Question about Lexmark Optra S 1855 Laser Printer
Lex,ark Optra S1855 Service Error Msg: 931 Printhead Error Where is the Printhead? Is it easily looked at for service?
  • karl_aritz Apr 08, 2011
    THe instructions do not have diagrams to see what I would repair. Illustrations, please?
  • 844 Answers
Welcome to FixYa!
Solution 1.
If this is the first time the error has occurred, try turning the printer off.
Restart your computer.
Let the printer sit turned off for at least 1 minute before powering it back on.
Solution 2.
Make sure it is plugged straight to the wall and not through a surge device or power strip. Power strips and uninterrupted power supplies can cause a low amperage problem in your printer. This can trigger a printhead error (For Lexmark Printers) even if the printer has worked on this surge device for months.
If the printer continues to post a 930 Printhead Error, it thinks the wrong printhead unit is installed.
The printhead unit and possibly the laser cable or the engine/system board to this printer may need to be replaced.
The printer needs to be serviced for it requires personalized tools that prevents further damage to the printer which the only the manufacture has it.
Keep me posted if solution 1 or solution 2 resolved the problem.
Thank you for using FixYa.
Jas247
Posted on Apr 08, 2011
  • 10,515 Answers
Exact error message - Mirror Motor speed detect error
These errors usually indicate a
failure in the HYSNC signal to the
printhead. Check the continuity of
the cables connected to J3 and J8
on the engine board. If incorrect,
replace the defective cable. The
voltage at J8-4 measures
approximately +5 V dc. If incorrect,
replace the engine board. The
voltage at J3-7 measures
approximately +24 V dc. If incorrect,
replace the engine board. If correct,
replace the printhead assembly.
Download the service manual from :-
http://www.feedroller.com/Store/Service%20Manual/Optra%20S.pdf
You need to have acrobat reader to view the file. This file would have all the details regarding print head and other components.
If printhead assembly is at fault, the cost of the new one is around $200.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
  • taran_2005
    taran_2005 Apr 08, 2011
    Thanks for your response!!
    Kindly read the COMPLETE solution. I did mention a link to ' SERVICE MANUAL '.The service manual is the one we use at our shop. Be advised that changing and checking the components does require you to take all precautions.
    Thanks and Regads
    taran_2005
Error 931
Solution What the error means
A Printhead Error message indicates that the printhead (laser scanner) unit inside the printer is not working correctly.
NOTE: On the E250d(n) models, all service errors are signified by the flashing of all of the lights. To determine if this is a printhead error, quickly double-press the pattlnk_312007_2142-continuebuttonicon_e120_en_us.gif button to see the secondary code. If the !, pattlnk_3132007_1545-paperjamicon_e340_e342_en_us.gif, and pattlnk_3132007_1542-continuebuttonicon_e120_en_us.gif lights are the only ones blinking, a printhead or a motor failure is indicated. For more information on deciphering the error lights, click here (PDF file, 255KB).
Clear the error
Step Action 1 If this is the first time you have seen the error, turn the printer off. 2 Leave the printer powered off for 10 seconds or more before turning it back on. This gives the printer a chance to reset. 3
Power the printer back on. If it goes to the Ready state, try printing again. If the error does not return, continue using the printer. 4
If the printhead error returns when the printer is powered on or when you try to print again, follow the suggestions below.
Check the power source the printer is plugged into
If this is an intermittent error, you may want to check how the printer is plugged into the wall.
Make sure the printer is plugged straight into the wall and not through a surge device or power strip. Please try this even if the printer previously worked correctly with this surge device. Power strips and uninterrupted power supplies can cause a low amperage problem, which can trigger a false printhead error.
You may also want to try plugging the printer into a different wall outlet to see if the printhead error continues. This will eliminate the power source as a possible cause of the issue.
If the error continues
If the error does not clear, the printer will probably require service to correct the issue. Please contact Lexmark Technical Support or a local authorized servicer for assistance.
When calling Lexmark Technical Support for service, please be prepared to describe the problem you are experiencing or the error message on the display. You will also need to provide your printer's model type and serial number. This information can be found on a label on the inside of the front cover of the printer.
Please call from near the printer in case the technician asks you to perform a task involving the printer.
Have a nice day and do not forget to rate please...!
May 14, 2012 | Lexmark Optra S 1255 Laser Printer
935 service printer head error. how do I fix it?
The Mirror Motor of the printhead is unable to reach operating speed. This means you have to replace the printhead.
Mar 08, 2011 | Lexmark Optra M412 Laser Printer
I have an error on my Lexmark T632 printer saying 933 service printhead error, can you tell me what this means
Printhead error message indicates that the printhead (laser scanner) unit inside the printer is not working correctly.
First step trying to fix this is to turn printer off, and back on after 10 seconds. If this won't clear it, try and plug the printer in a different power point straight into the wall. If the error does not clear, the printer will probably require service to correct the issue.
Sep 28, 2010 | Lexmark Optra T610 Laser Printer
900 service rip software error on our Lexmark Optra S1855 what does it mean? How do I fix it?
These errors indicate an unrecoverable engine software
error. Replace the engine board is the only solution
Apr 07, 2010 | Lexmark Optra S 1855 Laser Printer
What is 931 service error
Hello my friend,this is printhead error,check connections at both ends of cable for corosion or oxidation,reconnect them.Also can be system board error.You can check the operation of
the printhead shutter and clean the printhead window with a lint-freecloth folded over a cotton swab; do not use a bare swab and do not use any cleaning fluids or water on the printhead window if you see the defect on the photo conductor.Good luck:)
Feb 03, 2010 | Lexmark T642 Laser Printer
PRINT HEAD ERROR
there are several different printhead errors 931 933 scanner motor died scanners bad. 932 934 935 are loose lock errors these can be caused by either the scanner or the engine board
Nov 09, 2009 | Lexmark Optra T614 Laser Printer
935 Service Printhead Error
This error indicates that the Printhead ( Laser Scanner ) is defective. Sometimes turning the printer off for a little & then turning it back on, gets rid of the error but it will usually return. The printhead is situated at the top of the printer under the top cover. It will need to be replaced.
Aug 06, 2009 | Lexmark Optra T612 Laser Printer
Swap parts between Optra S 1255 and 1855
I can say for sure that these parts do not translate. The service manual says.
Jun 09, 2009 | Lexmark Optra S 1855 Laser Printer
Optra t610 error 935/933/934
replace printhead - scanner assembly. The scanner motor is not working correctly. Need to remove side covers, back of printer assembly, the top cover. Printhead is below the top cover
Jan 03, 2009 | Lexmark Optra T610 Laser Printer
Lexmark Optra S 1855 Laser Printer Logo
575 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Roopesh S
Roopesh S
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
