Question about RIM BlackBerry Pearl 8100
My blackberry pearl 8100 cannot connect to the desktop manager, it says it cannot communicate with the device. The phone is also displaying an App error 523.
You will need to reload the operating system of the device.
Make sure you backup the phone however you can. Put as much stuff on the SD card or SIM card as much as you can.
The device operating system will depend on your carrier, you will need to download the operating system from there. Wipe the device, connect it to your computer and it should recognize it.
When Connected select USB PIN: UNKNOWN (If the device still cannot connect to the computer, there may be a windows side driver problem, or more likely there is something wrong with the BB hardware.)
Start the Apploader from the BB desktop Manager
Select a Reinstall of the OS. It will take about an hour to reinstall the OS.
Posted on Apr 07, 2011
App Error 523 Blackberry Pearl 8100
you need to wipe the device with JL commander and reload the software using desktop manager
Jul 19, 2010 | RIM BlackBerry Curve 8300 Smartphone
I have JUM error 102 on my blackberry pearl phone and now it wont power up, is there a way to fix it without having to replace the whole phone?
Try to put a good battery,if it still not working flash it with desktop manager and a new blackberry firmware.
Mar 20, 2010 | RIM BlackBerry Pearl 8100
Phone powers on to white screen then nothing..blackberry pearl 8100
plug it into your pc and then after that, open the app loader on your desktop manager. run through (add remove programs if you want but you dont have to) when you finish, the phone sghould be able to work.
Mar 07, 2010 | RIM BlackBerry Pearl 8100
Phone turns into a white screen with hourglass in the middle then shuts off. happens several times a day.
Hi it is because the BlackBerry Pearl 8100 smartphone cannot initialize the BlackBerry Device Software or there is a corrupt operating system file.
To resolve this issue, reload the BlackBerry Device Software on the BlackBerry Pearl 8100 smartphone.
To perform an installation of the BlackBerry Device Software using BlackBerry Desktop Manager version 4.5 to 5.0, perform the following steps:
1) Open BlackBerry Desktop Manager. 2) Connect the BlackBerry smartphone to the computer and open the BlackBerry Desktop Manager. 3) Double-click Application Loader.
4) Click Start under Update Software to start the installation process.
5) Type your BlackBerry smartphone password, if prompted, and click OK.
6) Select Options under Device Software Options.
7) Select the check boxes next to the names of the applications to be loaded, and then click Next.
8) Click OK > Next > Finish.
9) When the process has completed, the message The loading operation was successful will appear.
10) Click Close to return to the BlackBerry Desktop Manager.
I hope this information will be helpful to you.
Nov 21, 2009 | RIM BlackBerry Pearl 8100
Blackberry red light then reboots!
This behavior indicates that no applications are installed on the BlackBerry smartphone.
CAUSE: The Application Loader tool in BlackBerry® Desktop Manager removed existing
applications from the BlackBerry smartphone, but failed to install new applications.
RESOLUTION:-
1) Verify that BlackBerry Device Software is installed on the computer.
2) If the BlackBerry smartphone is connected to a laptop computer using a docking station,disconnect the docking station from the laptop computer and connect the BlackBerry smartphone directly to the laptop computer.
3) If a third-party application uses the same communications port as the BlackBerry Desktop Software, close the third-party application.
4) If you use a USB adapter to connect the BlackBerry smartphone to a serial port, temporarily connect the BlackBerry smartphone to a USB port.
5) In the BlackBerry Desktop Manager, double-click Application Loader.
6) Follow the Application Loader tool prompts to install the BlackBerry Device Software.
Oct 15, 2009 | RIM BlackBerry Pearl 8100
My blackberry pearl will not connect to my desktop manager. my computer doesn't even recognize it.
Download and install the latest Handheld Software for your model then open Desktop Manager and run the application loader once the USB cable is connected to the device. 8100 Software located here https://www.blackberry.com/Downloads/contactFormPreload.do?code=1905AEDAB9BF2477EDC068A355BBA31A&dl=5585B27F984ECB0A1F1A967CAC7CA1B9
Just fill out the form and the download is free.
Sep 27, 2009 | RIM BlackBerry Pearl 8100
Blackberry pearl 8100 to be used as modem to a pc
found another link how to proceed. Thanks anyway
Jun 05, 2009 | RIM BlackBerry Pearl 8100
I have a blackberry pearl 8100 and it turned off and now all it will do is flash a red light in the upper right hand corner. I have taken out the battery memory card messed with the sims card. What...
CAUSE: The Application Loader tool in BlackBerry® Desktop Manager removed existing applications from the BlackBerry smartphone, but failed to install new applications.
RESOLUTION
  1. Verify that BlackBerry Device Software is installed on the computer.
  2. If the BlackBerry smartphone is connected to a laptop computer using a docking station, disconnect the docking station from the laptop computer and connect the BlackBerry smartphone directly to the laptop computer.
  3. If a third-party application uses the same communications port as the BlackBerry Desktop Software, close the third-party application.
  4. If you use a USB adapter to connect the BlackBerry smartphone to a serial port, temporarily connect the BlackBerry smartphone to a USB port.
  5. In the BlackBerry Desktop Manager, double-click Application Loader.
  6. Follow the Application Loader tool prompts to install the BlackBerry Device Software.
Apr 12, 2009 | RIM BlackBerry Pearl Smartphone
My blackberry has a jvm 513 error on my 8100 pearl. i need to know how to install the pearls software on my phone. and my phone says its not connected to the desktop manager even though its connected on my...
First, download and install the latest version of BlackBerry Desktop Manager software (5.0.1) from: https://www.blackberry.com/Downloads/contactFormPreload.do?code=A8BAA56554F96369AB93E4F3BB068C22&dl=DA5FB46338C8C0DCB1039F7898184FC5
then, download and install the latest Handheld Software for your model then open Desktop Manager and run the application loader once the USB cable is connected to the device. 8100 Software located here https://www.blackberry.com/Downloads/contactFormPreload.do?code=1905AEDAB9BF2477EDC068A355BBA31A&dl=5585B27F984ECB0A1F1A967CAC7CA1B9
Just fill out the form and the software download is free.
Apr 02, 2009 | AT&T Blackberry Curve 8300 Smartphone
My phone Wants me to reset it
Try to connect to it using the desktop software. you can download this from either your service provider website or, blackberry.com If you can connect to it back the phone up using the software then reset it to factory and put the backup on phone using the same software ... it will be for pearl 8100. If you cannot connect to phone you can try the service provider to see if they can recover it. But I am guessing the software below will be able to connect to it
Here is another solution step by step:
1. Install the software from the CD (that you received with the device), or download it from the service provider (AT&T).
2. Delete or rename the vendor.xml file, here: C:\Program Files\Common Files\Research In Motion\AppLoader (you're windows file options needs to be set to 'show system files', to see said file...
3. Open Desktop Manager (DM)...
4. Connect the Red Pearl (since am sure that's what you have!)...
5. Doing this will force the pc to see the BlackBerry as new hardware, and thus force it to reload the Operating System (OS)...
6. During the process, select YES to do a backup...
7. The whole process should take about 30-45 minutes...
But, since this has happened so many times, I have to ask myself, is it something you're doing that it causing this? I know the Red Pearls from AT&T have had issues from DAY ONE!
Jan 01, 2009 | RIM BlackBerry Pearl 8100
RIM BlackBerry  Pearl  8100 Logo
98 people viewed this question
Top RIM Computers & Internet Experts
Computer Repairing
Computer Repairing
Andrew Wright
Trisha
Trisha
Are you a RIM Computer and Internet Expert? Answer questions, earn points and help others
