Question about Maytag Neptune MAH5500B Front Load Washer
Maytag front load 2 year old washer
My machine appears to be working and then the message comes on the front panel that says "the washer did not appear to fill with water" and then it shows the door is unlocked and I haven't touched it.There is water in it.
  • 639 Answers
Dear mad canadian,
ngfam at you service!
neptune was discontinued due to 98 design defects!!!!!!!!!!!!!!!
You can not fix this problem your self!!!
This sounds like it will only fixed by service then you will be happy again!!
Yes sounds like you need service!
Call A&E Factory Service /They service nation wide
And are available 24/7 for making appointments!
If the appliance is 10 years old or more,it may make sense not to invest any money to fix it!
Happy to assist you,
Neil
Posted on Aug 26, 2008
LF appears after my maytag front loader is washing for about 4 min. We took the screens out, cleaned out and swapped ends of hoses from washer to the water valves. Still not working. Washer only a yea
LF means long fill....if the flow meter does not detect
the correct amount of water entering the machine the
code will appear. Google Maytag front load washer
LF code...there are several links including a video
that should help you solve the problem.
Regards,
Dennis
Oct 05, 2014 | Maytag Washing Machines
The bellow or door boot looks warped on my Maytag 3000 series front load washer. The washer is less than 2 years old and I just noticed the bellow looks twisted or warped, but it is not disconnected or...
Check the clamp on the bellow to see if it has come loose and shifted. You may be able to adjust the bellow and clamp and tighten it. If you need the parts, here are the links to them.
Bellow
Clamp
Nov 29, 2010 | Maytag EPIC MFW9700S Front Load Washer
Model - Maytag plus 2 speed. Will not spin everything else works. Machine ten years old
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Sep 08, 2010 | Maytag Washing Machines
Maytag washer top loading leaks water seems to be coming from the tub itself 7 years old thank you mija
does unit leak constant or only when spinning ther are 2 screws done low on front panel fill unit with water and watch center shaft there is a seal below basket
inside washer changing seal is a little difficult have also had this style of washer leak when starting spin cycle if water has not drained out fast enough
http://www.repairclinic.com/Washing-Machine-Top-Load-Maytag-Style-Appliance-Diagram
this page has a break down of normal maytag top load machine part at center is called boot and seal have also had thi type unit leak where bolts go through tub
good luck ron
Dec 12, 2009 | Cameras
My Maytag washer model #:sav515deww is leaking underneath during the spin cycle. I took off the 2 front panels. I saw the water leaking from a large metal part that spins around. Its behind the motor and...
My Maytag washer model #:sav515deww is leaking underneath during the spin cycle. I took off the 2 front panels. I have been told taht it is a bearing and a seal that are out. Replacement parts cost approx $90.00. Unit is 5 years old. Is it hard to fix? Thanks
Dec 10, 2009 | Maytag SAV515DE Top Load Washer
LG WASHER WM1832CW HAS LE ERROR MESSAGE
error LE Overload in motor.unplug for 1 hour plug back in. motors going bad or over loaded with stuff.
Jan 15, 2009 | LG WM-2277HW Front Load Washer
Washer wont rinse
you have a pump problem, need to lean washer back ageist wall go under washer. front left take off both hoses stick finger in pump remove all items from pump &hoses should work now
Aug 04, 2008 | Maytag MAH2400A Front Load Washer
Maytag front load washing machine Model MAH5500B misses spin cycle
either balance load sensor or machine failing to drain in the allocated time, check pump/filter for blockage
Nov 01, 2007 | Maytag Neptune MAH5500B Front Load Washer
Maytag washer sav365zaww
LARRY...I HAVE THE SAME MODEL AND THE SAME PROBLEM JUST STARTED FOR THE 3RD TIME. CALLED THE REPAIRMAN THE FIRST TIME, MYSELF THE 2ND. MINE IS A BROKEN(IN TWO) BRAKE PAD. THERE ARE THREE OF THEM. REMOVE 2 SCREWS AT VERY BOTTOM OF WASHER FRONT AND REMOVE PANEL. YOU CAN GET TO THE 2 FRONT PADS FROM THERE ALTHOUGH TIGHT FIT. I ALSO READ THEY SHOULD HAVE CLEAR LITHIUM GREASE ON THEM, ALTHOUGH THIS DOESN'T MAKE SENSE TO ME. GONNA GO DO MINE AGAIN...GOOD LUCK....KHRIS
Oct 24, 2007 | Maytag SAV2655A Top Load Washer
Maytag Neptune MAH5500B Front Load Washer Logo
57 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
