Question about Alpine CDA-9815 CD Player
Why does my alpine 9851 head unit say interrupt to hook up my sub woofer
3 Suggested Answers
ampman
  • 98 Answers
SOURCE: how to install an alpine cda 9851
you go to a stereo shop..(walmart autozone etc should also do) buy a mounting kit and a wire harness adapter. The wire colors on the adapter match the wire colors of most aftermarket decks. MAtch the wire colors and connect...make sure to tape wires well as if they touch you rick damage to your deck.. install the mount kit plug in your cd player and slide it in and you are good to go..
Posted on Aug 21, 2007
  • 82 Answers
SOURCE: hooking up alpine hd radio unit, bt-400, which one do i hook ipod to
Niether .... do you know what you have in hand? Both those extras costed someone some cash ... OK here it is: the CDA-9884 has a dedicated input for ipod (a KCE-422i cable is needed and comes with the new CDA-9884 in the box) ... The HD radio unit allows you to recieve new HD radio signals (digital radio, and stations that have it in your area may also have extra music streams like HD TV does). The bt-400 is a bluetooth adapter to use bluetooth enabled devices with such as a cell phone. If your ipod has bluetooth you could used the bt adapter but I suggest the KCE-422i cable instead, and check out the HD radio too, it's pretty cool.
Posted on Apr 17, 2009
I just replaced my subwoofer in my car and i need to turn up the gain on my new subwoofer. can i do this from my alpine cda9855 head unit
Yes on most alpine units this feature is available but the sub woofer has to be conected to the sub woofer input and if it's setup like this you can go to your audio menu on your alpine unit and turn it up or down I hope this helps.
Sep 26, 2013 | Alpine CDA-9885 CD Player
I hav a alpine cda-w925ehi head unit an it just stopped an now says "interrupt"
Hi I believe you have an Australia model? Alpine's use what's know as an interrupt wire to hook into vehicles/phones to interrupt the audio of the deck when their is a signal sent to it. On the Alpine harness you need to search for the Pink/black striped wire which is the audio interrupt wire. Make sure that wire is insulated and not grounding out against anything or hooked up incorrectly.
-Boz
Nov 28, 2012 | Car Audio & Video
With the gain in the middle was runing vibe12" sub in bandpass box it blew the sub in 4 min of using could u please tell me what sub I can use to play loud it has to be 2 x 12" thanks.
There are many sub woofers out there that would be suitable for your amplifier. Just stick to the quality brands such as Elemental Designs, JL Audio, Alpine(type X), MA Audio, RE Audio and there are many more. Make sure the minimum power handling for each sub woofer is 600 WATT RMS. Another thing. The gain control on the amplifier is not a volume. It is there to match the output voltage (V) of your head unit to the input voltage of the amplifier. For example, if your head unit RCA output is (1.2V, 2V, 4V or even 5V) then match that on the amplifiers gain to be the same. The higher the V number is on your head unit, the stronger the signal is that is being sent to the amplifier. For example, If your have a 4V head unit and the gain control on your amplifier is set to 1.2V the you are sending almost 4 times the amount of signal strength to your amplifier. This causes distortion and distortion causes speakers and sub woofers to blow. I hope you understand the concept. IMPORTANT: This is a powerful amplifier, a 4 Gauge or 2 Gauge power cable MUST be used. Less than 4 Gauge, will cause over heating of both the cables and the amplifier. YOU DON'T WANT THAT. If you still have doubts and need more assistance, let me know.
dreamsystems
Feb 13, 2011 | Alpine PDX-M12 Car Amp
I can no longer adjust my subwoofer level from my head unit. I used to be able to in my other car but since I put it in my new car I can no longer adjust it? I have the alpine cda-9886.
make sure that before the sub woofer is hooked into the stereo that the settings for the sub are blank that way there is no previous setting once you have hooked up the sub and amp.
Feb 04, 2011 | Car Audio & Video
Hey I have an Alpine CDA-9851 CD Player and was wondering how to hook up my two 10" Kicker subs, since there is no subwoofer connection on the back of the player.
First to start you need an amp something that is a little stronger than your subs. What you want to do is 'T' off your speaker wires into RCA's to hook up into the amp. There is a device you can buy or you can cut some RCA cables. There are a few down sides to do it this way because as you turn up the volume the Subs will get louder and start to distort a lot faster than hooking up proper. The best way to do it is to get a deck with RCA sub outputs. Good Luck
Mar 25, 2010 | Alpine CDM-7874 CD Player
I have an amp powering two subs but only work with the radio and not when its in aux mode or cd mode. do i need some other conection
I am not familiar with your head unit but I know some radios can control audio options for each source. My unit has adjustments for bass treble fade sub out etc in each source like radio, dvd, cd usb etc. I would check this first. For example, my radio can have the bass set to zero while the dvd can have the bass set to 5. If this is the case for your stereo, the sub out for the different sources can still be set to off.
Feb 22, 2010 | Alpine CDA-9851 CD Player
Alpine sub woofer
your speakers are hooked up wrong. hook both positives together and both negatives together and bridge it to the amp. if it is one channel hook it up as one together. if it is 2 channel hook positive to one side and negative to the other side.
May 18, 2009 | Alpine Type-R SWR-1222D Car Subwoofer
Amp powers on but sub does not come on
I would double-check your RCA's on the amplifier. You should hear a thud if you unplug them. If not they are either not hooked up or defective.
Feb 07, 2009 | Sony XM-2150GSX Car Audio Amplifier
Woofer making horrible noise! HELP!
Think as an expert... Probably from my experience repairing woofers etc... the cone (1) or the spider (2) isn't well glued onto the woofer skeleton(or both???) The woofer cone must be absolutely centered or else you will get those clicks in low frequencies(you also get them in higher frequencies but you can't hear them!) I must say that it is very difficult to repair a woofer by your own. I suggest to return it back where you bought it and take another one (i suppose that you have a guarantee ha?).
Aug 10, 2007 | Alpine SWR-1542D Car Subwoofer
Alpine CDA-9815 CD Player Logo
Top Alpine Car Audio & Video Experts
xxxxxx xxx
Tygh Duval
Tygh Duval
Jaime Hernandez
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
