Question about Dishwashers
I have a dishlex dx203wk dishwasher it is not heating, they said the board was faulty,i replaced the board but still wont heat. any suggestions all other functions are normal thanking you, allan
2 Suggested Answers
  • 3247 Answers
SOURCE: I have a Dishlex DX203WK
The thermostat could be faulty and therefore turning the heater off earlier then the desired cutoff.
Do you use cold water connection or hot? some dishwashers expect the inlet temperature to be within a range?
I will check out the specs for your model and come back to you later.
Posted on Oct 01, 2010
What would make my dishlex dishwasher display the error code i60?It runs the wash cycle and stops.
Heating time out. Usually is heting element defective or relay on main board.
Dado
Sep 03, 2014 | Electrolux Dishwashers
DISHLEX DX302 REPLACE HEATING ELEMENT
Remove the device and then restart again
Jan 25, 2014 | Dishwashers
Not drying
no heat? test element and circuit from control board.
If Dishlex DX103 etc, resolder relay onto board and get quote on new control board.
Oct 17, 2013 | Dishwashers
Dishlex dx302 not drying dishes. Doesn't seem to be as hot as usual when opened immediately after finished. Steam not present.
Check your heating element..
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The
Heating Element not Working
How to Replace the Dishwasher Heating Element
Dishwasher Maintenance
heatman101
Asker's Testimonial " explanation very clear. will give it a go and see how simple it was. thanks Ronnie " - ronnieshomes
Mar 04, 2011 | Dishwashers
Water wont heat on my dx 308 stailess dishlex. its ellectronic. is there a reset or does the heater ellement need replacing? cheers
Unplug your dishwasher,then remove the front upper control panel.You will see a series of plugs.Note where they all come from and carefully disconnect.On the circuit board you might find a track melted off.Solder a small wire across the 2 joints.See how that goes.
Dec 27, 2010 | Dishwashers
No drying cycle on the electrolux dishlex 302 any idea's
Dishwasher Problems The Heating Element not Working
heatman101
Asker's Testimonial " explanation very clear. will give it a go and seehow simple it was. thanks Ronnie " - ronnieshomes
Nov 10, 2010 | Electrolux 18 in. ESL4114 Slim-Line...
Idl350 dishwasher fitted a new element but it wont heat the water
check the safety thernostat under the tube you gain axcess to it by removing the lowest panel they are small and round with 2 wires to each shut off power b4 you check by ohms if good
Sep 01, 2009 | Dishwashers
I have a dx302. its not heating the water or drying.
My six year old Electolux Dishlex DX 403 dishwasher stopped heating the water. I found comments on the internet about burnt out solder joints in the control box. A friend opened the control box and found a blackened area on the back of the circuit board. Once the connection was re-soldered the water heated again. We also found that quite a few wires leading to the control box had overheated and the insulation had melted. Considering that this dishwasher was the top model from Electrolux at the time, I was not impressed. I had previously had a Vulcan Dishlex for almost 20 years.
Thanks to those people who previously posted information about this fault.
Feb 10, 2008 | Electrolux 24 in. EDW5505EPS Stainless...
Dishlex dx 302 heat drying
Found I had no hot water in my Dishlex DX302 and did a google search and found this page.
My problem was found to be the same as the others; one of the solder joints on the relay on the control board had arced off.
You could see the burn mark on the board and cover where it had been arcing.
Soldered it back together, and now it seems to be going good again.
Now my only problem is a damaged door seal, which means a small water leak; I have used part of a rubber glove to bridge the gap, and it reduces the water leak.
Sep 22, 2007 | Dishwashers
Dishwashers Logo
43 people viewed this question
Top Dishwashers Experts
