Question about Philips Televison & Video
Total loss of power to tuner. wall plug and cord okay. Internal fuse good. Tried unplugging and resting unit - nothing. Pushed all the buttons andfiddled with the remote- nothing
  • 643 Answers
Your powersupply is probably bad. Replace that and try again.
Posted on Apr 07, 2011
Okay my sister had her tablet she turned it on and it froze at the go screen. So I pushed and held down. The power button and it turned off, and then I don't know why I pressed the reset button but it...
Do a factory reset. Remove all power including internal battery. Let the unit discharge completely. Plug into external power supply and try to start up. If it starts. shut down, put the external cord out , replace internal battery, and recharge for an hour. Now try a strat from the internal batter. If it fails, that s the problem.
Feb 03, 2015 | Tablets & eReaders
Wii console went dead... is there a fuse to reset the thing?
Try unplugging all the cords from the wii unit, wait about a minute or so, then reconnect the cords and power up. This should "reset" the system. A similar situation occurred with our system, and this was the solution we were told to try, and it worked. Good luck! :)
Sep 23, 2009 | Nintendo Wii Console
Psc 2210 sounds like the gears just keep grinding then after a bit it stops. says press enter and nothing happens.
perform power cycle
1. Unplug the unit’s power cord from the back of the printer while the printer is 'on'.
2. Hold down the ‘On’ button for 60 seconds
3. Plug the power cord back to the unit while holding the ‘On‘ button down.
4. This will reset the printer’s mechanical systems and discharge all capacitors.
If the issue still persists, then
  1. Unplug the power cord from the wall outlet.
  2. Unplug the power cord from the all-in-one.
  3. Wait 30 seconds, and plug the power cord back into the wall outlet.
  4. Press and hold the # and 6 buttons on the numeric keypad.
  5. While still holding the buttons, plug the power cord back in to the all-in-one. Continue to hold the buttons for two seconds, and then release them.
This should resolve your issue.
Sep 02, 2009 | HP PSC 2210 All-In-One InkJet Printer
Power outage now microwave won't work
Most likely blew internal fuse. Pull the top/side cover off and check the line fuse. It should be behind the control panel in that area.
Nov 08, 2008 | Kenmore 62622 Microwave Oven
Dryer shut off towels were not yet dry, turned dial to restart dryer acts as if it isn't getting power I closed door and pushed start button. Nothing! Checked breakers and power cord at outlet all checked...
Hello mdonettaYou said,
Dryer shut off towels were not yet dry, turned dial to restart dryer acts as if it isn't getting power I closed door and pushed start button. Nothing! Checked breakers and power cord at outlet all checked okay. Any ideas.
yes, try unplugging the power cord or turning off the breaker for 5 minutes. Either will due. Some times the system needs to be reset!
If this does not work there are internal fuses that can be replaced!
Let me know how it goes!
Huuum
Sep 19, 2008 | Dryers
Doesn't turn on, but LED blinks 5 times
The 5 blink code indicates a loss of video. This could be as simple as bad connections on the main board or a couple of defective transistors. In many cases the parts cost is $5-$25. Add in the local labor rate for the total repair cost.
Dan
Jun 13, 2008 | Televison & Video
Samsung Microwave
You may have a blown internal fuse. You''ll need to unplug the unit, remove the outside cover and follow the line cord and you should find the fuse.
Replace it with the EXACT same value that was labeled on the original fuse. You'll probably be able to find a replacement at any Radio Shack store or hardware store.
Replace the cover and plug the unit back in. Hopefully nothing was damaged and the unit will play again.
Please let me know if I can be of further assistance to you.
- Jim
Feb 28, 2008 | Samsung SMH7174BC Microwave Oven
Televison & Video Logo
53 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
