Require circuit diagram for Kenwood X-45 dual cassette deck and T-85 Tuner as Power Amp stolen and I wish to use the above as stand alone units. Original power and system control were plugged into the Power Amp.System control is by 3 wire with a delta style plug.
  • 3 Answers
SOURCE: Stopped working
I had a similar problem with a jvc 8040. when I replaced the fuse it became very obvious that the b1560 output on the center channel was blown (smoke and sparks, always a dead giveaway). I haven't fixed the center channel yet but simply unplugged the center channel board and removed it from the unit. Now everything works fine except of course the center channel. Pre outs still operate just fine so a slave amp could be used for center channel power, or you could just go and buy a marantz amp; I did and then I realized that I was lucky that the old jvc quit.
Posted on Jan 30, 2008
petraman7
  • 1175 Answers
SOURCE: KRF-5030D i stand by mode
Does it go into standby when it's in another mode like : Cd or Video 1 or tape?
When you state that you checked the power amp IC's , how so did you do this?
Thanks n' let me know.
Posted on Mar 17, 2008
robotek
  • 1512 Answers
SOURCE: Kenwood Amp blinking Standby indicator light
Hi fuxsiloh.
It sounds like you have eliminated all the things that could generate this symptom that are external to the amp. It is most likely that there is an internal problem that is causing the amp to go to protection mode. A power supply failure(maybe a fuse) is the only really user serviceable part inside the amp. Perhaps check for failed fuses, replacing any that may have blown with exactly the same type. BE SURE TO UNPLUG AT THE WALL FIRST:)
Is the amp still under warranty? If so, then returning it to a Kenwood service center is the shot. If you want to have a go at repairing it, I can talk you through it, but some experience with this sort of thing is very necessary. Good luck
regards
Graeme
Posted on Apr 06, 2008
SOURCE: Technics ST-X302L tuner - Unit not powering on
i have the same unit and a similar problem, after a fall of the tuner on the floor while i was cleaning my room, first times the st-x302l was powering fine but after some minuts it quit alone.. now (i dont know why) it remains on but if there is an interruption of electricity it dont turn on anymore, it turn on only by removing the metal chassis and moving random the electronics.. i think it has some electronic contact or circuit break.. i brought it to a specialist in electronics and he told me the reparation would be too expensive so i prefer to try fix it by myself.
Posted on Apr 10, 2008
SOURCE: Kenwood KX-W6080 dual stereo cassette tape deck
I have the same unit which had the same problem. It has to do with dirty contacts on each tape mechanism.
Remove the main cover and look down on each tape mechanism. You will see 4 contacts on each unit. These come in contact with the tape. Remove each unit by removing 4 holding screws.
You will now be able to spray some contact cleaner into the front of the plastic contact cover. I removed the covers on both of the second from the right contacts so that I could clean them with an abrasive. These are the main ones.
Put everything back the way it was and the tape deck should work great.
Posted on Jan 04, 2009
I asked 3 times now!!! How do I hook up together a Pioneer tuner, power amplifier, and dual cassette deck, together then hook it up to a speaker!!!
Are we a little impatient?
It's pretty straightforward. Use one cable to connect the tape deck to the amp. Use another cable to connect the tuner to the amp. Use speaker wire to connect the amp to the speaker.
Jul 26, 2014 | Audio Players & Recorders
Kenwood KX-79 CW dual cassette hook up?
Just connect the deck via tape 1 the out of the deck going to the in of the amp. While the out of the amp goes to the in of the deck.
The tape deck itself will automatically choose the player that plays the cassette. One will play the other will be on pause (if you press both play buttons) till the tape stops then the other will play. For recording from tape to tape one deck will be the copy and the other the copier. There should be a dubbing button which you press to record tape to tape. Some models have a high speed dub also. For recording from the amp unless both decks have record buttons you will only be able to record with one deck. Make certain the dub button is not set.
Dec 25, 2013 | Kenwood Audio Players & Recorders
I have a kx-w4050 dual kenwood tape deck niether side will play hear click and counter moves one then another click. Is there a way to fix this?
Yes, the belts need to be check and idlers or whatever drive mechanism that is used in that system. Dual deck units are among the most unreliable units there are and a reason I tell people for the last 30 years not to buy those things. Almost most of the time they are not worth fixing due to their poor performance at the end. These are facts not just opinion.
Jan 14, 2013 | Kenwood CT 401 Hi-Fi Stereo Dual Cassette...
I have an old kenwood stereo system I forgot how to hook up it is a ka-87 amplifier a kt-57 tuner and a double deck cassette player kx-57w .Can anyone help?
Connect the RCA Outputs of the Tuner to the RCA inputs for Tuner on the amp.
Connect the output of the Tape Deck to the Tape Input on the amp.
Connect the input of the Tape Deck to the Tape Output on the amp.
Select Tuner on the amp to listen to the tuner.
Select tape Monitor to hear the Tape Deck(s).
Dec 30, 2010 | Audio Players & Recorders
I´ve forgotten in what order I should connect my old (80´s) separate modul hifi system´s remote cables. It shuts down imadiatly when you try to start it with the remote. If I disconnect the...
I would have thought that it should go from the amp to the tuner,then the tape deck and finally the CD deck.
I'm suspecting that your tuner is faulty and thats whats causing the system to shut down
Aug 27, 2010 | Kenwood CT 401 Hi-Fi Stereo Dual Cassette...
Kenwood KA-880D Amp keeps blowing the 6v 250w fuse
please check the VDR in primary supply side.its directly connect to bouth N&Live wire connections of supply.
nuwan.
Jan 11, 2009 | Kenwood CT 401 Hi-Fi Stereo Dual Cassette...
Kenwood tuner/graphic equalizer c-h6
sound output section trouble.can you remoove and shall we start rectifing the problem.
nuwan
Dec 04, 2008 | Kenwood CT 401 Hi-Fi Stereo Dual Cassette...
 Grubhead
Grubhead
