesaw Wizard
What type of oil for central pneumatic air compressor model number 94667
It should use 30 weight mineral oil, or 30 weight motor oil.
Aug 01, 2009 | Air Tools & Compressors
Mtd 22" Yard Machine Push Mower Logo
Top Mtd Garden Experts
Roland W VanLue
Roland W VanLue
Tim Whalen
Phil Walker
Phil Walker
Are you a Mtd Garden Expert? Answer questions, earn points and help others
