Question about Amana Dryers
Acts like it wants to turn but it wont turn. Checked the belt. And its fine. If u turn the barrel manually it will sometimes start after..SO idk what the problem is. or how to even get the top of the dryer completely off.
  • 10,319 Answers
The belt is stretched out of its original shape. You will need to replace the belt along with the idler pulley. Sears has these parts in a kit form with instructions. The rear section were the top attaches to has a screw with a hinged metal peice which needs to be removed from each side of the back. Tiilt the top towards the front and pry up on the two front corners to remove the top. Then the front panel is removed undoing the sheet metal screws. The drum slides out and now you can access the belt and idler pulley. That a picture of it before removing the pulley with the belt on for reference
Posted on Apr 07, 2011
I hav a 2001 toyota camry. it turns over but it wont start. i need help. idk what it is
run the fault codes and look for faulty cam/crank position sensors( broken timing belt/chain). check immobiliser operation.
Nov 20, 2014 | 2001 Toyota Camry LE
1995 sl1
replace ignition coil
Jun 20, 2013 | Saturn Cars & Trucks
When the serpentine belt is off the engine starts with the belt motor turns but drags and wont start the motor shakes and acts a miss took the alt.had it checked it was fine so my ? Is why would it start...
You need to check all the pulley's to see if one is not turning freely. If one of the pulley's is locked up that will cause the dragging you mention. If they all spin by hand, they all should.
Sep 25, 2011 | 1989 Oldsmobile Cutlass Ciera
We have a 2002 Grand Cherokee that we have just bought. Dealer installed a brand new battery because of sluggish starts. In a week the battery is acting weak again, sometimes it starts fine, other times...
I was having the same issue with my 95 GMC. I replaced the battery and alternator. It would start fine at times, at other times it would be sluggish. I finally took the starter off and had it checked. Turns out the starter was bad. When it would get hot, it would act as though the battery was dead. Replaced the starter and it has not acted up again. Have the starter checked. Replace if bad.
Jul 01, 2011 | 2002 Jeep Grand Cherokee
My dryer's barrel will not turn. I have replaced the pulley and belt but that did not fix the problem. The pulley's tension is not tight enough to turn the barrel. I have the correct barrel and...
Hello Mwagner, sounds like the Idler bearing pulley assembly has come loose from the belt. It's job is to keep tension on the belt so the motor is able to turn the dryer drum. By watching some videos online it seems that alot of teardown is required to get to the part you need to inspect and or replace. Here is a link for you to look at that might help you. Samsung Dryer Idler Pulley Roller Replacement DC97 07509B
May 04, 2017 | Samsung DV316LES Electric Dryer
Fisher and paykel clothes dryer wont turn with clothes in it.
Hi
Most dryers work with a belt around the drum. Either the belt is stretched and needs replacement or there may be a belt tensioner which needs adjustment to tighten the belt.
What is happening in your case is that the belt is slipping on the drum as it is too loose.
Best wishes,
Graemevm
Jun 18, 2009 | Maytag PYE2300AY Electric Dryer
Honda civic wont start
You might have to change the spark plugs or at least have them cleaned.
Jun 19, 2008 | 1996 Honda Civic
Electric Whirpool Dyrer Wont Run
your dryer needs a new motor
Sep 17, 2007 | Dryers
Dryers Logo
56 people viewed this question
Top Amana Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you an Amana Dryer Expert? Answer questions, earn points and help others
