Question about Mastercool 67471 Evaporative Cooler Air Conditioner
How do you replace the mastercool pads? Or how do you remove the mastercool pads?
3 Suggested Answers
SOURCE: replacing pads
we purchased a swamp cooler 4 years ago. The first couple of years it worked great. Now for some reason we can not get cold air coming trough. We can't find the manual for the machine. It is a Mastercool swamp cooler and was pretty expensive. I know if properly operated it should cool the house within 10 min. We need to run this all summer. My brother in law says we dont know how to operate the thermostate. ? Any suggestion would be greatly appreciated.
Posted on Jun 30, 2008
How do I replace a rigid pad on my Mastercool swamp cooler?
Posted on Jun 14, 2010
Mastercool doesn't seem to be getting enough water circulating
If the pads are old replace them. Take a panel off and look at the water dist. tubes if plugged, best method to remove it and use compressed air blow from the center, and let it rip, the basket maybe dirty. Good luck
Jul 02, 2011 | Mastercool 67471 Evaporative Cooler Air...
How to remove algae from master cool pad
It seems like your pad needs replacing if you have a build up of algae
There is no way to wash out the pad properly without destroying it
You have to be careful with cleaners as you will be breathing the residue later
Jun 10, 2011 | Mastercool 67680 Evaporative Cooler Air...
PLEASE TELL ME WHAT DOES A MASTERCOOL CLEAN MACHINE PURGE PUMP DO?
From the ad below, it replaces old water with fresh. ------------------------------------------------------------------------- » HVACR» Air Conditioners» Evaporative Cooler Accessories Universal Cooler Cleaning SystemBrand: MastercoolModel: CM120ASKU: 47495 34252_300.jpg
$74.13
3 Business Day Shipping $7.91
No Longer Available Mastercool CM120A Universal Cooler Cleaning SystemTotal Ratings: 0
Average Rating: 0
Review this item transparent.gif Product Information Item Cleaning System Function Timer-actuated, Automatically Removes Mineral-laden, Dirty Water every Six Hours and Replaces with Fresh Water, Reduces Scale Deposits and Leaves Pads Cleaner, Saves Up to 70 Percentage of the Water Weight 3.10
  • Replacement Motors and Accessories
  • Universal Cooler Accessories
  • Cleaning System
  • Save up to 70% of the water used in bleed-off cleaning systems.
  • Timer-actuated drain system automatically removes mineral-laden, dirty water every six hours and replaces with fresh water.
  • Reduces scale deposits and leaves pads cleaner.
  • Uses: For residential size coolers only.
  • Note: Limited availability.
Universal Cooler Cleaning System, Clean Machine Pump Cooler Flushing Device for Residential Size Coolers Only
Apr 04, 2011 | Heating & Cooling
How to remove pad
I am assuming that the pad you are talking about is the concrete pad? if it is I am hoping that you are just replacing it with a newer one. You will have to lift the unit up by all four corners, you can use the red bricks(or concrete), and angle iron(under the unit going to the bricks you spaced away from pad) once it is up enough you can remove pad. Hope This Helped Tim
Oct 23, 2010 | Mastercool 67680 Evaporative Cooler Air...
I am a single woman trying to prepare my mastercool for winter. I don't know how to remove the pads, so if insructions could be sent, it would be greatly appreciated. I don't know the size of the cooler,...
Is it a side draft or downdraft cooler? My instructions simply say to cover the unit, disconnect the power and drain the water for winter. They don't suggest removing or cleaning the pads until spring. If you're ductwork also is connected to your furnace, and you don't have a cookie sheet(piece of sheet metal that fits in a slot beneath mastercool unit or along the inside if it's a side draft cooler) then besides covering the entire unit you cn probably cover the blower, also called the squirrel cage, with a canvas cover.
Oct 09, 2010 | Mastercool 67680 Evaporative Cooler Air...
Need replacement pads for mastercool mrc55wa evaporative cooler
These pads are available in different sizes and styles at home improvement stores like LOWES or HOME DEPOT (in season)
Sep 18, 2009 | Mastercool 67471 Evaporative Cooler Air...
Replacing pads
May 22, 2008 | Mastercool 67680 Evaporative Cooler Air...
Summer
If it was not drained for winter, do so and then remove all scale from the pan, pump inlet screen, etc. Replace the pads if they are scaled up and remove any scale from the louvered panels. WITH THE POWER OFF, check the belt for cracking and check to drive motor and blower wheel bearings for smooth operation, oil bearings with oil ports. With clean water in the sump, a good drive belt, clean pump screen and clean pads, the unit is ready to power up and run test the float action/shut-off, water distribution through the arms, belt tension (just enough to prevent slipping). These units work best when they can fully evaporate the water, so let the air flow out as fast as it come into the cooled space to maximize the evaporative effect. Also note, these unit must be level to work properly.
Apr 27, 2008 | Mastercool 67680 Evaporative Cooler Air...
Mastercool 67471 Evaporative Cooler Air Conditioner Logo
422 people viewed this question
Top Mastercool Heating & Cooling Experts
Bill Long
Dan Webster
Dan Webster
Boyet Soriano
Boyet Soriano
Are you a Mastercool Heating and Cooling Expert? Answer questions, earn points and help others
