Question about Microwave Ovens
Here in Australia we have different power sockets and power supply As I understand the machine I have has 120V 60HZ 1025 W What do I need to use it here in Australia? Do I need a new plug or a transformer? Many thanks Christel
  • Microwave Ovens Master
  • 1,238 Answers
Good day.
first,the power socket,,try to see the power plug of your machine and the power socket you have..compare it..when its compatible no need to replace,,if not you need a socket adapter.or if not available buy a new plug (if your plug is not compatible to the socket)
secondly,you don't need a transformer if your ac supply in Australia is 120v..
if the supply in your place bigger than 120v...like 220v,230 or 250v..you have to use a step-down transformer with input of what you have in Australia and the output is 120v..and of course pay attention for the wattage of transformer to avoid over heat or burn..I suggest to buy 1500w...
thank you and good luck
Posted on Apr 08, 2011
I have aclock on a frigidaire microwave that is loosing time
A defective clock would be the cause, the voltage is regulated by the oven circuit board, so line voltage would rally need to be way off to affect the operation of the clock. Ranges of line voltage here in USA are 110V-120V
Jun 23, 2016 | Frigidaire Microwave Ovens
I appreciate the advice I have got. I have a step down transformer which is written 125v 15amp.Can this be used for my Daewoo DVDP480 120v 60hz 20w?
I take it that you are operating at 220volts, the step down transformer will easily run the daewoo DVD player even if the voltage is 125volts because there is allowance in the circuitry to handle more without damage and the current draw is a fraction of the demand that the the transformer is capable of delivering.
Apr 27, 2012 | Daewoo Microwave Ovens
My oster 1000 watts microwave is not getting hot
There is a semiconductor device called a triac, if food is warm the microwave is not running at full power because the triac is defective.
Apr 09, 2012 | Microwave Ovens
Model SCR 05 120V, 60Hz, 35W. Looking for a manual
Hi, can you please give more details about the manual your looking for?.. The information you gave is not enough for me to provide a manual for the product your looking for ..thanks......
Apr 08, 2011 | Microwave Ovens
Dear Sir, I have an electrically
Yes should be okay to work without bulb without any modification......Try Philips lighting agent for your 120 volt lamp...
Feb 17, 2011 | Microwave Ovens
Hi I bought a expresso machine in Europe 200v. Is it possible to use it in America 110v?
You can't run the machine on 110 volts at all, because its heater is designed to work on 220. But you could have an electrician install a 220-volt outlet near where you want to use the machine. Then replace the European style plug on the machine's power cord with the appropriate American style so you can plug it in. This will provide the necessary power for the machine to operate.
There may be problems using the machine in this country though, beyond the voltage difference. European power-line frequency is 50Hz (Hertz, or cycles-per-second), while it's 60Hz in the US. This difference won't matter to the heating element in the machine. But your machine may not work properly if it has any electronic circuitry inside. There are two possible pitfalls.
First, the electronics in the machine will probably have a transformer in its power supply. That transformer will have been designed for a 50Hz line frequency. Running it at 60Hz might not be a problem, but it could also change the voltage seen by the rest of the circuitry, and this might cause damage. Also, some equipment uses the line frequency as its clock, which in this sense means more like a metronome, providing the beat by which everything else operates. Since our line frequency is faster, so is that clock, and this might throw off the unit's operation. A true time-of-day clock may run fast, for example, since it will gain time. Or the computer inside, if it has one, may not work correctly - or not work at all - if the line frequency is wrong. The only way to know would be to check the manual, which might say it doesn't matter, or to check the circuit board to see how it's designed.
So while the correct answer to your original question is "No, the machine can't run on American 110v", you may still be able to use it here. But without seeing the machine for myself, or having access to a manual to see what it says about power requirements, I can't tell you definitely. Hope this helps some, and thanks for using Fixya!
Nov 29, 2010 | Electrolux Microwave Ovens
I am planning to replace my 240 volt microwave oven with an 120 volt. Can I use a converter?
You might be able to use a 120v to 240v inverter, but may still get problems as the inverter doesn't alter the mains frequency. In the UK and Europe, our 240v / 200v are supplied at a nominal 50Hz. Most 120v systems use 60Hz.
For many devices this doesn't matter, but a microwave oven uses an internal inverter to boost the incoming voltage to the much higher one needed to operate the cavity magnetron: the bit which makes the microwaves. Although it actually runs on dc power, the ac to dc conversion does not produce a smooth dc output,. Since the magnetron relies on an oscillation process to produce microwaves, the wrong oscillation can result in weak or no microwave power, or it can cause the element to overheat and fail.
In simple terms, it will work or it won't. If it doesn't it may blow the most expensive single internal component which usually renders the microwave economically unrepairable. If it does, it may underperform or gradually stress the magnetron causing premature failure. Considering the cost of a suitable inverter and the risks to the oven, it makes more sense just to buy an oven of the correct voltage to start with. New ones cost peanuts these days and used ones are often offered free on FreeCycle or Freegle, usually just needing a good clean before being re-used.
Mar 12, 2010 | GE Advantium SCA2000B Microwave Oven
I have a Sunbeam Microwave Oven SMW777 - 120V-60Hz. It stopped working two weeks ago - - I can set the time for the clock function but it will not cook/heat anything - won't allow me to set a time to cook...
In all likelihood the mangnetron has failed, or perhaps even the Power Supply. You need to have it serviced by a reputable service centre/man.
Ensure you get a firm "Quote" before proceeding, and remember these days the cost of repair can equal or exceed the price of a new one.
Jan 25, 2010 | Sunbeam SMW777 Microwave Oven
Replacing Microwave turntable motor
if they are physically alike use it,the units are both120 volt units,you cant operate a 210 volt motor on 120 volts w/o an inverter furthermore it would be 220 volts for that type of motor,its just a production run #
Aug 25, 2009 | Microwave Ovens
Microwave Ovens Logo
111 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
