Question about Sanyo Televison & Video
Tv wont turn on.. Ceacked all connections.. all ok what gives?
  • 42 Answers
If it's 3 years old it must likely has dryed out capactors in the power supply section. Nothing is made like it was in the old days.
Posted on Apr 07, 2011
Wgt624v4 wont connect
Hi John,
Have you tried resetting the router using the internet address?
When your IE stops with "Can't open Page" type into the URL box
192.168.100.1/gscan.htm.
This should give you the router maintenance page which will tell you if it is working ok and options to try and reset it.
Feb 27, 2014 | NetGear WGR614 Wireless Router
Tv wont turn on
Check connections, if all connections are OK, the TV's power supply will be broken
Nov 21, 2013 | Televison & Video
Tv turns off then back on,, now it wont turn on at all
1. is the tv connected to pvr ordvd or is it directly connected to wall cable.?
2. is power cord properly inserted at both ends?
3. try direct cable connection to wall to check if ok. Then reconnect to other devices.
Aug 07, 2013 | Element Electronics ELCHW261 26 in. TV
TOSHIBA 32AV502 Wont Turn On
Ensure that the input device and the connections are ok. Try changing the input device to something that you know, works. Try controls on the panel of TV. Remove battery from remote, before you do that. Try connecting the TV to a different power outlet. If nothing works, this might require the attention of a qualified service technician.
Jul 30, 2012 | Toshiba 32AV502R LCD TV
Panasonic tv model tc-p42c2 remote is inop
It is a common thing that all the buttons of a universal remote control might not work, as it meant to be. Try an other code. If this too won't help you, there is no other way than buy a new original remote control for your Panasonic TV. You can buy in from the authorized service center for Panasonic at your town. Just give them the exact model number to your TV. They will provide you the original one.
Jul 20, 2012 | Panasonic TCP42C2 42 in TV
Previously Requested but no solution: I cannot reprogram the remote for this TV so that I can connect to AT&T Uverse Satellite. I do not have a mdoel number for the TV remote that came with the...
Hello, Mr. Ross.
I'll be more than happy to assist you with this and all of your other Uverse concerns.
First please write these codes down, these are the TV codes for your Mitsubishi TV,
0093, 0150, 0178, 0019 (we are going to do trial and error for these codes till we hit the correct one for your TV.)
Please turn the TV on and point your ATT remote control.
Okay, using your ATT remote control, please press and hold the TV button together with the "OK" button.
All four modes should flash twice indicating that we are programming your remote control.
Now, enter the 4 digit code and the selected mode (in our case it is the TV) should give a long flash.
Then press OK.
Try to turn your TV off and check if it would respond
If not, please redo the steps but this time use the other codes I provided earlier.
If these codes wont work we will do the automatic code finder if you are using the "black" AT&T Uverse remote control.
Using your ATT remote control, please press and hold the TV button together with the "OK" button.
Then press the "scan/ff" button repeatedly with atleast 1 second interval till it turns your TV off.
Press OK then try to turn your TV on again.
Whenever your remote won't respond, try pressing either the AT&T button on top of the remote before any other buttons or the TV button beside the ATT button.
Aug 10, 2011 | Mitsubishi Televison & Video
My hlr 5078 wont turn on it gives me 3 blinking lights
CK the Lamp Fan if it stops running Lamp will shut off, and Ballast board is what turns Lamp ON
If Fan is OK Look at Ballast board it connects to Lamp Plugins. Encompass Parts Distrubtion List Parts/Prices for this TV 1-800-638-3328
Let me know if you need any more help.
Mar 21, 2010 | Samsung HL-R5078W 50" HDTV
WD-62525 My tv wont work. new lamp does not work. have tried ever
I had the same problem with my 52". I had the error code of 34(lamp abnormal). I put a lamp in that I knew was good and changed the ballast with one that I knew was good and had 8 caps replaced on the power board(they where not puffed but did them anyways) and still nothing. light came on for 3 seconds and went off again and tv shut down with a red status light. I did some reading on other web sites and found that if the color wheel is bad the tv will not work. I found a light engine on ebay for a 100 bucks used and installed that and now it works perfect.
Feb 23, 2009 | Mitsubishi WD-62525 62" Rear Projection...
Tv wont stop changing channels
ok, Sony had this issue on their early production. The problem you are having is called a leaky switch. The volume down switch on the TV is leaky. To fix this you must replace the switch. This part is called the switch block. Part number 1-473-549-21
Average cost $26
Best regards
Circuitcity
Dec 18, 2006 | Sony KV-27V42 27" TV
Televison & Video Logo
19 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
