Question about Amana SXD524VW Side by Side Refrigerator
Our amana side by side works well, in fact too well. It freezes salad greens in the vegetable drawers and now freezes things like yogurt on the open lower shelves too. We've turned dow the settings to both refrigerator and the freezer, but nothing seems to work.
  • Amana Master
  • 43,501 Answers
Hi, There can be many reasons why your refrigerator is freezingyour food. To see what could be happening and to figure out how to possibly fixyour problem. Take a look at this tip which contains many of the causes andsolutions to fix the problems.
Refrigeratoris Too Cold and Freezing Food
heatman101
Posted on Apr 08, 2011
What causes food to freeze in the bottom of the refrigerator & meat & cheese tray
See if there is a temperature setting on the side of the drawer. Mine has a small lever that opens a hole to the freezer to keep that drawer colder. If it's opened too far the food will freeze.
Jul 26, 2014 | Jenn-Air Refrigerators
Our refrigerator is about 7 years old. The vegetable drawers (clear plastic) are very difficult to pull out. We have washed and dried them, cleaned the tracks, etc., but to no avail. Is there a...
Normally, all vegetable doors can easily be pulled out as there are minimum 1/8" allowance in both side. I think, your refrigerator got corroded with where indoor compartment is fixed. Please check any dental in iron side of the door, If not, just clean drawers both side with an emery (salt) paper to enable it to enter inside freely.
Jan 22, 2011 | Amana ARB8057C Bottom Freezer Refrigerator
Vegetables freezing in crisper drawer
This is an issue with the convection system in the refrigerator, while the cold air trapped withing the crisper drawer remains and the temperature of the moisture in the area drops below the freezing point, the water content acts as a cover and thereafter enables the vegetables to freeze. A slight rearrangement of the utensils within the refrigerator solved the problem
Jan 21, 2011 | GE GSS22SGM Side by Side Refrigerator
Food (vegetables, fruits) on the refrigerater side freezing
Your model has a control damper inside the vent. The damper opens and closes with changes in temperature. It has a pig tail spiral thermostat on the side and if it goes bad the door sticks open or closed. Sometimes it is just frost but you will need to get to it. I will send photos and links in a moment, Thanks Sea Breeze
Jan 20, 2010 | Amana ARS266ZBS Side by Side Refrigerator
Salad in drawer is freezing
Good day,
One user claims that the return air vents or vent located at the bottom rear of the fresh food compartment, have collected enough junk to block the cold air from returning to the freezer compartment. You can clean them out but I cannot verify that solution.
The crispers are located in the coldest part of the fresh food compartment.
This problem can occur when the machine gets light usage especially in colder weather, when the machine running time drops and the air in the fresh food stratifies, causing to cold air to pool in the bottom.
Normal may no longer be normal. Controls by their design will tend to run colder as they age. You might try tweaking the control warmer.
Patience and time are the most important tool you have to work with in dealing with this issue.
Dec 04, 2009 | Amana Easy Reach AFD2535DE Bottom Freezer...
Amana Bx22s5W freezes food in the crispers
I've had the same issue with an Amana BX21TL. In my case, the problem was that the various air flow adjustments were all directing the cold air to the bottom of the fridge, underneath the vegetable crispers.
What I've done to fix this was:
1- Made sure there was a tight seal between the vent opening at the back of the fridge (at about mid-height) and the rubber/plastic duct that directs air to the meat/cheese drawer.
2- Made sure that the adjustable opening at the back of the meat/cheese drawer was fully open.
3- Made sure that the adjustable opening at the back of both vegetable crispers were fully open.
Hope this helps.
Jan 25, 2009 | Amana Refrigerators
The fridge on my bosch fridge/freezer keeps freezing all my food
This, as with the on off complaint on a bosch, sounds like your thermostat is n't paying attention. Turn it up, then slowly down and feel for any irregularity. If there is looseness or rough, like hsngin up its the thermostat. At least we know the bulb goes out when you close the door. Good Luck
Dec 28, 2008 | Bosch Classixx KGV28323 Bottom Freezer...
Vegetable draw is freezing the vegetables
if you pull out the vegetable drawer, you will notice a vent on the left side in the back. get some tape ( I use aluminum tape ) and cover the bottom half of the vent, that will help keep your vegetables from freezing. that should solve your problem. Joe
Dec 12, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Bottom vegetable/fruit drawer freezing fruit
to the left of the bottom drawer is a veg/meat slide switch.make sure it is all the way on veg.if it is on meat,it opens a small doorway to the freezer and lets the cold air in and will freeze the food in the bottom drawer.in some cases,you will need to remove the drawer and shelf and then take apart the doorway.ball up some putty and jam it it the hole to completely seal it off
Jan 11, 2008 | Amana ARS2661BS Side by Side Refrigerator
Amana SXD524VW Side by Side Refrigerator Logo
243 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
