Question about Sport & Outdoor - Others
Model 36276.1. I can't figure out what to stick the poles into in the corners? Can you send me the instructions? waldhorn@sbcglobal.net
  • 5 Answers
SOURCE: change message on ge model 29875ge1-b.....lost manual
hold down the greetings button and speak when it beeps
Posted on Mar 28, 2008
pgh_pa_guy
  • 2992 Answers
SOURCE: west bend model 84386
Here is a link to the manufacturer for replacement parts for the 4-quart cooker:
http://www.focuselectrics.com/catalog.cfm?dest=itempg&itemid=802&secid=54&linkon=category&linkid=101
You can download a copy of the copy of the instructions on that page.
Posted on Nov 27, 2008
thetaocat
  • 122 Answers
SOURCE: can't send email to sbcglobal.net address
AddressGuard is another powerful line of defense against spam:
  • Create disposable email addresses in a snap
  • Give them out when you don't want to give out your primary Yahoo! Mail address
  • Have messages delivered to your Inbox or a personal folder
  • Simply delete them if they start receiving spam
If the email receipiant has reported you as spam that is why you can't get through
you will have to call the receipiant and ask them to remove you from their spam list
Posted on May 04, 2009
SOURCE: I can't send my emails,because the message says
If you are using outlook, go to Tools > Account Settings > under your email address, highlight it and click Change. Then change your email address to scajaeger12@sbcglobal.net and make sure the POP3 & SMTP settings are correct. Click More Settings, then click Outgoing Server. Then check the box that says My Outgoing Server Requires Authentication. Then click Use the same settings as the incoming mail server. Click Apply & Ok. Close & reopen Outlook then check if it is Ok.
Posted on Sep 29, 2010
  • 707 Answers
SOURCE: My computer is sending out
that's one through yahoo servers not your computer. you can search for sbglobal files and maybe find and delete them but won't stop yahoo.
Go into yahoo where you created the account and manage it through settings
hope it helps
Posted on Nov 19, 2010
How do you set it up
Check your manual, or look for instructions online, but the basic plan is...
1. Lay it out so the door faces where you want it.
2. Stake down the corners, yes- even if it is 'free-standing' you usually want to do this.
3. Figure out where the poles go. They usually go through cloth sleeves, or metal rings, or clips or something. They also go in arcs that may or may not cross at the top. (a manual REALLY helps with this!)
4. Slide a pole in place. if it goes through a sleeve, you usually slide it in first, then stick the ends of the poles on little metal studs at the corners. If it clips on, you usually build the pole, then run it from stud to stud, then clip the tent to the arch you made.
5. Repeat for all poles
6. Pull the rain fly in place, clip on at each pole end and as needed.
7. Pull out and stake other ties as available. This gives you more interior room, more stability and protection in weather, and improves ventilation.
May 30, 2014 | ACADEMY BROADWAY CORP Camping, Backpacking...
I have a disney princess tent that goes over a twin bed and i lost the instructions to putting it together and i need help.
  • 1
    Remove the tent and poles from the packaging. Select an indoor area with a high ceiling or an outdoor area without overhead obstacles. The poles are not excessively long but they will be difficult to assemble without space.
  • 2
    Lay the Princess tent with the floor on the ground. Pull on each corner to tighten the floor. Assemble the two tent poles by inserting the male sections into the metal ferrules.
  • 3
    Slide one pole through each of the diagonal sleeves. Place the end of each pole in the fabric pockets on the corners. This will flex the poles and raise the tent body.
  • 4
    Place the fabric roof on top of the tent. Attach the hooks on each corner of the roof to the loops on the top of the pole sleeves. The roof fabric will stretch tight and cover the ventilation gap in the tent ceiling.
  • Apr 22, 2011 | Toys
    I purchased the toy story bed tent for my daughter and misplaced the instructions on how to put it together so if you could provide me with this I would really appreciate it
    there are four pockets on the inside of the tent which hold the ends of the pole with the string in them. connect all the poles with the string in them. bend it in a (n) shape and stick the ends in the pockets. the poles are bent so as to give the tent height not depth, do the same for the rear of the tent. the twelve other poles are connected using the small connectors. one connector for two poles then stick those poles into the front and rear (n) shaped poles in the empty connector spaces already on the pole you bent. remember when you bend the pole they will not stay bent until you stick them into the inside pockets in the tent. the nylon straps at the bottom of the tent help the tent to hold on to the mattress. its simple enjoy. i put all the poles together first and then had my helper to hold it in a (n) shape until i could stick the legs into the pockets. look inside the tent once together you will see where you need to tie the nylon straps to the poles
    Jan 08, 2011 | Disney Toy Story Indoor Bed Tent With Push...
    I got the tent but no instrutions with it.
    first lay it out on the ground put the pegs in 4 corners & centre then place the ropes and peg them into the ground about 3ft from tent then place the poles through the eyes of the tent erect the poles centre ones first stand the poles up then it should be upright from there just continue to add poles and ropes adjusting it during this procedure
    hope this helps
    Sep 13, 2010 | Computers & Internet
    Hello. I have a disney princess bed tent that my daughter recieved for christmas. We went to go and set it up and the instructions are missing. Is it possible to get a copy faxed/emailed to me?
    I just put one of these up today with no instructions so I am going to share my experience. In my Disney bed tent there were two long sets of poles held together by an elastic string. 1) put these two sets of poles together. Now you should have two long poles. 2) Turn the three way brackets all the same direction on both long poles. 3) Lay out the tent and look in each corner of the tent for a little pocket to insert the end of a long pole...taking the other end insert into pocket, not diagonally, straight across the long way. 4) Do the same with the other side of the tent and long pole. 5) Now take your ten short poles and attach two together making 5 medium sized poles 6) Push these into the brackets along the long pole, kind of has a ladder effect. You are done!! I use mine with a full size blow up bed, the elastic gets stretched but I can set it up easily outside, or in the livingroom. Enjoy Nancy
    May 19, 2010 | Toys
    I'm receiving error messages, as I have changed e-mail addresses. How do I correct by dropping highdesertrats@sbcglobal.net, and changing it to highdesertrats@charter.net?
    if you are referring about outlook..you have to change the email address and password by making a new net passport into outlook
    Aug 17, 2009 | Computers & Internet
    Can't figure out how to put the poles in the tent to set it up
    Well, without a brand and year, it will be hard to figure out exactly. Here are some basics.
    First thing, peg the tent down. (At leat the corners)
    Next, locate the two longest poles. These are usually fit through a sleeve in the roof of the tent and attached in the corners via pegs or inserted into a pin. Put one corner in, then go to the other side and slide/bend the pole until it fits into the corner. Let it flop on the ground. Do the same for the other corner and the tent should be standing.
    Next, if there are other poles, they could be for the front entrance or to support the rain guard. Look for peg holes or pins to place the poles into and that should give you an idea. (Also look up your model on the internet to give you an idea how it looks.)
    Depending on where you are camping, you may not need the rain cover. It goes over the top and probably bungies into the peg holes.
    Hopefully this will get you started. good luck. Alley
    Aug 01, 2009 | Remington Sport & Outdoor - Others
    How do i set up a wenzel monarch tent
    If you have the model number (which is sown on a label inside the door flap) you can e-mail Wentzel as I have done and they will send you the set-up instructions. Or email me at bobz1011@sbcglobal.net and I will send you the attachment I recieved.
    Aug 24, 2008 | Wenzel Swiss Gear Grand Lodge Cabin Dome...
    Sport & Outdoor - Others Logo
    Top Sport & Outdoor - Others Experts
    Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
