Question about Electrolux Washing Machines
Have a ewf model that will not start. green light is on and blinking but no response when i push the button
  • stannga Apr 08, 2011
    Serial number is :01675715 Model 8556. The installer installed the machine with the drain hose in a downward position. It worked for about 5 loads. Now I get a green flashing light on the start but no response when I press the button
  • 4,323 Answers
Hi
The issue seems to be with the control board going bad however, please elaborate and post back with the model no for further assistance.
Daniel
Posted on Apr 08, 2011
  • Daniel Scott
    Daniel Scott Apr 08, 2011
    It seems that something is stuck or the drain hose is not installed correctly or is kinked, you will have to take it out and clean it then install it correctly
Green light is blinking --says clean when you push
Hello & Welcome to FixYa
Flashing green light is reset by pressing two buttons in sequence 3-4 times, to reset your dishwasher press these buttons in sequence:
High temp wash-heated dry-high temp wash-heated dry
Please get back to me if you have any other questions.
Kevin
Jun 10, 2011 | Kenmore 16764 Dishwasher
Green light is blinking over "start & resume"
It sounds like he didn't run it completely through try holding the cancel button down for a few secs.
Mar 22, 2011 | Magic Chef DU6500 Dishwasher
Will not turn on
ONE OF TWO THINGS HERE:
set turns on and green power light goes off in a few seconds, if this is the case on the front of set push and hold both menu and input buttons at same time for at least 5 seconds and release both buttons.
Green power light will blink two digit error code like: 2 blinks, 2 blinks----a pause and it will repeat error code for a total of 5 times.
If this is case let me know error code.
If green power light does not come on let me know.
You answer will dictate a response if you let me know here.
I am expert on Mitsubishi sets and know them well.
SD TECH
Aug 17, 2010 | Mitsubishi WS-55511 55" Rear Projection...
How do you unsnap the lid clothing stuck under agitator
i bought2 month ago new electrolux washing machine model EWF 8556....now this washing machine will give me a problem......problem is start /stop button always blinking.....and other button also not funtion( spin/option/rinse) also for delay button....... so please help me as soon as possible..... tq
Aug 12, 2010 | Washing Machines
Dell x50v won't turn on
while pushing the power button , push reset button for couple of seconds. hope that helps as that is what worked with mine.
Jun 11, 2009 | Dell Axim X50v Pocket PC
Blinking clean light
If the clean light flashes 7 times, pauses, then repeats...
When the dishwasher doesn't sense a water temperature increase, it will stop working and lock the functions (clean light flashes 7 times, all buttons are non responsive). It does this as a safety in case the element is broken and feeding electrical current into the water.
To resolve this you will have to reset the console. Do this by closing the door and press these buttons in sequence...
-high temp wash
-heated dry
-high temp wash
-heated dry
...all the lights will turn on briefly and the machine will start a diagnostic cycle. You can press cancel or let the diagnostic cycle finish (1-2 minutes).
You should now be able to run the dishwasher as normal.
If the issue returns, you could have a problem with the heating circuit (ie. element, thermostat or wiring). It rarely happens but it could also be the door switch not engaging properly when the door is closed (slightly bend the door latch down making sure it doesn't hit the door when you close it).
Jan 21, 2009 | Kenmore 24 in. 16293 Built-in Dishwasher
I cannot unlock the commands ; the red light ( paddock ) is on
Push the HeatDry and High Temperature buttons at the same time
Then:
punch these buttons back and forth until lights light up (about 5 times) then:
Hit cancel
Jan 01, 2009 | Kenmore 24 in. 15689 Built-in Dishwasher
My projection tv trys to come on but won't you push the button and the power on light comes on but goes off comes back on then goes back off 3 to 4 times then goes off for good started few days ago but if...
I need the model number of your set. And can you count exactly how many blinks the power light blinks when you press power? Please respond to this same post so all comunication will be available for each response.
Jun 26, 2008 | Televison & Video
Blinking green reset light
Can you please supply us with the make and model as well as the blink count of the green light. That count should be indicating the problem circuit. Once that info is posted, we should be able to give you more details and possible solutions.
Dan
Jun 19, 2008 | Televison & Video
Washing Machines Logo
57 people viewed this question
Top Electrolux Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you an Electrolux Washing Machine Expert? Answer questions, earn points and help others
