Question about Kodak Easyshare M893 Digital Camera
My camera is not working. my camera does not turn on and when it does it turns off
    Novelist:
  • 125 Answers
Welcome to FixYa.
For camera's that won't turn on or will turn on but automatically turn off. First thing you need to check if the battery was fully charged.
Second, check if the battery was placed in right direction.
If those two solution was done, You need to removed the battery and re-insert it again.
Also try to install new fully charged battery.
If this issue will continue you need to contact your service center because this might have a camera malfunction.
Feel free to send us your comments or suggestion if this solution was helful.
Thank you for using FixYa.
Posted on Apr 08, 2011
My camera is stuck open and wont turn off or turn
i have the same problem. It does'nt work. Any suggestions ?
Apr 26, 2010 | Olympus FE-200 Digital Camera
Camera keeps turning off when turned on. I just
try to insert different batteries. then it would work fine. I had the same problem and i have put my friends camera batteries and it worked for me. after that my batteries have also been worked fine
Jul 15, 2009 | Kodak EasyShare One Digital Camera
Even with new baterries the camras turns on momenterily then turns right off.
I had the same problem with my camera. What I did was turn it on and grab the outside of the lens so that it did not retract. I then turned it off and then on again and it worked hust find. It seemed that something in the retraction and turn off process was out of sync. My camera works just fine now.
Jul 03, 2009 | Kodak EasyShare C913 Digital Camera
The Same problem
I'm not sure why this works for me, but I think it's worth a try:
1) First, take your SD card out of the camera.
2) Then turn on your camera and let it turn itself off.
3) Read the next step first and be ready to press the shutter release button (take a picture) right after the LCD screen turns on
4) With the camera lens pointed down towards the floor (aim down), turn on the camera. At this point the LCD screen should not be blurry anymore. Immediately press the shutter release after confirming that the LCD is not blurry. If the camera stays on and you can review the picture (most likely of your feet), then you are almost done.
5) Turn off the camera and re-insert your SD card.
5) This may not be a permanent fix, but point the camera lens downward whenever you turn on the camera. It should work normally if you do this. Mine worked normally (meaning I don't have to point it downward when I turn it on) after doing this several times. Your results may vary.
Jun 05, 2009 | Kodak EasyShare M1033 Digital Camera
I have a kodak m1033 turns on then shuts right off
May 18, 2009 | Kodak EasyShare M1033 Digital Camera
Camera turns on but screen is blank and no buttons work
h...i try to do the following steps...
Turn off the camera.
Ensure the camera is not connected to an AC power adapter.
Remove the battery from the camera for 15 seconds.
Reinsert the battery.
Turn on the camera.
thank u rate me!!
Feb 10, 2009 | Fuji Finepix® F31fd Digital Camera
Malfunction -turns on and message to return on
the camera has a lens fault and needs to be checked by a panasonic repair technician.
Apr 23, 2008 | Panasonic Lumix DMC-FX9 Digital Camera
Turning on the camera.
I had the same problem. I tried turning it off and hitting the camera on the palm of my hand but that didn't work. But, hitting it one time on the palm of my hand WHILE THE CAMERA WAS TURNING ON worked. I turned the camera on, it moved the lens out and I hit it one time on my hand and it works perfectly now.
Someone suggested it was a problem with the internal lens which makes sense. Also, be careful not to hit a sensitive part of the camera on your hand. I used one of the corners.
Oct 26, 2007 | Sony Cyber-shot DSC-W50 Digital Camera
Camera turns itself off after turn on
mine was same turned out to be flat batteries, bought 4 new and they did not have the power to run it ,went for durracell and it worked fine for 5 photo's, had to stick with re-chargeables and it works fine, good luck
Sep 16, 2007 | Panasonic Lumix DMC-LC50 Digital Camera
Kodak Easyshare M893 Digital Camera Logo
80 people viewed this question
Top Kodak Cameras Experts
Tony
Are you a Kodak Camera Expert? Answer questions, earn points and help others
