Question about Equinox HD8X Underwater Video Housing (HD8XFX7) for Sony HDR-FX7 Camcorder
I shot video with an Equinox HD 8 and a Sony FX7 in an indoor swimming pool with lights above it and it was heated. My video came out grainy. It should be crystal clear HD video. Will I have better results in a lake or ocean if the water is clear. Please advise. Thanks Dave
    Problem Solver:
  • 19 Answers
You may already know this but I will give you a bit of background first.
What causes grain in video is called "gain" Essentially it increses the charge on your sensor to allow more light to be recoded.
To eliminate this turn off auto gain on your camera and set your gain to 0db.
Ensure your iris is fully open.
If your exposure in the pool is too dark then you will have to increase your gain. However in my experience when you get into the lake/ocean you will have more than enough light.
the fx7 is a good camera and you are correct it should be crystal clear. Play with your settings out of the pool and get used to how all the setting work.
Hope that helps
Posted on Apr 08, 2011
How can I reset my circu-pool salt generator? it is giving me a high salt light and a check cell light
I have a Circu-pool SJ45, no issues . Have you cleaned the cell. How old is unit. Have you checked pool salt level. Have not seen reset button, will look .
May 15, 2016 | CircuPool Swimming Pool Salt Water...
Tip
How To Connect Hook Up Use Above Ground Swimming Pool Vacuum and Hose With Sand...
<utube src="YEW-QUyP2Iw"></utube>This video will show you how to connect your above ground pool vacuum and hose to the sand filter on your swimming pool.
on Aug 03, 2013 | Pool & Spa
How can we take it apart after we drained the pool?
Question:
How do I properly remove my above ground pool?
Answer: by Osko Pool n Spa Onground Pool Removal Guide
Recently, a reader of one of my other articles asked the question;
" How do you take down an above ground swimming pool to move it? I can't seem to find anything to help me. I read your article on replacing a liner but I need to know how to move the entire pool".
Well, (I thought to my self), this is a very good question. So, here is a basic step-by-step guide on the basic proceedure: ( You'll need at least three people, to help with your wall).
1) Drain all water out of pool using a sump pump.
2) Remove skimmers, returns, lights etc.
3) Remove old liner, (use a razor knife and cut into manageable folded pieces). You'll need a new liner if your going to reinstall the pool.
4) Remove Top Seat Ledge covers
5) Remove Top Seat Ledges.
6) Remove Top Rail and Joiner Plates.
7) Locate Wall Bolt Joint on the Pool Wall and remove the corresponding Upright.
8) Now, get some help and remove all Wall Bolts and associated hardware.
9) Next, start pulling the wall out of the bottom rail (track). And roll the wall up as you remove it from the bottom rail. When finished, duct tape the wall so it does not unroll.
10) Pull the uprights, bottom rail and bottom rail joiner plates out of the ground in sections.
11) Remove uprights from bottom joiner plates.
12) Make sure to separate all components and save all hardware!
That's it!
Hope this helps!
Apr 09, 2016 | Intex 32 x 16 x 52" Ultra Frame...
Sony HDR fx7 fuzzy image
http://www.youtube.com/watch?v=KYHtCvyHhc4&feature=youtu.be
i have sony hdr fx7 . image are blur look like in the video . both indoor or outdoor . why? how can i fix it.
Nov 30, 2011 | Sony HDR-FX1000, HDR-FX7, HVR-HD1000U, and...
HOW TO WINTERIZE AQUAMATE ABOVE GROUND SWIMMING POOL PUMP
Open the plugs on the bottom front of the pump pot and on the pump housing itself. These two plugs will do the pump and just the pump. You should have simmilar plugs on the filter, heater, chlorinator and any other equiptment on the system.
Oct 13, 2010 | Hayward Sp1580x15 Power Flo Lx 1.5hp...
Opened pool. Rheem heater has the service light blinking
rollout switch is open, and sns is a sensor failure. replace rollout switch, clean out vents, inspect heat exchanger. water sensor senses too cold or too hot water
May 28, 2010 | Rheem 266K to 399K BTU Swimming Pool...
Finepix E550 -suddenly very grainy photos and over exposed?
Have you checked what ISO you have selected here?
Graininess and over exposure can be caused by selecting the wrong ISO ( which in film days was ASA ( film speed) The average ISO should be 100 some early models allowed ISO 64 or similar. Having it set at 400 -800 ISO can also have the pics come out grainy. But not nescessarily overexposed unless you point directly at the light source as these ratings are for low light/movement situations. The video mode usually sets itself up differently to picture mode. The fact that you say your video is OK says there is nothing wrong with the lens or sensor, just the settings you have initially chosen to have autoed.
Please rate our help to keep thye service online++++Thanks for using FIXYA
Sep 19, 2009 | Fuji FinePix E550 Digital Camera
Very grainy pictures indoors at night
If you can adjust the ISO sensitivity to a lower number then the graininess will be reduced.
However, by reducing the ISO, you will need a slower shutter speed and a larger aperture. A tripod, table or other support may be necessary.
The "noise reduction" setting on the camera can also be adjusted a step up.
Taking pictures at full resolution and fine compression will also help.
Overall, at least try lowering the ISO, and using the flash brighter.
Jul 01, 2008 | Panasonic Lumix DMC-TZ3 Digital Camera
GRAINY PICTURES
Noisy pictures = High ISO in almost all cases. Select ISO manually (select a manual mode where you can control the ISO) and set it to the lowest possible value. To avoid camera shake, place the camera on a tripod or another sturdy surface; or use the flash
Dec 20, 2007 | Sony Cyber-Shot DSC-S40 Digital Camera
Would grainy picture mean defective camcorder?
Here's what I do: I go to the store that I got the camera and try some shots there with their floor model and compare it. If defective I get them to work the issue on the spot.
Sep 14, 2005 | Sony Handycam DCR-HC42 Mini DV Digital...
Equinox HD8X Underwater Video Housing (HD8XFX7) for Sony HDR-FX7 Camcorder Logo
191 people viewed this question
Top Equinox Cameras Experts
Steve
Are you an Equinox Camera Expert? Answer questions, earn points and help others
