Question about Panasonic RQ-CR07V Personal Cassette Player
The unit does not turn on when I press the band button, A key shows in the window. I do not remember how to remove the key. I do not remember entering a key. How do I remove please?
  • lincolnr Apr 11, 2011
    Yes your solution worked. I tried to email you the same time but it failed.
    Much appreciated.
    Regards
    Lincoln
  • 1,591 Answers
Your keypad is in a locked state. The fix is easy enough.
I will also give a link to the manual
the lower right hand button is marked HOLD
Press and hold this button til the key disappears
The unit is now unlocked.
manual is here
http://www.generalmanual.com/Players/Panasonic-RQ-CR07V-Portable-Radio-Cassette-Player.htm
Click "Operating Instructions" on that page.
Thank you for choosing FixYa.
Posted on Apr 07, 2011
  • Norman Skinner
    Norman Skinner Apr 11, 2011
    You're welcome. Thank you for choosing FixYa.
How can I boot from cd by pressing a button
as sonn as you turn on your unit continuously press F12 before the windows logo shows. this will take you to bios where you can change boot options. Make your cd/dvd/ the first pop in disk save settings and exit unit will reboot then tell you to press a key to boot from disk you only have about 3 seconds before pc boots normally
May 09, 2014 | Dell OptiPlex GX150 PC Desktop
Auto shut off of monitor
Instructions for Windows XP
  1. Go to your desktop. Remember to minimize all applications or show only your desktop by pressing the "Win Key + D" combination on your keyboard.
  2. Right-click on your desktop.
  3. Choose the "Properties" option.
  4. Switch to the "Screen Saver" tab.
  5. Click on the "Power" button, and switch to the "Power Schemas" tab.
  6. The default is the "Home/Office" schema. Leave it like this.
  7. In the "Turn Off Monitor" dropdown, choose the desired time and click the "OK" button.
Instructions for Windows Vista and Windows
  3. Choose "Personalize."
  4. Click on the "Screen Saver" icon.
  5. Click on the "Change power settings" link.
  6. Click on "Choose when to turn off the display" in the left pane.
  7. In the "Turn off the display" dropdown, choose the desired time and click the "Save changes" button.
  8. Close the window.
Oct 18, 2013 | HP Pavilion Computers & Internet
Danfoss rx1 thermostat shows 'of' ?
Remove batteries from room stat,turn off the electrical supply to reciever unit.
Turn back on the electric to reciever unit,the red light should be on,press the top "manual" button,the green light should come on and boiler should fire (assuming the programmer is in an "on" period)
Press the bottom button,and keep it pressed,then press the top button until the green light flashes,stand about 6 feet away,and refit the batteries to the stat while observing the reciever unit,either the red or green light (cant remember which) should flash to show the 2 units are syncronised.
Another basic test if all seems ok,when turning the stat up or down,when the green light on the reciever unit comes on or goes off,its usually accompanied by an audible "click" ive found,that if this is not happening, the reciever unit does not switch either on or off,may be intermittant.
Replacement is the only cure.
garden led light
Jun 04, 2012 | Garden
Just bought from store press reset button it lights up but does not display after or start
Make sure the safety key is inserted this engages the power up sequence for the unit to start operating. Also as a simple test try to get the unit into calibration mode by pressing the stop and speed up buttons at the same time while inserting the safety key Press the Stop key one time. The Time window should read EP:2P. Some newer models may also say FP, Pass, or the like. This means that it passes the EPROM test. Press either incline key and the incline will calibrate automatically. BE CAREFUL, THE TREADMILL WILL RUN AT FULL SPEED IN THIS NEXT MODE! DO NOT STAND ON THE WALKING BELT. Press the Speed Up key and hold it down until 85 is shown in the Distance window (some models may show the 85 number in another window). After completing calibration of the speed, press the Speed Down key. The treadmill will automatically return to 0 MPH. Please allow the unit to stop completely before continuing. Press the Stop key once and remove the safety key.
If either attempts fail then call the store where you purchased the treadmill, either have them send a service tech out or exchange theunit.
Jun 26, 2010 | Weslo Cadence Ct 5.8 Treadmill
What buttons change time display
How do I set the clock?
A5
There are several methods to set the clock, depending on the model.
Method 1
Press and hold the BAND and DISPLAY buttons to display the clock
Press and hold the BAND and DISPLAY buttons until the time display flashes
SEARCH left to adjust the hours; right to adjust the minutes
Press BAND button to store the time
Method 2
Same as Method 1, except press DISP to store the time
Method 3
Press ADJ
SEARCH left or right to select clock and press ENT
SEARCH left or right to select the hour or minute
Turn rotary knob clockwise or counter-clockwise to set the correct time
Press enter to store the time
Press ADJ to return to the previous mode
Method 4
Press and hold the BAND and FUNCTION buttons to display the clock
Press and hold the BAND and FUNCTION buttons until the display flashes
Search left to adjust hours; right to adjust minutes
Method 5
While the display is showing the clock, press and hold the CLOCK knob until the minutes flash
Press the CLOCK knob to adjust the minutes
When the CLOCK knob is released for 5 seconds, the hours will flash
Press the CLOCK knob to adjust the hours
When the CLOCK knob is released for 5 seconds, the time will be stored
A5
Method 1
Method 2
Method 3
Press ADJ
Method 4
Method 5
A5
Method 1
Method 2
Method 3
Press ADJ
Method 4
Method 5
A5
Method 1
Method 2
Method 3
Press ADJ
Method 4
Method 5
A5
Method 1
Method 2
Method 3
Press ADJ
Method 4
Method 5
go to this web site for any thing about ur stereo
http://www.clarion.com/us/en/support/faq/Audio/index.html
Feb 18, 2010 | Clarion Car Audio & Video
Aux port
Turn off Radio with car on or key on. Press and hold the big volume button in for 3 seconds, and the radio will say initialise. Than press the FCN button till it says AUX. Than press the SEL button till it says "Aux ON ". Turn on radio and you should be good to go.
Aug 29, 2008 | Pioneer DEH-P4800MP CD Player
Iam having problem with my mobile n72
you can do a soft format by pressing *#7370#.
or you can hard format your phone by following these steps. Remove your memory card, Turn off ur mobile, then press green key(answer key), 3, *(star) at same time and then turn it on, keep presing the buttons till format is complete. all your data in phone memory will be removed.
Remember to back up your data before format
May 17, 2008 | Nokia N72 Cellular Phone
ADX5355 clock
you just have to turn the power on, push the display button so the time is showing on the display. (The only buttons involved are the "BAND" button, the number 4 roulette button which is the top right station preset button and the "DISPLAY" button.) I think you push and hold the BAND button and while holding it push the number 4 roulette button. (you don't have to hold it for any specific time you just have to push BAND in when you push the number 4 roulette button.) the time will flash and you use the vol/seek knob to adjust the time. When done push the BAND button again.
=> This really work, thanks!
Dec 23, 2007 | Clarion ADX5355
Panasonic RQ-CR07V Personal Cassette Player Logo
287 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
