Question about Coleman Sport & Outdoor - Others
I have a 1993 Coleman Destiny Royale pop up camper. The lift system cable(s) for the top have broken or are near their breaking point. Is there a schematic available for this system so I can fix it and where can I get it from?
  • petros793 Apr 07, 2011
    The canvas is attached to the top,this needs to be taken off too? How is the top attached to the pillars (what kind of fasteners, screws, rivets, cotter pins?) How long should this take if I have help?
  • 3,018 Answers
You will have to contact them to get the information you requested. Their contact info is listed below.
Coleman Trailers - manufactured by Fleetwood Enterprises, Inc. - Before 2006 - Toll free: 1-800-544-8193
Customer Service Email:warranty@dutchmen.com Website: www.coleman-rv.com
Regards, Tony
Posted on Apr 08, 2011
  • 11,800 Answers
No schematic available. But there is no actual need for one - the system is extremely simple: the lever turns a screw; this screw goes into a flange; all the 4 cables are attached to this flange; from the flange to the posts the cables are routed thru the chassis (on the rear ones there should also be a pulley , to reduce the friction on the chassis); at the base of each pillar support a pulley sends the cable to the top of the pillar support; there another pulley is sending it inside it to the bottom of the pillar, where it's attached. When you turn the lever it pulls on the flange, which pulls on the cables, which pulls on the bottom of the pillars raising them.
To replace the cables lift the top and remove it, just turn the lever all the way to the left to release the he tension in the cables then just take out the pillars disconnect the cables and pull them out.
Posted on Apr 07, 2011
  • Azrael SRL Apr 08, 2011
    No need to slide the canvas out, the top will be taken off with it. The top is attached with screws. It's a 4 hour job for 2 men.
I have a 1993 coleman destiny royale pop up. The interior lights do not come on.
Hi Keith,
Try Google with "wiring diagram Coleman etcetc". You'll get a whole raft of hits - take your pick! The best one might be: http://popupportal.com/
Aug 01, 2015 | Cars & Trucks
How to tighten cable on pop up camper
the adjustment can be done by your dealer, contact them see how much it costs.
Oct 26, 2008 | Coleman 10' X 10' Sundome Tent 9160K101
I bought a pop up. On the way home from buying it popped off hitch (apparently the coupler needs to be replaced)- how do I go about repairing (or does anyone know of a place in southe east WI area that...
Hitch: Verify the obvious. 1-7/8" or 2" ball and coupler. Some couplers can be and may need to be adjusted. Look for a screw on the rear side.
Sorry, not much help on the lift system. Although, I rigged a winch up to my coleman instead of replacing the whiffle tree. You may be able to do similar.
Apr 09, 2010 | Coleman Campers Grill
I want to buy this pop up camper but the wiffel tree is broke i was wondering how hard it is to fix it and how
It is not difficult however, it may not be broken. First, verify all the pins in the crank linkage are not sheared and thus not turning the wiffle screw. There is on not visible from the outside. Under the camper is a rectangular tube usually mounted between the 2nd and 3rd crossmember. It is just a cover. Remove the cover and near the front is the probable culprit. Just turn the crank and look to see if the wiffle tree screw is turning.
If the handle won't turn or is very hard to turn, the wiffle tree is likely bad. The four cables are attached with welded closed eye-bolts. Just back of the nuts and remove them keeping track of where they go and how much exposed thread is showing. This is the adjustment for the cables to ensure even lifting. On the front the 2nd crossmember is a thrust bearing under a small rectangular cover. Remove the cover, seperate the crank linkage rods and remove the bearing and it's spacer as a set. Pull the wiffle tree screw with the bar the eye-bolts were attached to, forward. It may need some persuasian but it is just a slip fit in the rear and will come forward to remove it. Install new one in reverse order.
Sep 24, 2009 | Coleman Campers Grill
Rockwood pop-up camper.when i try to use hand crank to put it up or down only the back seems to go up not the front
Hello.
You either have a broken cable, or it may have come loose. Gain access to your anchor points and check the cables. Replacement cable can be purchased "by the foot" al Lowe's/similar as well as cable nuts and such Check the axels and spools powered by the hand crank for anything out of whack, like a broken weld on a cable drum, etc.
Best regards, W/D
Aug 17, 2009 | Coleman Campers Grill
I need a repair/owner's manual for 1999 Coleman
Tried googling Coleman? They might be able to help.
Jun 29, 2009 | Sport & Outdoor - Others
Have used 1981 Coleman pop-up camper and the mechanism that raises the camper up is stripped. Either need manual for 1981 Coleman pop-up or any idea where to get the part to fix problem. It's the screw...
My Coleman has the same problem. I can crank the top up but it will not hold in place.
I just leave the crank handle in place after raising the top and secure the handle to the bumper with a bungee cord. It's jury rigged but it works great.
Sep 21, 2017 | Coleman 10' X 10' Sundome Tent 9160K101
Hard to crank up
May sound a bit tacky but all pop ups are a bit tedious to crank up. In the event this IS NOT your first time to own or operate a pup. I apologize and suggest you post your problem on the pop up times and or the pux webpages. Both are reliable sources for people who have pop up up or small campers.
May 25, 2009 | Coleman Campers Grill
Broken cable in older Coleman pop-up camper...how to replace it? Can't see in body of camper where the cable needs to go through to the posts that raise the top.
This camper uses the Coleman lift system which uses a threaded rod that connects to a tracked distribution block to which all four cables are connected and then routed by pulleys to all four corners of the popup.First raise the popup to it;s full height by using automotive jacks and poles once extended securely clamp the poles to the telescoping up rights This IS SUPER IMPORTANT FOR YOUR SAFETY. Next get under the camper find the broken cable unbolt it's routing pulley(s) pass the broken ends out the pulley(s).Next unbolt the end from the distribution block. followed but unbolting the cable from in side the telescoping column;carefully note the routing in side the column. Buy or make up an exact length cable of aircraft grade stainless steel twisted wire cable of the same gauge. Reverse steps to re install,take lowering strain on crank make sure crank handle is captured by anti free wheeling device on camper un clamp poles remove, lower and raise top by crank to ensure smooth working. You're finished.
Apr 19, 2009 | Coleman Sport & Outdoor - Others
Sport & Outdoor - Others Logo
583 people viewed this question
Top Coleman Sport & Outdoor - Others Experts
David Payne
David Payne
Vernon Taylor
Are you a Coleman Sport and Outdoor - Other Expert? Answer questions, earn points and help others
