Question about Health & Beauty
I work for an ems service and we have an eagle vent the training on it was poor and the company does not know if they have a manual how can I get one to besure it is working correctly it displayed an error message 5 what does that mean
    Brigadier General:
  • 4,736 Answers
You didn't mention which model you agency has, but here is a link to a video presentation on the operation of the Uni-Vent Eagle Model 754. http://www.childrensmemorial.org/professionals/section4.aspx
In addition here is a link to a Power Point presentation on the training for emergency responders.
www.jdhmedical.com/Impact/754TrainingPresentation.ppt
Hope this helps you. Please let me know.
Posted on Apr 08, 2011
How automotive companies make unique car keys?
A locksmith is a highly trained individual who knows a lot about security.Locksmith services can be of exceptional assistance with regard to dealing with security problems. The automotive companies provide unique car keys, each of this car keys is designed by professionals.
Well, I will recommend you to take the services of Auto Locksmith San Jose, they provide a high-quality Locksmith Service. They have a team of professionals who are skilled enough to design unique car keys. In fact, they are trained enough to provide services on Car key replacements, Car key duplication etc.
Aug 09, 2017 | Cars & Trucks
Maximus em 600 pulley config. Need instructions.
I too am looking for configuration instructions for this machine em600
please help the company doesn't seem to want to
Aug 12, 2013 | Maximus Exercise & Fitness
I have a Rinnai Tankless and I have a problem with the water going from hot to cold so I called to have it serviced, I was told that it needed to be flushed to remove settlement from the unit. Okay we did...
Did service man clean combustion parts and check for loose wires, proper venting etc?
In other words, is the tankless up-to-date on yearly required maintenance?
Did you check outlet for power?
Is the unit properly grounded?
Is the unit vented properly, and set for correct altitude?
Is the thermostat set too high?
What does the manual say about maintenance?
It certainly says to clean water filter frequently, and clean combustion parts yearly, and bleed air from gas line, and delime yearly.
Is your water heater exposed to more than 11 grains hardness in water that will cause failure due to clogged parts?
Does service man have a service manual for your specific water heater?
Does anyone have a service manual for your water heater? Probably not, which means service man will be guessing at one thing and then guessing at the next thing.
Problem could be PC board failure.
Similar to failed motherboard on computer.
Let's be frank:
Do you want the cheapest solution?
Or do you want to chase around trying to find why a complex computer chip connected to electric outlet, electric sensors, gas valve, water valve, water line, gas line, and gas burner with vent to outside has decided to stop working?
Cheap solution, Buy tank-type gas water heater for $350 at local box store. Just get a simple one off the shelf. Don't worry about warranty, because it means nothing.
Select Whirlpool, AO Smith, American, State, Reliance, Craftmaster, Kenmore because these are made by same company and can be repaired and maintained by homeowner, and service manuals are available, and any plumber knows how to fix em..
Avoid Rheem, Ruud, Richmond, GE, for all same reasons except in reverse.
Read the manual, perform the required maintenance.
Keep the air intake clean.
Install water heater yourself same day, turn up the temperature wait, 1/2 hour for tank-full of hot water, and take hot shower.
http://waterheatertimer.org/How-to-install-gas-water-heater.html
Oct 05, 2012 | Rinnai Webstone The isolator EXP tankless...
Rheem tankless water heater eco180-dvn has flash error code 13. Any solution? Called Rheem, only said venting problem, wouldn't provide the next step. Thank you.
Rheem wants customers to call trained service technician since error codes are start-place for troubleshooting, and problems can be combination of issues.
Risk of CO poisoning from improper vent, or clogged drain line causing damage to heat exchanger, and risk of homeowner working on complicated gas-burning appliances are reasons why Rheem instruction manuals recommend yearly maintenance by trained technician.
That maintenance would typically cover most common error code issues, and homeowner could gather tips and information from service tech.
Open following links for Rheem troubleshooting resources:
http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html
http://waterheatertimer.org/pdf/Error-code-13.pdf
Jul 12, 2011 | Rheem Water Heaters
I hit the on botton and it doesen't come on. I have 4 flashing red lights after the green light stops
http://www.scribd.com/doc/16940552/Service-Manual-Kdsr60xbr1
Above is your service manual, perform the troubleshooting steps and you should be able to isolate and troubleshoot, your problem and hopefully effect a repair. Below is another helpfull service and training , manual. http://www.scribd.com/doc/20513612/Sony-Kds-r50xbr1-Kds-r60xbr1-Training-Manual
May 14, 2010 | Sony KDS-R60XBR1 60" Projection HDTV
Powersupply not working.Need circuit diagram and/or service manual.
Well, FIRST, Umm need to know the name make and model of your set, I cannot read your mind...
http://www.scribd.com/doc/2893683/PANASONIC-CHASSIS-TH42PHD5-TV-PLASMA-TRAINING
Anyway that's a training manual this is whats used to tech engineers to fix these. They are all very similar so get a service or training manual for your exact make model.
May 01, 2010 | Televison & Video
1992 eagle talon white smoke
check for pcv valve and vent for blockage ,should be vacuum. valve train could be stopped up and not draining down ,or u need a ring job rebuild
Jun 27, 2009 | 1992 Eagle Talon
EM-G4753
I did a google search for the service manual and found one from Sanyo support. From that I was able to figure out how to open the unit safely, and find the fuses and safety switches to check. I found a loose wire plugged onto the main interlock switch (don't know how it worked all this time for how loose it was...). Re-attached it, and now it works fine.
WARNING! There can be very hi voltages on the inside of the uwave so you really need to be careful and know what you are doing! Also, you need a special bit to remove a couple of the cover screws.
Apr 14, 2009 | Sanyo EM-P410W Microwave Oven
True refrigeration Technical
You can contact any commercial refrigeration company. I just searched for Miami commercial refrigeration on google and several company's are listed. Please let me know if you need any further information.
Oct 06, 2008 | True T-49 Side by Side Refrigerator...
Training
what company do you work for?im a service tech for hobart.what would you like to know specifically?
Jan 09, 2008 | Dishwashers
Health & Beauty Logo
78 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
