Question about Razor MX650 Electric DirtBike
My razor mx650 rocket bike got wet when i was hosing it down now i doesn't work. just a quiet "click" sounds when i hit the accelerator, i haven't checked on it in about a week or so. will it work in a couple of days? Is it waterproof?
2 Suggested Answers
kelleyjo29
  • 18 Answers
SOURCE: What happens if you blow a fuse on a razor mx500 dirt rocket, would it explain the bike shutting down and not turning back on
http://www.scootercatalog.com/ottrshti.html
This site has everything to check if scooter is not running regarding fuse problems.
Posted on Mar 14, 2016
Why is my Razor motorcycle MX350 battery showing green but not charging
yes!your battery needs replacement.....throttle clicking after a full charge is a sign,...but that's after 2years or more,depending on how it's being used..your motor can go bad before then if you been riding in the rain--wet connectors in or out the motor can not get wet for any reason..a full dirt motor bike can not get full dirty with mud..mud catains water/water and electricity don't mix/////.motor/thottle/moisture.
Dec 17, 2012 | Razor MX500 Dirt Rocket
Razor MX650
It is the rear freewheel assembly causing the problem. if is fixable, but you have to be good with tools, the bicycle shop and the electric bike shop both said they couldn't fix it, but is is doable. 1. you need a special bmx tool that fits that back wheel, your local bike shop should have it in stock. 2. you need to remove the freewheel sprocket and disgard it along with the the bearings (make sure to unscrew the razor chain sprocket from the freewheel assembly and secure it for reuse). 3. either purchase a new freewheel sprocket for bmx wheel or remove one from a old bike (again you will a special tool for that). 4. screw the razor chair sprocket onto the new BMX sprocket (it goes on with the same 4 original screws, right over the sprockets. 5. Screw the freewheel back onto the rim now. tada its fixed.
Jun 03, 2012 | Razor MX650 Electric DirtBike
How do i adjust the chain on the mx650
The chain tensioner is on the right side of the bike a few inches or so in front of the tire on the rear swing arm all you do is adjust it up to tighten and down to loosen it.
May 30, 2011 | Razor MX650 Electric DirtBike
Cold knock
This is just a suggest, mind you, but if its still under warrenty, I would run it by the dealer, because from what you write, it sounds like a little bit of piston slap.
That engine should be tight.
Nov 27, 2008 | 2008 Triumph Rocket III
Razor MX650 Electric DirtBike Logo
245 people viewed this question
Top Razor Toys Experts
Clif Roberts
Bryan Mcphee
Bryan Mcphee
Level 1 Expert
David Payne
David Payne
Are you a Razor Toy Expert? Answer questions, earn points and help others
