Question about Dyson DC14 Bagless Upright Cyclonic Vacuum
I need to replace the Latch that is on the Handle of Dyson DC14 Vacuum that holds the canister in place. Apparently one of the little feet on this part has broken and Dyson will not sell me the part. And when i went to Sears as Dyson told me to do, they were told I would need to buy the entire upper part of the Vacuum which is a joke. I only need a new latch part that I can replace the broken part with using two screws and I am done. Frustrated that I only need a few dollar part on this and not to spend enough to buy a competing vaccum to replace this. This is the fourth part that has broken on this vacuum, and I am about to give up on this.
  • Handie Andie
    Handie Andie Apr 07, 2011
    Hi fantiqua434,
    I agree, you shouldn't have to buy the whole upper part. I'll see what I can find.
    Can you describe the clip more fully? Is it for the dust cup (cyclone) or another clip on the handle?
    Thanks,
    Handie Andie
askdyson
  • 2572 Answers
Official advice and support for Dyson technology
    Verified Fixya Pro
    SOURCE: my vacuum won't turn on
    Hi, Darran from Dyson here. It is possible that the thermal cutout has activated as your machine may have become too warm during use. If you leave it for an hour or two and see if it switches back on then we would recommend checking your filter and checking your machine for a blockage. If you need any further advice, call us on 0800 298 0298 if in the UK or 1-800-MYDYSON if in the US to speak to one of our customer service advisors. Thanks.
    Posted on Apr 15, 2009
    • 134 Answers
    SOURCE: beater bar belt needs replacedon a dyson DC14 animal
    Remove the glide plate at the bottom of rhe machine. Remove brush and broken belt. Fit new belt and re install brush. Fit glide plate, job done.
    Its in the instruction book
    Posted on Mar 08, 2009
    • 61 Answers
    SOURCE: Dyson Animal DC14 brush will not rotate. Removed
    If this model takes a clutch then it is stripped and needs to be replaced.
    danforddan1
    • 192 Answers
    SOURCE: Smells when in use. Have cleaned filter inside red canister, but that didn't help.
    Vac up some carpet freshener this will help get the musty smell out. ,
    Posted on May 06, 2009
    SOURCE: Dyson collecting debris/hair, ect on top of hepa filter?
    Called Dyson today about the cyclone canister clogging in my DC17 Animal. Turns out it's a problem with the black rubber gasket in the bottom of the canister. This also causes the HEPA filter to get lots of dirt and debris on top of it. They are sending me a new Cyclone canister with the corrected gasket. This will prevent anything but small particles of dust from entering the top of the cyclone and the HEPA filter should no longer collect all that stuff. Hope so!
    Posted on Oct 29, 2009
    DC14 arm extension will not lock in place.
    I WOULD CALL DYSON TO BRING IT IN THEY CHECK IT FOR FREE FOR YOU, AND WARRANTY IS USALLY 5 YEARS FROM PURCHASE.
    https://www.dyson.com/support/warrantyterms.aspx
    http://www.dyson.com/support/servicecenters.aspx
    May 25, 2016 | Dyson DC14 All Floors Upright Vacuum...
    DYSON DC14 DUST ON OUTSIDE OF THE CANISTER SEEMS TO BE STATIC DUST BUT WHY IS IT THERE?
    Hi Donna, it's Jack at Dyson.
    As with any vacuum cleaner, it's normal for your Dyson vacuum to generate harmless static in use. You may find this causes small, airborne dust particles to cling to the outer casing of the machine, including the outside of the cleaner bin. This can be easily removed using a soft, dry cloth.
    It sounds as if your DC14 is working as intended, but if you'd like any further advice please call our experts directly on 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
    Mar 23, 2014 | Dyson DC14 Bagless Upright Cyclonic Vacuum
    The clip or latch that holds the Motor Inlet Cover of my Dyson DC14 is broken. Any way to fix this? It appears attached to the large body of the vacuum.
    I'm sorry to hear the catch has broken on your DC14. Our Helpline should be able to assist you in resolving this - please give us a call free on 0800 298 0298 (UK), or 1-866-693-9766 (US). It will help if you have the machine to hand when you call.
    We'll look forward to hearing from you.
    Best wishes,
    Jack
    Dyson Online Customer Support
    Feb 22, 2012 | Dyson DC14 Animal Bagless Upright Cyclonic...
    My dyson dc14 all floors won't stay on when I press the power button. I can hold it down and it will work, but that makes cleaning very slow.
    Quick Fix...takes 4 minutes max
    Remove the switch by using instructions here:
    http://www.sparesaver.com/vacuum-spares/help-and-support/dyson-section/dyson-technical-advice-450/dyson-dc14-technical-advice-474/replacing-the-cable.html
    (The was an additional torx screw 3 " below the one in the directions...yours may have this too...just remove)
    Then...While holding the body of the switch in one hand, use your other to hold both contacts between your thumb and forefinger and gently place pressure on each contact in the opposite direction, just like screwing a nut onto a bolt. Press the switch down while applying this torque and see if it sticks. If it does just bend the contacts slightly and continue pressing the switch to ensure it holds. Reinstall switch.
    I still advise buying a switch from amazon for $4.00 and replacing it but this will help you to continue to use your vacuum in the meantime without having to hold the button...
    Aug 11, 2011 | Dyson DC14 Telescope Reach All Floors...
    Im having issues with my dyson animal. when i put my foot on the cleaner head to try to release the handle to start vacuuming it doesnt release. like its stuck in the upright position. makes vacuum useless
    Sorry to hear you're having a problem with your DC14 Animal. You should find the cleaner reclines freely into the vacuuming position when you place a foot on the cleaner head, and lower the handle. If it's not doing this, please get in touch with us free on 08002980298 (UK), or 1866MYDYSON (US), so we can provide the assistance you need.
    Kind regards,
    Jack
    Dyson Customer Service
    Jul 24, 2011 | Dyson DC14 Animal Bagless Upright Cyclonic...
    Have a DC25, I can not return the handle to the upright position. Nothing appears to be broken
    Occasionally, customers have problems locking their Dyson vacuum in the upright position. This is a minor problem common with the Dyson DC07 and DC14 series and can easily be fixed by the customer. This page will show how to fix this problem. Although we show a Dyson DC14 Animal on this page, these instructions will work on any Dyson vacuum in the DC07 and DC14 series.
    During shipping, moving parts on a Dyson vacuum can shift in position. One of these parts is a swinging arm in the base of the unit. This arm holds a removable elbow pipe in the vacuum's air passage. This arm can move out of the way so that you can clear out a blockage in the air passage. When this arm is out of position, the vacuum will not lock in the upright position. Fig. 1 Shows the base of a Dyson DC14 Animal locked upright. The red arrow points to the swinging arm. Fig. 2 shows the vacuum with the swing arm out of position. Since the swing arm is lower than it should be, it doesn't line up with the tab on the main body indicated by the red arrow.
    Lean the handle of your Dyson all the way back and locate the black button on the right side of the vacuum indicated by the red arrow in Fig. 3.. Press the button down and hold it to unlock the swing arm.
    While holding down the black button, pull the swinging arm (Shaded red in Fig. 4) all the way up. Fig. 5 shows the swinging arm in the correct position. Release the black button to lock the swing arm back in place.
    The vacuum can now lock in the upright position as shown in Fig. 6. Note how the tab on the swinging arm overlaps the tab on the main body..
    dcramer531_17.jpgdcramer531_18.jpgdcramer531_19.jpgdcramer531_20.jpgdcramer531_21.jpgdcramer531_22.jpg
    Dec 11, 2010 | Dyson DC25 All Floors Bagless Upright...
    Our Animal DC14 hose unraveled, can we replace it?
    Yes you can replace the hose youself. First buy the hose (through Dyson directly or google to see a list of online retailers). All you'd need to do is to unhook the hose from the bottom - you'll remove the canister/dirt bin and push the lower cord hook/cup off the back of the machine from the front and simply click the new hose into place.
    Jun 07, 2009 | Dyson DC14 All floors Bagless Upright...
    Canister problem
    If it won't latch after cleaning the latch and making sure that everything is seated well, get in touch with Dyson, they're great about making things right with their vacuums.
    Sep 18, 2007 | Dyson DC07 Animal Bagless Upright Cyclonic...
    Emptying cylinder
    I hope you've found out by now, but, in case you haven't, the latch to remove the canister is right by the handle on top of it, just don't lift until you release the latch with your thumb, it's got a safety to keep you from hitting the release when you're using that handle to carry the vacuum.  (good engineering).
    you can download a manual from the dyson site, here:
    http://www.dyson.com/customercare/manuals/us/dc07_opmanual_usa.pdf
    Aug 14, 2007 | Dyson DC07 Bagless Upright Cyclonic Vacuum
    Dyson DC14 Bagless Upright Cyclonic Vacuum Logo
    95 people viewed this question
    Top Dyson Vacuums Experts
    AskDyson
    AskDyson
    Samyfam
    Samyfam
    Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
