I did software upgrade for my NETGEAR DG834Gv5 router and after the upgrade I couldn't log into the router by the IP Address althought I can browse the internet and when I restaretd the router I found that the ethernet ports are diabled and the wireless led is green but no wireless ssid is out and the power LED is RED. so as ethernet ports are not working I canot access the router at all. I tried to reset the router it seems to reset but the same result. please help ASAP Usama Bakry
  • Tony Apr 08, 2011
    when u reset the router did you hold the reset button for 30 seconds or more when u first power it on?
debbily
  • 101 Answers
SOURCE: I have to 'Dongle' my way to the internet!
reset shouldn't hurt anything.  The box may have died but the reset didn't do it.
Posted on Oct 14, 2007
  • 193 Answers
SOURCE: Diag led
s u can roll back teh firm ware while u doing this the device should be power on should not be distrubed>and while the firm ware downgrading u can see the power light is blinks>and once its study then reboot and check>if its not works change the device>rate me solved if its help full
Posted on Oct 24, 2007
oldnovii
  • 667 Answers
SOURCE: Cannot configure D-Link DIR 625 wireless router
Hey Raj - Unplug your modem and router. After 60 seconds plug your modem back in. When the lights return to normal (except the activity light) , plug your router back in. Give it 10 seconds and try it. If this solves your problem PLEASE rate this as fixed. If not, DO NOT RATE YET. Just add a comment letting me know what happened and I'll be happy to assist you further. Thanks.
Jeff
Posted on May 31, 2008
RickOz
  • 145 Answers
SOURCE: Connecting Laptop wireless and Desktop wired to the router
Do you need to see the desktop or just share folders from each other? If the latter then you need to do the following:
Use Windows Explorer and select a folder you want to share. Right click and select sharing and security.
On the sharing tab click on Share this folder. Enter a share name ( I like to enter the PC name _folder name; Rick1_Downloads)
Click on Permissions. If your ok with everyone using the PC's and Laptops having access then highlight Everyone and click on Full Control.
Do this on each PC and Laptop.
That should be it or darned near close.
Posted on Apr 10, 2009
  • 159 Answers
SOURCE: Netgear DGN2000: Only ethernet port 1 works.
Sounds like a configuration issue. With some routers you can set them up for bridging. Normally port 1 would connect your "bridge" and port 2-4 would connect your computers. You can test this by plugging your modem into port 1, and your computer in port 2. Power cycle your router and see if you get connectivity. It may be in your best benefit to reset the router to factory settings and see if 2-4 work with factory settings. After the reset, reconfigure the wireless side and your firewall.
Posted on Oct 26, 2009
WRT300N: does not boot, all leds are lit
Solution 1.
How can I reset the Linksys WRT300N to factory defaults?
Hold the Reset button on the Linksys WRT300N for about 30 seconds.
What is the IP Address, Username and Password to log in to the WRT300N?
IP Address: 192.168.1.1
Username: none
Password: admin
You should also know the configuration of your ISP provider after reset. You'll need to re configure your connection from modem to router.
Solution 2
How do I upgrade the Firmware on the Linksys WRT300N?
# 192.168.1.1 -> Administration tab -> Firmware Upgrade sub-tab. Click "Browse" and browse to the firmware upgrade file on your computer. Click "Start to Upgrade". Do not reset or power cycle unit while it is upgrading.
Username: none
Password: admin
Apr 10, 2011 | Linksys WRT300N Wireless Router
Tip
Reset and Restore the NETGEAR device to Factory Default Settings
<p><b>Symptoms:</b><br /> <ul> <li> Forgotten/lost password to log into the NETGEAR device </li> <li>Cannot access the NETGEAR device web interface</li></ul><br /><b>Resolution:</b> <br /> <br /> If you have changed the default password and have forgotten the password, you may need to reset</i> the NETGEAR device to factory default settings. <br /> <br /> When a NETGEAR device resets</i>, it goes back to the state when it was new - all information that was entered by hand is <u>lost</u>! Examples include critical things you need to get online, such as ISP username, ISP password, IP addresses, wireless security keys, and ports and services that were opened. It all needs to be re-entered.<br /> So, have your ISP information before resetting</i> the router.<br /> Naturally, if you moved to a new city, or if you bought a used router, the old information in the router may not be of use to you. Contact your ISP if you can't connect any computer directly to the Internet. Then, if there is a connection problem when the router is added, see <a href="http://kb.netgear.com/app/answers/detail/a_id/1098">No Internet Access Through the Router</a><br /> <b>Reset</i> for most routers with a reset</i> button on the rear panel</b><br /> Write down configuration information such as IP addresses, security keys, opened ports and services, etc., that you modified. (The default username is <b>admin</b> and the password is either <b>password</b> or <b>1234</b>. Try these before resetting</i> the router.)<br /> <ol> <li>Press the reset</i> button on the back until the test light blinks. This takes about 10 seconds. (To avoid accidental resets</i>, the small button is recessed. Use a pen or paperclip to access it.)</li> <li>Release the button.</li> <li>Wait for the router to reboot.</li> <li>Log in with the default password. If the router configuration was not cleared, try these additional steps AFTER the router has finished rebooting.<br /> </li> <li>Unplug the router's power.</li> <li>Press and hold the reset</i> button. While the button is held down, reconnect router's power.</li> <li>Continue to hold the reset</i> button for 20 seconds after reconnecting the power.</li> <li>Wait for the router to reboot.</li> <li>Log in with the default password.</li></ol> <b>For DGN2000 / DG834Gv5 Routers</b><br /> To restore the factory default configuration settings when you do not know the login password or IP address, press both the Wireless button and WPS button on the side of the modem router for 5 seconds.<br /> <b>For FR314, FR318, and FV318</b><br /> These routers require reloading the firmware in order to recover from a lost password. Download the most recent firmware from NETGEAR's Web site before proceeding. Follow the instructions in the manual.<br />
on May 30, 2011 | Computers & Internet
Forgot my security passphase shirleywilt1@gmail.com
Symptoms:
  • Forgotten/lost password to log into the NETGEAR device
  • Cannot access the NETGEAR device web interface
Resolution:
If you have changed the default password and have forgotten the password, you may need to reset the NETGEAR device to factory default settings.
When a NETGEAR device resets, it goes back to the state when it was new - all information that was entered by hand is lost! Examples include critical things you need to get online, such as ISP username, ISP password, IP addresses, wireless security keys, and ports and services that were opened. It all needs to be re-entered.
So, have your ISP information before resetting the router.
Naturally, if you moved to a new city, or if you bought a used router, the old information in the router may not be of use to you. Contact your ISP if you can't connect any computer directly to the Internet. Then, if there is a connection problem when the router is added, see No Internet Access Through the Router
Reset for most routers with a reset button on the rear panel
Write down configuration information such as IP addresses, security keys, opened ports and services, etc., that you modified. (The default username is admin and the password is either password or 1234. Try these before resetting the router.)
  1. Press the reset button on the back until the test light blinks. This takes about 10 seconds. (To avoid accidental resets, the small button is recessed. Use a pen or paperclip to access it.)
  2. Release the button.
  3. Wait for the router to reboot.
  4. Log in with the default password.
  5. Unplug the router's power.
  6. Press and hold the reset button. While the button is held down, reconnect router's power.
  7. Continue to hold the reset button for 20 seconds after reconnecting the power.
  8. Wait for the router to reboot.
  9. Log in with the default password.
Oct 30, 2010 | NetGear Computers & Internet
Xbox Live with Netgear WNR834M Router
please follow the steps to fix you issue
1.upgrade firmware on router
link for latest firmware
http://kb.netgear.com/app/answers/detail/a_id/863
follow steps to upgrade firmware on router
1.Log in to the router using a Web broswer. The URL is http://192.168.1.1 ( if you did not change the router’s IP address ).
2.Click Maintenance > Router Upgrade
3.Click Browse and find the file you just downloaded.
4.Click Upload. Do not interrupt the upgrade while the router does this step. The router reboots when the upgrade is done.
5.After the router boots up, log in the router again.
6.You MUST Reset the router to default settings after upgrading the firmware
7.Click Maintenance > Backup Settings
8.Click Erase. The router reboots when the Erase operation is done.
9.If you would like to check that the upgrade was successful, log in to the router again at http://192.168.1.1, and check the firmware version.
10Re-configure the router with the settings you saved in step 1. Optionally, You can use the Smart Wizard configuration assistant on the CD to reconfigure the router.
after all this login to router
under advance you will WAN setup there will NAT ,you need to click on open then apply
regards
prakash
Jan 26, 2010 | NetGear RANGEMAX WNR834M Router...
False connection with wireless router
Please make a note of the settings of your router before upgarding
  1. Open the browser and access the router (usually the address is http://192.168.0.1).
  2. Log in to the router (User Name = admin and Password = password unless you have changed it).
  3. Click Maintenance > Router Upgrade.
  4. Click Browse and locate the upgrade file (download link is below).
  5. Click Upload.
  6. Wait for the router to reboot.
  7. Verify that the router firmware was upgraded.
  8. Reset router to factory defaults.
  9. Wait for the router to reboot.
  10. Reenter the settings you noted down before upgrading.
ftp://downloads.netgear.com/files/wgt624_2_4_2_8_1_0_1.chk
May 20, 2009 | NetGear WGT624 Wireless Router
Netgear DG836GT
OK. First, that dg836gt_1_02_09.img file does not seem to be a firmware file. You need to get a .zip file or a .bin file to upgrade the firmware. Check Netgear's website for the current firmware. If it is a .zip file, then you need to extract the .bin file from the .zip file with winzip software. Then, log into your router with Internet Explorer by typing it the routers IP address in the address bar like this http://xxx.xxx.xxx.xxx. Enter user name and password. Look for a tab that states software update. Browse for the .bin file you downloaded or extracted from the .zip and click update.
Apr 25, 2009 | NetGear DG834 Router
Power light keeps blinking and cannot log into WPN824 router
Firmware upgrade is very important. You have to make sure that you were able to do it properly.
You have to do a hard reset on the router. Press and hold the reset button for 30 seconds while the router is turned on. Try to see if your computer is able to get a valid IP address. If not, set up a static IP address on the computer and see if you can ping the router, if not then the router has gone bad.
You have to replace it.
Feb 10, 2009 | NetGear RangeMax WPN824 Router
Is there any updates for the netgear router that are new have had ours for several years it is a netgear RP614
If you are referring to the RP614v1 not v2 then the latest firmware update is 4.15 and is located here: ftp://downloads.netgear.com/files/rp614v1_4_15rc4.bin .
Instructions to upgrade:
  1. Using the Web browser, and access the router by typing its IP address in the browser's URL address box (this is usually 192.168.0.1).
  2. Login to the router (User Name = admin and Password = password, unless you have changed it). Can't Log in?
  4. Click Browse and locate the new firmware which you just downloaded.
  5. Click Upload.
  7. Turn the router power off.
  8. Turn the router power on, and wait for the router to reboot.
Jan 29, 2009 | NetGear WGR614 Wireless Router
Connecting to http://192.168.0.1
You need to use the desktop computer to access the Netgear page. Check the default gateway address of your desktop (this is the IP address of your Netgear). You may follow these steps if you don't know how to check the IP address of your desktop:
1. Go to the Command prompt or DOS prompt. Type in ipconfig and press enter. Check the Default Gateway address.
Oct 12, 2008 | NetGear DG834G Router
Wireless connection
JRSavage - The solution you supllied is to assign the IP address to the client. It appears Guest is asking how to log into the Router.
Guest - If the router is a wireless router then you should not have to know it's IP to connect to it, simply looks for it's SSID in WIndows Zero Config wireless util (or the util that came with your wireless adapter)
If you're connected and looking how to log into the router itself you'll want to enter the router's IP address into the address bar of your internet browser.
If you're looking for where you enter the router's IP for NIC configuration, you would enter the Router's IP as the Gateway address.
Feb 23, 2008 | NetGear WGR614 Wireless Router
Computers & Internet Logo
35 people viewed this question
David Payne
David Payne
