Question about Pool & Spa
I am looking to replace an XL-2 Teledyne Laars oil fired swimming pool heater but they seem to be obsolete. Many dealers have discontinued this model{DP-250 and DP-350} I note that some people carry the XL-3 which looks similar. Would a XL-3 fit the existing piping arrangement. If so who can do this job? The pool is in the town of Jefferson New Jersey on Lake Hopatcong lakefront Bob Ahart
  • 718 Answers
SOURCE: Where can I download an instruction manual for
You can download some information from;
http://www.manatron.net/Pdf's/JANDY%20MANUALS/heaters.pdf
This will give a parts list, applications and diagram.
Posted on Mar 27, 2009
  • 139 Answers
SOURCE: starting a teledyne laars heater
check for proper millivolt reading( 400-600).it could be 20 different problems and/or components
Posted on Jun 21, 2009
  • 139 Answers
SOURCE: My teledyne laars pool heater will not cycle on. The pilot is lit and the valave is in the on position
check millivolt output should be 400-600.if less than that you dont have enough voltage to power valve
  • 9 Answers
SOURCE: Laars Teledyne Pool heater flames on for 2 seconds, shuts off
You have no flame rectification.....LLD series heaters check for a signal through the flame to ground; if the module does not detect this signal, it go through two more trials for ignition and then lock out the module. There should be a flame rod and it may need cleaning. I use steel wool.
Posted on Jun 28, 2009
  • 246 Answers
SOURCE: My TELEDYNE LAARS Boiler hammers when the main
the hammer is due to boiling inside some one has been messing with the safety controls or water to slow or no flow at all
Posted on Oct 15, 2009
I have a laars 125 swimming pool proplane heater i need to conect to a 47klo prolane bottle can u tell me what regulator i need thanks brian
I wish I could tell you a part number and a supplier but I can only recommend contacting your propane company or a licensed LP Gas plumber. Either one will need to know pool heater information. I hope this helps.
Sep 04, 2011 | Teledyne Laars Laars Lite 2 Pool Heater...
I have a teledyne laars lite 2, it fires up fine but the flames are excessive and go outwards towards the wires, any ideas
It would seem that this unit has had a conversion done from Nat to LPG or visa versa..the main gas valve and burners need to be adjusted
http://www.laarsman.co.uk
Miles
May 03, 2010 | Teledyne Laars Laars Lite 2 Pool Heater...
Teledyne Laars LD250 Propane Pool heater cycles on and back off
Do you replace the thermopile or check the milivolts?
Check the Pressure gas
You need replace all of them terminals and check again the milivolts at the gas valve
Apr 01, 2010 | Teledyne Laars Laars Lite 2 Pool Heater...
Swimming pool heater
try removing and cleaning flame sensor with fine steel wool.its located in lower end of burner box,usually opposite side of ignitor
Sep 02, 2009 | Teledyne Laars Laars Lite 2 Pool Heater...
My laars swimming pool pilot light keeps going out and it makes a clicking noise when it fires up and the pilot light goes out? it has been going on and off alot recently but can work for weeks on end then...
check power pile conections on gas control valve.it is the 2 wires that come from pilot asembly.if they are loose or have rust or oxidation this can affect pilot and cause intermittent outage. let me know
Jul 20, 2009 | Teledyne Laars Laars Lite 2 Pool Heater...
Pilot light on but heater will not start
check the high-limit switches. Under the inlet/outlet header. if either is open it will not allow you to fire up. my 150 degree switch was corroded and after jump9ng out, bam it worked.
May 25, 2009 | Teledyne Laars Laars Lite 2 Pool Heater...
MY Teledyne Laars is 20 year old +
check pressure switch (looks like space shuttle copper wire one side 2 wires other side) need 24 volts ac both sides if not need new
Dec 18, 2008 | Teledyne Laars Laars Lite 2 Pool Heater...
Pool & Spa Logo
123 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
john h
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
