Question about Samsung Cell Phones
Cell Phone Problem
Displays only white screen. I did not drop. High humidity here in August in Michigan might cause it? help! -Mike
Como le hago para poder descargar de mi celular a mi ordenador mis archivos si no tango el software ya que no hay ni siquiera para descargar
Posted on Aug 06, 2008
SOURCE:
Should a heat pump run all the time?
It really depends on the climate and the design. In Michigan where the winters are cold and the humidity high the air cooled heat pumps run constantly, but here in Arizona they cycle on and off like a regular air conditioner. That's the best answer I can give. Hope this helps and good luck.
Oct 05, 2014 | Carrier 52CQ-312-4 Comfort Series Heat...
My Maytag A/C is blowing out white smoke. What should I do? Is it blowing something in or is it something inside it? I had it on 75 degrees and on high cool.
If it's blowing very MUCH of it, then it's coming in from outside. There's very little inside an air conditioner that could possibly generate smoke, and VERY little that could possibly generate any LOT of white smoke.
Now... it's POSSIBLE, if your humidity is high right now, that it's blowing cold enough air to condense the humidity in the air, causing an actual cloud (just like the ones in the sky) inside your house. That can happen only when the humidity is very high, though.
Aug 01, 2014 | Maytag Heating & Cooling
Why does the humidity in my house go up when the furnace is on?
Humidifiers are usually controlled by a humidistat that reads the humidity in your house and turns the water on and off to humidifier that is attached to your furnace. When your furnace is running it sends the voltage through your humidistat that then runs water through a filter screen inside humidifier and the furnace forces air through this screen which places humidity into your home. If humidity too high look at dropping level on humidistat control. (Usually attached to ductwork bye furnace)
Nov 03, 2013 | Heating & Cooling
I have a white upright line on the right side of the screen at all times can yiou help please
This is caused when the screen has hit something slightly or a bit hard. When the hit occurs, it usually causes some kind of crack or dispersion of white or other colored line or patching on the display side of the screen. This is because the inner ink that displays objects have been partially shattered.
The only way to fix this problem is for you to send it to a specified technician or to the company as there is a very high possibility a new screen would have to be put to replace the former.
Hope this solution was helpful? Please comment for more information and thank you for using fixya
Jan 13, 2011 | Panasonic Lumix DMC-FX35S Digital Camera
Unit keep on going out on lock out
Wash out outside coil with hose with 30 degree downward starting at the top and work side to side to bottom and try again. If this don't help check evap coil (inside) for ice forming when unit is on. You should see a 15 - 25 degree drop from room temp coming out of discharge air. This will change with humidity indoors. as it drops temp will too.If outside coil is dirty or unit is low on gar it will cause high compressor and high disgharge lockout. Low gas can also cause freezing of indoor coil and loe temp or pressure lock out depending on type of protection incorporated.
Jun 30, 2009 | Heating & Cooling
I have a GE air conditioner with ditigal panel. I
Wash out outside coil from time to time.This is the most over looked part of window units. Take care not to spray water directly into fan motor. If not real humid in house check temp coming out of ac inside and make sure filter and coil are clean. run on high speed and the air should have good force. 20 to 30 degree temp drop of room temp should be about right. Much depend on outside temp and humidity and indoor humidity plus insulation factor of area. How many people are in the area and if you keep unit on day and night .
Jun 28, 2009 | GE AJCQ08ACB Air Conditioner
Samsung s860 camera got dropped turns on but screen is only white
dropping the camera might have caused damage to your LCD screen, best advise I could give is to send it in for repair
check if you can still view old pictures or if the on screen displays are visible, it will narrow down if the problem is with the lens or the screen
hope this helps
Mar 30, 2009 | Samsung S860 Digital Camera
1998 Dodge Ram won't start when very humid or raining
does the check engine flash while driving, a quick test, cause I suspect the coil pack, when dark open the hood start the truck and with a water bottle spray the coil pack if you see sparks replace it, change many of those here ....
Dec 17, 2008 | 1998 Dodge Ram 1500 4WD
Benq lcd Displays only white
Most often the all white screen is the result of a missing voltage to the LCD panel. We usually find an open fuse on the panel circuit board. Unfortunately replacing the fuse does not usually fix the problem.
Mike
Mar 02, 2008 | Computers & Internet
White Screen
  1. Upon startup lens emerges but when screen appears it is white whereas it normally displays whatever the lens sees. When the shutter button is pressed the camera will focus and take a white picture which can be deleted. The camera does not flash although flash is set to automatic and photo taken in a dark room. Camera flashes (weakly) with flash set to manual on. Lens is unobstructed and appears to be perfectly normal. Camera was not dropped. Batteries have been changed.
Jan 19, 2008 | Pentax Optio E10 Digital Camera
Cell Phones Logo
155 people viewed this question
Top Samsung Cell Phones Experts
Felizardo Erilla
Felizardo Erilla
Bill Long
Donni Steen
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
