Question about Nuance PaperPort 12 Full Version for PC (780420121188)
Suddenly PPort 12 Pro All In One feature no longer works properly. When I attempt to add an item, the AOI screen flashes anddisappears. When I try and re index the whole file it goes through the proper routine. But then it will not search for a document but asks me to run the full index. Tried to reinstall the program with the same result. Am running Vista 64 bit on a Toshiba laptop. Any suggestions? Thanks.
I inadvertently used a search engine ASK to download some irs files. Now can't get rid of it. It has taken over firefox.
https://support.mozilla.org/en-US/kb/refresh-firefox-reset-add-ons-and-settings
What does the refresh feature do? All of your Firefox settings and personal information are stored in a profile folder. The refresh feature works by creating a new profile folder for you while saving your important data.
Add-ons which are normally stored inside the Firefox profile folder, such as extensions and themes, will be removed. Add-ons stored in other locations, such as plugins, will not be removed but any modified preferences (such as plugins you have disabled) will be reset.
Firefox will save these items:
  • Bookmarks
  • Browsing history
  • Passwords
  • Open windows, tabs and tab groups
  • Cookies
  • Web form auto-fill information
  • Personal dictionary
These items and settings will be removed: Note: Your old Firefox profile will be placed on your desktop in a folder named "Old Firefox Data". If the refresh didn't fix your problem you can restore some of the information not saved by copying files to the new profile that was created. If you don't need this folder any longer, you should delete it as it contains sensitive information.
Feb 24, 2016 | Apple MacBook Pro Laptop Computer with...
I inadvertently downloaded a search engine asK while attempting to access IRS files. Now it has taken over firefox
  • Bookmarks
  • Browsing history
  • Passwords
  • Cookies
The world is upside down, the king has lost his crown, don't laugh please, my monitor screen suddenly got upside down.
Rotating the screen image is a feature of the graphics card and is normally caused by accidentally pressing a combination of keys. To correct it, hold down Ctrl and Alt and press one of the four arrow keys (up, down, left or right) until you have it the correct way up.
As your screen is completely upside down, hold down Ctrl and Alt and press the Up arrow key.
Alternatively, you probably have a Rotation setting in the display properties of the graphics card. You should be able to reach your graphic card settings, but reading and setting them properly may be difficult since everything you see on the screen is upside down until it's fixed.
If all else fails, try restoring the system to an earlier date when the display was right. This will reset the driver to its proper orientation.
Nov 27, 2014 | Samsung SyncMaster 913N 19" LCD Monitor
Touch screen is not working
Hi
Try this
a. Press Windows key + Q.
b. Type Control Panel.
c. Go to Hardware and Sound.
d. Click on Pen and touch.
e. Click the touch tab.
f. Enable use your finger as an input.
Cliff
Aug 23, 2014 | Toshiba Satellite Computers & Internet
Lg inverter 75kg wd1238c problem, after before getting to the spin stage of the wash, it stops and the screens says UE on it and UE is flashing on and off
Error code UE cause : Load is too small, load is out of balance( 1 or 2 large items) solution: Add items to help balance the load, rearrange load to allow proper spinning.... Hope this is useful .....
Sep 18, 2010 | Washing Machines
After 12 years of perfection..I suddenly can't access camera wizard on my computer...Puzzled. (I get a sort of empty box popping up that says EX55) puzzled x
Microsoft updates can make enough changes to the registry that suddenly, our programs or devices no longer work. Use a card reader to download your pics to a folder you create on your desktop.
Apr 17, 2010 | Casio Exilim Pro EX-P600 Digital Camera
USB Flash drive suddenly not recognized in WinXP
Ive included here a link that helped me fix a problem with my flash drive that was giving the same problems. perhaps you could take a look at it.
http://www.hat.net/geeky/node/221
Oct 27, 2008 | Computers & Internet
Sony DSC-T2 lost flash feature
take it to the near service station you circuit belt insde is came out due to vibration or must be fall
Jun 07, 2017 | Sony DSC-T2 Digital Camera
Suddenly, can't sync PDA
When duplicate items are resolved, are they normally dealt with automatically? If so then you could try to do this manually to get an idea of what the problem is.
Oct 02, 2007 | HP iPAQ HX4700 Pocket PC
Nuance PaperPort 12 Full Version for PC (780420121188) Logo
Top Nuance Computers & Internet Experts
tony wahlman
tony wahlman
 Grubhead
Grubhead
Are you a Nuance Computer and Internet Expert? Answer questions, earn points and help others
