1979 twinstar,runs good, why won't horn work?
  • 6,993 Answers
your horn is not working because;
1. The horn might be defective and needs to be replaced.
2. The horn wire/cord might have been disconnected
If you find the wire being disconnected, reconnect it and the horn should work. But if the wire is intact, remove the horn, connect it to a 4 AA battery and observe if it will make any noise in order to confirm if the horn is defective or not. If the horn does not make any sound, then it means you have to replace the horn.
So, check any of the two above mentioned as one has to be the cause of the problem.
Good luck.
Posted on Apr 07, 2011
After i took out the batterie to take off carbs to clean them the starter wont work or the horn
Hi, Chuck and the usual suspects are:
1. Ignition Switch not in the "ON" position.
2. Engine Run Switch in the "OFF" position.
3. Discharged battery, needs to be 12.5 volts or better and be able to pass a load test if necessary, check battery terminals for damage or corrosion, check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
4. Bank angle sensor tripped and ignition/light key switch not cycled to the "OFF" position and then back to the "ON" position.
5. Faulty starter button/switch.
6. Faulty kickstand or clutch pull in switch/sensor.
7. Security alarm needs a reset.
8. Starter control circuit, relay, or solenoid faulty.
9. Main fuse or circuit breaker may be blown or faulty.
10. Electric starter shaft pinion gear is not engaging or over-running starter clutch slipping.
For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have nice a day.
http://www.thegsresources.com/_forum/showthread.php?231947-GS750-won-t-turn-over-battery-is-charged-Nothing-from-starter-button-or-kick/page3
http://www.xs11.com/forum/showthread.php?t=41364
Suzuki 83 GS750ES Power Problem Help please
SUZUKI GS750 GS750E MOTORCYCLE SERVICE REPAIR MANUAL 1976 1977 1978 1979...
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
May 18, 2016 | 1979 Suzuki GS 750 E
Need to know the location of horn in a 1979 vw super beetle
Hi Paul:
If the horn works, have someone push the horn button. Then you get to follow the sound.
HINT - Horns are usually located at the front of the vehicle, behind a grille or bumper.
Sep 09, 2015 | Cars & Trucks
What is the horn relay location for 1979 trans am?
The dual horns are located between the radiator and engine...the horn button controls the circuit...you must remove the steering wheel to gain access to the horn button spring assembly...pre-air bag so not a big deal to remove the steering wheel on your 79 T/A...hope this helps.
Aug 25, 2014 | 1979 Pontiac Firebird
Horn wont work in 1979 chevy van
either horn button in steering wheel is broke horn is bad or horn relay is shot, but check the simplest first see if the wire came off the horn or the wire may have broke off.
Jul 28, 2013 | Cars & Trucks
1980 Honda Twinstar CM 200 won't shift
Hi, Anonymous and the usual suspects are:
1. Clutch not disengaging.
2. Bent shift shaft.
3. Shift fork bent or seized.
4. Gear seized on the shaft.
5. Gear positioning lever binding.
6. Shift return springs weak or broken.
7. Shift return spring pin loose
8. Shift mechanism arm spring is broken.
9. Shift mechanism arm is broken.
10. Shift drum is broken.
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
81 Honda cm200 oil clutch problem
1980 Honda CM200 Transmission Issues
CLYMER SERVICE REPAIR MANUAL HONDA TWINSTAR CM185T 1978 1979 CM200T 1980... $34
https://www.partsfish.com/page/oem-parts-for-honda
http://mybikemanuals.com/honda
Jul 02, 2012 | Honda Motorcycles
Honda CM200T Twinstar remove the seat
Hi, David for this scenario you will need your service manual, parts fiche, and owners manual if you can't find the best tool you ever bought for your Honda, despair not, for a mere zero $0 you can download another one.
Honda CM200T Twinstar remove the seat Google Search
How do take off the seat
Honda TWINSTAR 250 Service Repair Maintenance
Jun 24, 2012 | Honda Motorcycles
My horn won't work. I've replaced the fuse and the relay. The steering wheel clicks. So what do I do next?
if the steering wheel clicks when you push on the horn then the wiring from the horn pad out to the horn is good.if it clicked before you replaced the parts then you didn`t have to replace them.check the horn at the horn,with someone pushing on the horn pad tap the horn to see if it will try to work if so then the horn needs to be replaced if not then run a power wire from the battery positive to the connector at the horn if the horn works again the horn needs replacing.
Aug 09, 2011 | 2006 Ford Focus
Where is my horn relay located in my 92 olds cutlas cruiser ?
have you checked the fuse for the horn you don`t say what you have done to this point,if the fuse is good and you hear a click when you push on the horn button, then the horn relay is good as that is what is clicking,if not you will have to check the horn itself as some relays won`t work if the horn not itself is not working,by running a jumper wire from the battery positive to the terminal on the horn, it should work if not then the horn is the problem.the relay is on the fuse panel under the dash.I think it is a square sided relay
Mar 10, 2011 | 1992 Oldsmobile Cutlass Ciera
Need wiring diagram for a 1979 yamaha xs750 special, where all the wires go into the headlight that run horn,blinkers and headlight
G'Day mate
Check out this site to find the exact model of your bike from the VIN here. You can get a wiring diagram for your model from the Biker.net website. There is usually a mess in the headlight tub, lots of dodgy previous owner "fixes". Sometimes it pays to strip it all out and work your way through it. Happy to give you advice on the electrics of this bike. I have plenty of experience:)
regards robotek
Apr 07, 2010 | 1978 Yamaha XS 650 SE
71 sportster stops running
sounds like a ground problem. make a jumper wire and hook one end to the ng side of bat. the other to a good metal prt of engine. if this cures the prob start chasing down your ground wire making sure all connectsions are clean and tight
Sep 07, 2009 | 1979 Harley Davidson XLS 1000
Televison & Video Logo
32 people viewed this question
Top Televison & Video Experts
