Just changed the mother board on a Dimension 4600. When I turn it on, everything powers up for a moment and then stops and the power light flashing green.
  • 721 Answers
Usually a ram problem. Make sure the memory is correct for the board. Also, when you swapped cpu's were you sure no pins got bent? Make sure the 4 pin power is connected at the top. Make sure the cpu fan is 4 pin & connected.
Posted on Apr 16, 2011
Dell dimension 4600c won't turn on since we had a power outage
hi
if you CPU has a green light it meance your Power supplay is working fine chack back side of your CPU fan is working or not if it's working then just open case
folow the 2 step
1 remove RAM
2 CIMOS beetery which is on mother board leave your CPU for Some thime re fix both i hope you CPU will give you the disply
Jul 19, 2010 | Dell Dimension 4600 PC Desktop
Dell Dimension 4600 will not reboot. I have to turn it off, unplug the power, push the On/off switch for a moment, let it set for 15 min then it will reboot. I have recently upgraded from 256kb ram to 1gb,...
from what you describe, they system will not shutdown. So try the following:
  1. Boot to safe mode (F8 at boot) and then see if the system will reboot from the safe mode.
  2. Boot to the Safe Mode again, Start RUN MSCONFIG, edit the startup group, (Basically uncheck all the items in the startup tab) reboot in the normal mode then see if it shutsdown. If it shutsdown normally, then start adding items back one at a time until you identify the items that were causing the items.
Jan 12, 2010 | Dell Dimension 4600 PC Desktop
Power supply or motherboard dell 4600
Ok, you stated that the power supply cooling fan was running at this time. unfortunately, this is not the power supply unit that has failed. the mother board has actually failed in this case. If the power unit was damaged, the cooling fan would not spin. You will need tp replace the mother board in this case. it has failed.
This is not a novice situation. we recommend a service tech for this type of repair. if it was a power supply issue, it would have been quite easy to replace but, this is not the issue here. it the mother board.
Jun 22, 2009 | Dell Dimension 4600 PC Desktop
Computer won't shut off (occasionally)
usually this the indication of Hard driver problem.
this hard drve is on its last lag. it is hardware failure.
get a new Hard Drive and copy everything to the new hard drive. save this one as a backup.
May 22, 2009 | Dell Dimension 4600 PC Desktop
No anything
Flashing amber power button indicates a failure of the power supply.
Jun 14, 2008 | Dell Dimension 4600 PC Desktop
Dell Dimension 4600C will not power up
Sounds like the power supply is faulting. If not it is your mother board that has failed.
Mar 06, 2008 | Dell Dimension™ 4600C PC Desktop
Pover up trouble
sounds like something is drawing down on your 12 volt supply drives or on board regulators. Try it without the drives connectged, and see if you can get the system to boot up(you'll just get a notice that your drives are unavailable, but you'll already know that, right?
got backup for your Dell?
Feb 15, 2008 | Dell Dimension 5100 (D51L1) PC Desktop
Hard drive and cd drives still on
Locate Power Wakeup option in modem/LAN in BIOS and disable them, if you have "power wake up" enable for LAN/modem your computer will be switched on for remote network command.power wake up setting are located on BIOS.
Dec 09, 2007 | Dell Dimension 4600 PC Desktop
Power problems with Dell Dimension 4600
Your mohterboard seems to be bad! If you have replaced the power supply and placed all connections in the rightful place, with no result! Your Motherboard is definetly bad!
Nov 29, 2007 | Dell Dimension 4600 PC Desktop
Computers & Internet Logo
27 people viewed this question
David Payne
David Payne
