Question about Hitachi PJ-TX10 Multimedia Projector
Just purchased a used PJ-TX10 Multimedia Projector. It came with ceiling mount. Took ceiling mount off. Projected picture is still upside down. how do I get it rightside up? Thanks.
    Genius:
  • 1,447 Answers
Hi!
Go to this site to check Manual Online. Click HERE.
Hope this helps.
Posted on Apr 07, 2011
Upside down picture on Vivitek D530
Hello
Check the Projection setting on the Installation I menu of the OSD
Feb 11, 2012 | Vivitek D530 Projector
I have a Panasonic PT-LM2U; when it is turned on, everything powers up fine but the image projected is upside down. I've looked through the menu but didn't see an option for flipping or rotating...
Every modern projector that I have seen has a setting that will allow you to flip the image for this.If you purchased it used it was probably configured as a ceiling mount in an upside down orientation or rear projection onto a translucent screen. (The projection method can be set from the "OPTION2" menu. in a Model LM1 so it should be similar. http://service.us.panasonic.com/OPERMANPDF/PTLM1U.PDF
If yours doesn't have this option, then you'll have to use mounts that require the projector to be upside down.
Jul 18, 2011 | Panasonic PT-LM2U Multimedia Projector
Where is the air filter on the Hitachi pj-tx10? I dont know how it looks?
it's on the right hand side of the projector when you are looking at the projector from the front. The plastic grille just unclips and the filter is inside.
Mar 30, 2011 | Hitachi PJ-TX10 Multimedia Projector
Upside down picture
turn the projector up the other way,
or
Press the Menu button.
Select the Advanced menu. You see the features and their settings on the right side:
Press Enter and use the directional buttons and the Enter button to set the following option:
Projection
Front: Projector is in front of the screen
Front/Ceiling: Projector is in front of the screen, mounted upside-down from the ceiling
Rear: Projector is behind the screen
Rear/Ceiling: Projector is behind the screen, mounted upside-down from the ceiling
Feb 22, 2011 | Epson EMP-54 Multimedia Projector
Can the Optoma EP739 be ceiling mounted and projected upside down? what are the steps to do so? also, what would be the best mount for said projector?
Mine has been in place for about three years. Because the ceiling was open I was able to create a connection for a tripod head on the ceiling and then using a STRONG tripod head and some small bolts (longer than the originals) I mounted an external base and with the tripod head fitting dttached to the projector it just became a matter of running the various connector cables from the sources I use that require projection to my wall.
Dec 02, 2010 | Optoma EP739 Multimedia Projector
When we turned it on the picture was upside down. what do we do?
somehow you managed to change the orientation of the projected image. You do not mention if your projector is ceiling mounted or front. If select menu item + front or menu item + ceiling front. one of those two should help you
Jun 13, 2010 | SharpVision® XV-Z3100 DLP Projector
Hitachi PJ-TX10 alligment
i have one of these projectors found on setting it up that the projector must be square on with the screen, the pjtx10 doesn't have ant "wedge type" setting like sony does. if this doesn't fix problem there is some thing not aligned in the lense
Mar 04, 2008 | Hitachi PJ-TX10 Multimedia Projector
Angle of projected image
Hi there
No this can not be changed , the PB6100 was actually designed to mounted upside down in your ceiling and therefore the lens is 28-30 degrees upwards when projected on a flat surface.
Flip it upside down and you'll see what I'm getting at.
Oct 07, 2007 | BenQ PB6100 Multimedia Projector
Picture become reversed
In the menu functions there is a place you can change the way the image is projected on the screen. If the projector is mounted in the ceiling you need to change it to front/ceiling, but if you scroll through the options you should be able to find the one that will work for you.
Oct 03, 2007 | Epson PowerLite 8100i Multimedia Projector
Hitachi PJ-TX10 Multimedia Projector Logo
124 people viewed this question
Top Hitachi Office Equipment & Supplies Experts
jasbo
jasbo
Chris Goulet
Are you a Hitachi Office Equipment and Supply Expert? Answer questions, earn points and help others
