Question about LG LDS4821 24 in. Built-in Dishwasher
Why is the water still on the bottom... will not go away? how do u do that?
    Guru:
  • 500 Answers
Drain pump not working anymore. Check the outlet hose and let it lie on the floor to drain most water out of the dishwasher, then remove the Top Panel (fastened by 2 screws at the back) and then the side panels. A normal Dishwasher should be attached to the sump.
Kind Regards :-)
* If you found this solution helpful, please rate 4 thumbs up and leave a small testimonial. :-)
Posted on Apr 09, 2011
When is a dishwsher supposd to drain? Is pump working correctly?
normal to fill pan during wash and rinse fix door seal if it leaks
Jun 15, 2015 | KitchenAid KUDE40FXSS Builtin Dishwasher
Water not draining away, what can I do
Take out the bottom rack and put it aside. In the bottom of the dishwasher, there is a plastic strainer that screws in. Remove the screws and set them aside with the strainer. Feel around for anything in the hole which could be blocking the drain. Often labels, soapscum, food particles, etc., get in there. If there is standing water, mop it out so you can see in there. After you've cleaned out the drain, replace the strainer with its screws and the bottom rack. Try the dishwasher out by letting in a little water (an inch) at the start of the cycle, then turn it to the end of the rinse cycle to see if the water drains out. Hopefully that will fix your problem without having to call in an expert.
Feb 25, 2015 | Dishwashers
When I open the refrigerator, I notice water at the bottom
The drain for the water to get away when defrosting is frozen shut...
Checkout this tip to help you..
http://www.fixya.com/support/r3780310-water_running_in_refrigerator_from
heatman101
Jun 07, 2010 | Maytag PTB1553G Top Freezer Refrigerator
Ice forms in bottom of freezer on frigidaire
dependant on appliance you may have a small drain hose at the base of the appliance that drains the defrosted water away at regular intervals. Sometimes this blocks and the water that should drain away just starts to freeze over.
Mar 19, 2010 | Frigidaire Freezers
The water wont go away suspect blockage how do i unblock
hi there i have managed to solve the problem by undoing the filter under the bottom panel it was blocked with debris and coins everything fine now thanks bob warwickshire
Dec 26, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Water is not draining away throguh the hole near
the drain is probably frozen, unplug unit and defrost manually, use a hair dryer to melt the ice around the drain , be careful not to melt any of the plastic
Nov 03, 2009 | Bosch Classixx KGV28323 Bottom Freezer...
Water weeping out vents in lower back of freezer compartment
heatman101
Jun 29, 2009 | Kenmore 73502 / 73504 / 73509 Bottom...
Bosch KGU40124 water leaking from freezer
remove freezer back panel and you will see a tray at the bottom with a drain hole in the middle and it is this which is blocked. if blocked with ice, clear with some hot water and make sure drain is free and water flows away
Nov 05, 2008 | Bosch KGU40124 Bottom Freezer Refrigerator
Water pooling on the bottom shelf of the freezerless refrigerator
take back panel off inside freezer.
you will see a drain tray at the bottom with a drain hole in the middle. this hole is blocked with ice
melt off with a hairdryer and follow up with hot water till water flows away freely.
check drain tray heater is ok as well
Oct 11, 2008 | Kenmore 16.7 cu. ft. Freezerless...
LG LDS4821 24 in. Built-in Dishwasher Logo
83 people viewed this question
Top LG Dishwashers Experts
Mike
Mike
Mike
Are you a LG Dishwasher Expert? Answer questions, earn points and help others
