Question about Samsung LE32R73BD 32 in. HD-Ready LCD Television
I have a samsung LCD TV that was zapped by a power surge and now will not turn on. The standby light blinks and a slight squeek comes from one of the circuit boards. I tried an inverter board with no luck. please help!
  • 643 Answers
Have you tried replacing the powersupply???
Posted on Apr 07, 2011
My Samsung LED has a flashing blinking light on the front. When I power on, it does not go into standby mode. It just turns solid red for a few seconds and then starts blinking. No image on screen. Is it...
I'm guessing you meant to say 'power off''. Otherwise it sounds like you have reasonably guessed there may be an electronic malfunction -- but with this, as with any device with a 'chip', I'd suggest first literally 'pulling the plug,' or if it's surge protected powering that down. Give it 30 seconds or so, then power back up. Best of luck!
Feb 25, 2015 | Samsung UN32D4000 UN32D4000NDXZA 32 inches...
My sansui hdlcd1909 19 in. lcd tv won't turn on. the standby red light blinks once, what can i do to turn it on?
sounds like bad capacitors on the power board. Very common problem. I would look at the caps if any appear even slightly rounded on top they are bad. They should be perfectly flat on top any puffing up means replace that cap.
Aug 07, 2012 | Sansui HDLCD1908 19 in. LCD TV
Standby light blinks 4 times
The Standby/Power light of the TV blinks when there is any internal malfunction in the TV.
The self-diagnostic function of the projection TV will cause the STANDBY light to blink or flash when the television detects an issue. The number of times the STANDBY light flashes corresponds to a specific issue. As per the two examples below, some of the issues may be resolved without the need for service.
If the STANDBY light flashes four times in sequence, the TV may be overheating. To resolve this issue, ensure that the back of the TV is well ventilated.
If the flash sequence is not listed above or the light continues to flash, follow the steps below to perform a power reset:
Try the following steps to check if the issue can be resolved.
Turn off the television.
Unplug the television power cord from the electrical outlet.
Let the television remain without power for 60 seconds.
Plug the power cord back into the electrical outlet.
If the television is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.
If the issue continues to occur, service may be required.
Thanks for using Fixya.
Jun 01, 2011 | Sony BRAVIA KDL-40S2010 40 in. LCD...
Red standby button comes on after power comes on. It blinks 13 times, pauses few seconds, then 13 more blinks
The Standby/Power light of the TV blinks when there is any internal malfunction in the TV. The self-diagnostic function of the TV will cause the STANDBY light to blink or flash when the television detects an issue. The number of times the STANDBY light flashes corresponds to a specific issue.
Few examples are given below; some of the issues may be resolved without the need for service.
1 blink / 2 blinks / 5 blinks: - This indicates that there may be a power-related problem with your set.
3 blinks: - This indicates that there may be a power-related problem with your set. The set will need to be serviced to allow a technician to determine the specific issue that needs to be repaired. If the power light flashes three times in sequence in a Lamp TV, the lamp cover is not securely attached. Reattach the lamp cover to resolve this issue.
4 blinks: - This indicates that there may be a back light or lamp power problem.
6 blinks: - This indicates that there is some kind of audio problem with your set.
7 blinks: - This indicates that there is a temperature problem with your set. Please check to make sure that the air vents on the sides and back of the set are not blocked or clogged and there is adequate ventilation around the television. We recommend that you check and clean the vents periodically to make sure the set receives adequate air flow. If the problem continues, the set will need to be serviced.
8 blinks: - This indicates that there may be a video-related problem with your set. If the flash sequence is not listed above or the light continues to flash, follow the steps below to perform a power reset:
May 25, 2011 | Sony BRAVIA KDL-40S2010 40 in. LCD...
Sony 3 lcd rear projection tv hd w/ wega gate. kdf-e42a10. tv will atempt to turn, shuts down, greem power light blinks 12 times on average. red standby light blinks 4 times. i replaced lamp [ xl 2400...
Mar 02, 2011 | Sony KDF-E42A10 42 in. LCD Television
Kdl-52xbr4 5 blinking standby lights
If the STANDBY light flashes three times in sequence, the lamp cover is not securely attached. Reattach the lamp cover to resolve this issue.
Dec 15, 2010 | Sony KDL-52XBR4 LCD Monitor
I had a power outage and my computer when I tried to turn it back on after the power was turned back on. All it does is have a green light blink on the back of the tower and a small green light on the...
most likely the surge fried one of your ram chips... this is where i would start first sometimes the ram will work as a surge protection for your motherboard
Nov 18, 2010 | Computers & Internet
Have lcd tv samsung. Had a power surge now tv will turn on but no picture or sound. What could be the problem?.
If you get no standby light or error blinks, the power supply board is bad. Most likely the power surge will take out some capacitors on the power supply. Replace the power supply board to solve the problem. This is a common failure caused by a power surge.
Note: If you are looking to do it the cheap way, you could try looking for bad capacitors (visually inspect for ones that look "bubbly") and replacing just those but it is not guaranteed to fix the TV as the power supply could have other issues and just cause the capacitors to bubble again.
Oct 08, 2009 | Televison & Video
Samsung LE32R73BD 32 in. HD-Ready LCD Television Logo
130 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
