Question about LG LRTN19320 Top Freezer Refrigerator
The cooler not cool properly what is the poseble cuose?
  • LG Master
  • 43,501 Answers
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Posted on Apr 08, 2011
How to properly clean my pelonis water cooler
not sure if this will help you out but have a read up.
To clean the cooler:
  1. Unplug the cooler.
  2. Check to see if your cooler is equipped with a water guard. ...
  3. If you do have a waterguard you need to remove it. ...
  4. Rinse the reservoir out with a baking soda and water solution, use approximately 1 cup of water and 2 tbsp of baking soda. ...
  5. Replace the water guard kit.
The Water Express :: How to Clean Your Cooler.
or go to this link.
How to properly clean my pelonis water cooler Google Search
Oct 30, 2017 | Pelonis Heating & Cooling
Oil and water mixing 2004 m benz c200engine oil in
unlikely to be engine oil, more likely transmission oil from faulty transmission oil cooler in radiator tank
take it in for a proper diagnosis and quote
the coolant system will have to be properly and completely flushed
Oct 24, 2016 | 2004 Mercedes-Benz C-Class
Wine fridge is not getting cold anymore
Its really hard to determine without proper diagnosis, but are you sure it indeed has a compressor? does it run ? Does it have a circulating fan inside? A lot of the wine coolers I've dealt with were "Peltier" coolers. They use electronics to cool usually only to about 10deg below room temp. They require a load ( in this case wine bottles ) to operate properly. They don't have a cold control like a refrigerator.
Jun 30, 2014 | Koolatron KWD28SN 28 Bottle Compressor...
Beeping will not stop on wine cooler - red wine side
Beeping usually indicates that something has gone wrong. Probably not cooling properly. The water coming out would indicate that the unit has defrosted. Turn the unit back on again and see if the red side is cooling properly. Some wine fridges have independent evaporators which allows different cooling temps in different parts of the cabinet.
Jun 26, 2014 | Danby DWC2727BLS Silhouette 54-Bottle...
Do I need a wine cooler to store my wines or can I store them in a normal refrigerator?
The purpose of a wine cooler is to store wines at their proper temperatures in a proper manner. Wine coolers are set to higher temperature ranges than other systems simply because wine should not be kept as cool as other beverages.
Jul 31, 2012 | Furniture
Haier wine cooler won't cool
Does the unit cool at all? If it is running and not cooling properly, check and clean the condenser coils on the back of the cooler.
Jan 25, 2011 | Haier BC112G Wine Cooler
When i turn on my new h p notebook a cooling fan not operating right warning appears. and if i dont push enter it turns off my notebook
you have to consult your engineer to check the cooler fan if it is properly seated on the motherboard or connected tightely
Jan 05, 2011 | HP (344872-001) Laptop Cooler, Cooling Fan
I have a model 5645 and it has stopped cooling
the outside fan can be replaced with a 92 x 25 mm computer cooling fan. Inside fan is a 60 x 10 mm. Remove the cover on the inside by pulling straight up. Plug it in and check if the metal heat sink on the inside is getting cold. If it does, then the problem is one or both of the fans.
Mar 15, 2010 | Coleman Electric Cooler 40 Beverage Cooler
Wine cooler doesn't cool properly
Few things to check here. If the compressor is not running then the problem may be a bad thermostat or the compressor start device (ptc starter). Most common would be the thermostat on wine coolers. Also need to check if the fan is running. If everything is running then you have a sealed system problem. If the fan is the only thing that is not running that will cause a no cool situation.
Oct 07, 2007 | Marvel 61WC Wine Cooler
LG LRTN19320 Top Freezer Refrigerator Logo
161 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
