Question about Canon Office Equipment & Supplies
My printer which is a canon mp250 says error 6000 and the alarm blinks and the on button blinks i dont know how to fix it and if it needs to be repaired by a specialist I probley will not be getting another canon printer is thier anyway I can fix it.
    Novelist:
  • 125 Answers
As for the solution, pls take out the cartridge from printer.
And then wipe out the circuit part by rubbing alcohol (by Q-tip)
And then put your cartridge back to printer.
If above method is not working..... I think your cartridge circuit part must be shorted.
It happens when you refill your cartridge in Canon...(mostly for color cartridge)
This error is called e5 error, which canont be solved.
You can find the many solution for e5 but unfortunatley non of method can't fix the problem.
Well... as for immediate solution? Replace with new cartridge.
Posted on Apr 08, 2011
My canon mp250 is showing a E16 error and has the alarm constant orange and the B blinking. I tried removing and replacing the cartridges but it did not help. I cannot scan either.
Error No. E16 is caused by Ink has run out / cartridge must be reset.
To solve the problem here is your solution:
Press the STOP / Reset for 5 - 15 seconds wait until the led display process.
Aug 22, 2011 | Canon Pixma Mp250 Allinone Inkjet Photo...
I just bought a Canon MP250 scanner, printer copier. I printed 1 page and after that the on button keeps flashing, the letter P and number 3 keeps flashing next to the on button. Also an amber colored...
The manual says: " 'P, 0, 3' is displayed: If any object is placed in front of the machine, remove it. Open the Paper Output Tray gently, then turn the power off and back on."
If this doesnt work you need to contact the canon service center, you can find all of the information on their Webpage
Aug 21, 2011 | Office Equipment & Supplies
Printer is displaying error po8
The Canon Pixma MP250 error p08 code means your printer has wasted ink. You will need to reset the printer by pressing the reset button and holding it and then press the reset button twice to enter the maintenance mode to reset the wasted pad ink. Press the reset button four times and then turn the printer button off and then back on.
Feb 21, 2011 | Canon Pixma Mp250 Allinone Inkjet Photo...
How to fix error code 5200 on canon printer MP258? what is 5200 mean?
Here's the procedure. This code is normally encountered after refilling an ink cartridge and replacing the cartridge. Turn off printer. Hold down Stop/Reset button with one hand and turn printer on with other hand. After green light comes on for the ON button, press the Stop/Reset button two times and you should see the green light blink off and the orange alarm light blink "on" with the first press and then the green light comes back on for the power button and the orange light goes off with the second press (if you did it correctly). Now, you need to hold down the ON button about five seconds, then let go to shut OFF the printer. When you turn it back on, the printer should be back to the factory original condition. Make sure you set all your printer properties the way you want them again from your printer properties dialog boxes because some of the settings may have been stored in the printer's EEPROM, which you just reset to get rid of the offending alarm code.
Feb 01, 2011 | Canon Pixma Mp250 Allinone Inkjet Photo...
Canon mp250, not printing. Print screen says "creating print data" and freezes there.
This sounds like an internal memory problem and I don't have a workaround. Before you give up, try this technique to reset the printer to factory. They are great printers once you learn this reset technique. Turn off printer. Hold down Stop/Reset button with one hand and turn printer on with other hand. After green light comes on for the ON button, press the Stop/Reset button two times and you should see the green light blink off and the orange alarm light blink "on" with the first press and then the green light comes back on for the power button and the orange light goes off with the second press (if you did it correctly). Now, you need to hold down the ON button about five seconds, then let go to shut OFF the printer. When you turn it back on, the printer should be back to the factory original condition. Make sure you set all your printer properties the way you want them again from your printer properties dialog boxes because some of the settings may have been stored in the printer's EEPROM, which you just reset to get rid of the offending alarm code.
Jan 20, 2011 | Canon Pixma Mp250 Allinone Inkjet Photo...
How do i clear an error 5100 from my canon pixma mp250?
Try this technique. Turn off printer. Hold down Stop/Reset button with one hand and turn printer on with other hand. After green light comes on for the ON button, press the Stop/Reset button two times and you should see the green light blink off and the orange alarm light blink "on" with the first press and then the green light comes back on for the power button and the orange light goes off with the second press (if you did it correctly). Now, you need to hold down the ON button about five seconds, then let go to shut OFF the printer. When you turn it back on, the printer should be back to the factory original condition. Make sure you set all your printer properties the way you want them again from your printer properties dialog boxes because some of the settings may have been stored in the printer's EEPROM, which you just reset to get rid of the offending alarm code.
Jan 14, 2011 | Canon Pixma Mp250 Allinone Inkjet Photo...
I have canon mp 258 with error e27 how would i resolve it?
Canon error e27 ink absorber full/reset process
printer powered off but connected on power source , you must:
1. Press & hold stop/reset button, and then press & hold [ON/OFF] button.
2. When Green power lit, leave stop/reset button & press twice stop/reset (see orange indicator).
3. Leave On/Off button. Printer in actually service mode.
4. Press stop/reset 4 times (see orange indicator) if not blink restart above process from top.
5. After press stop/reset 4 times successful press On/Off button 3 times. printer will off.
6. Press On/Off button.
Jul 10, 2010 | Canon Pixma Mp250 Allinone Inkjet Photo...
MY PRINTER CANON PIXMA MP250 ARE NOT PRINT AND THE ALARM IS ACTIVE.WHAT DO IDO?
in the small moniter what the errore you have like E5 - E2- E3 so that we can help you this Errore know you the problem on the printer
Dec 02, 2009 | Canon PIXMA MP150 All-In-One InkJet...
Giving the error e 2,3
Go to this link. Type "error e 2 3" in the search window and click the Search button. Try the troubleshooting steps provided. If the error still persists, you may need to have the machine serviced.
Apr 29, 2008 | Canon PIXMA MP160 All-In-One InkJet...
308 people viewed this question
old marine
old marine
