Question about Janome Memory Craft 3000
I keep getting Stept motor error.What can cause this
  • 794 Answers
Hi ibequilting,
The Stepping Motor Error that you are getting is caused by a damaged main circuit board / motherboard, breaking the track from the sensor to the computer. If the sensor fails, it does not know that the carriage is back in the correct position. Replacing the motherboard can cause you around $400.
Hope it helps.
Thank you for using Fixya.
Posted on Apr 08, 2011
My xl400 singer embroidery carriage has stopped working. Will not move at all when machine is turned on. Also keep getting msg error about hoop size but no hoop attached.
The switch for "sew" or "embroidery" must first be in the "embroidery" position.
Make sure the connections are very firmly pushed in.
If it still isn't functional it may require some small motors to be replaced. The motors are what makes the hoop move.
Sep 28, 2016 | Singer Futura Xl-400 All-In-One Sewing And...
I am trying to wind on a bobbin and keep getting an error message of E9 which says in the manual When Motor is locked it will not allow me to wind bobbin
The machine you're talking about isn't indicated. However, when the motor is locked it is trying to run the needle and feed dogs at the same time that it is trying to wind the bobbin. This cannot be done simultaneously.
*** The place where you place the bobbin must be set firmly against the bobbin.
***Some newer digital systems still need the hand wheel to be released by hand. (Turn it, push or pull it)
Sep 29, 2015 | Sewing Machines
Fo1 main motor speed error on my espire sewing machine
Kim,
Potentially bad news with this error - could need a new motor. On the positive side, if it hasn't been serviced for a fair while, or has been in storage it may be that the oil has dried out and the shafts are "dragging", slowing the machine. Thread tangles in the takeup leaver area can also cause this in some machines. I'd suggest take it into your local sewing centre for a service.
Feb 02, 2015 | Baby Lock Espire
Husqvarna viking diamond deluxe embroidery machine main motor overload
I'm not familiar with the Diamond machine but suggest the following. The motor is overheating. Is the sewing machine cord plugged directly into an outlet or are you using extension cords? Voltage drop due to long or light duty cords can cause the motor to run hot.
Can you trun the handwheel freely? If not, there is friction or binding in the machine that needs to be corrected. The blank screen and reboot are simply protection devices like a circuit breaker in your home electrical circuits. Find the source of the problem!
Mar 23, 2013 | Husqvarna Sewing Machines
I keep getting an E6 error message - tangled thread. I think it's the bobbin thread that's getting tangled, and I can't figure out why, or how to fix it. Any ideas?
It could be that the bobbin is being put in upside down check to make sure that you do not need a bobbin with a magnet on one side. also make sure there is no thread tangled inside the bobbin housing it will cause the timing of the machine to be off and cause issues with your needle picking up the bobbin and thus cause a mess inside you bobbin housing
Apr 02, 2010 | Brother BC-1000 Computerized Sewing...
Janome E1 error
If a warrantee job, it will be no charge.
Motor in Australia is $149-00.....plus installation charge.
You could phone or email Janome HQ or another dealer in your country and ask for an explaination of the E1 error to satisfy yourself of what is the likely cause, and a quote to fix it.
Aug 21, 2009 | Janome Memory Craft 5700
My babylock says THE SAFETY DEVICE HAS BEEN ACTIVATED. The belt is not broke. I have changed the needle and pressure foot and still when you start to sew it does nothing and the above wording comes...
When you get that error message it usally means there is a jam in the machine that is causing the motor to work to hard so it keeps you from burning up the motor try taking your needle plate off and bobbin case out and then put your needle plate back on and then the bobbin case if that doesnt work try looking at the take-up lever there might be thread wraped around it soaking up the oil and causing a bind
Jul 02, 2009 | Sewing Machines
Step motor error
One of the stepper motors has failed. The machine has two stepper motors: one that moves the needle back and forth and one that moves the feed. Take it to your dealer for an estimate.
Apr 02, 2009 | Elna Quilter's Dream 6003Q
Janome 10000
Sorry if this gets lengthy...
The dealer had tried, unsuccessfully, to reproduce the error, but have they performed any maintenance on the machine (Cleaning / Lubrication) ?
Most AC powered devices will work properly even if your house supply is low. I'm sure this is not the problem, nor is it your outlet. The internal computer is detecting a fault and is run on DC voltage that is internally produced and regulated. If the DC voltage was bad you would probably notice other strange behavior.
The computer is obviously detecting what it thinks is a fault. The only way it can detect this type of fault is from sensors or back feed from motors. Dirty or worn bearings can cause motors to run at a lower than expected RPM, causing the computer to think there is a fault. If you've ever had to remove threads from the foot area it is possible that there is more thread internally wrapped around a spindle, motor or gear causing it to bind, which will lower the rpm, again causing a possible reason for the computer to think there is a problem. If the machine uses any optical sensors they may need to be cleaned as they could have a buildup of fabric 'dust' causing them to produce inaccurate readings. Magnetic sensors generally do not need cleaning but if any are loose they can cause problems.
It may be as simple as getting a can of compressed air used for computers. Use it to blow any dust and dirt from the inside of the unit, hopefully cleaning any sensors.
Hope this helps.
Mar 12, 2008 | Janome Memory Craft 10000
Will not run
I had the same problem with my machine, there is nothing you personally can do to fix it. You'll have to find a service tech who can work on it to solve the problem.
Dec 23, 2007 | White Sewing White 4400 Computerized...
Sewing Machines Logo
60 people viewed this question
Top Janome Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Eva Hack
Level 1 Expert
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
