Question about Brother HL 5250DN Laser Printer
Had a power outage, and "Brother HL-5250DN"
SOURCE: my yamaha rx-v461 won't turn on
Check the main fuse
Posted on Aug 22, 2008
SOURCE: no power
Mine died about 5 days ago, About Feb 5 09.
Fix was very simple. it involved a drill, a soldering iron, and spare capacitors.
Open up the unit. Spot all bad capacitors. in my case, a 820uf 10v ELNA capacitor was to blame, it had exploded adn opened up. Desolder the bad capacitor, Replace it with a good one, like matsushita or rubycon or nichicon. Random brands like CAPXONS and ELNA and Fuhjyuus are known to die fast. in my case, it got swapped with a matsushita. then the unit powered up again.
I found it funny that panasonic did not use a single one of their own capacitors in teh making of the unit. i spotted lots of Nichicons, which are really good, then lots of ELNAs which are bad, one Capxon and some matsushitas.
Posted on Feb 10, 2009
komguy
  • 2306 Answers
SOURCE: after power surge, canon I9900 printer will not turn on?
You can try to power up with the printhead out, that sometimes causes it to not power up. Otherwise that machine is fried since you can't get a replacement logic pcb anymore.
Posted on Jul 30, 2009
  • 191 Answers
SOURCE: After Power Outage, wont power up...
did you try the pwr button on the console not just on the remote?
it might have still been fried, some electronics are sensitive- or it was in the middle of an update
Posted on Aug 06, 2009
  • 8457 Answers
SOURCE: my tv made a popping noise and then shut off wont
Power Supply Board is dead.Replaced the power supply board will solved this problems.Tries websites Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Posted on Mar 19, 2010
Testimonial: "power supply board had a couple blown resistors. Thank you"
All LED lights flashing on Brother HL-2140, how do you clear it?
Your printer needs servicing due to a fault on its electronics. This is due to a power surge or spikes cause by an abnormality in your power distribution system or your power transmission/distribution lines might have been struck by a lightning during a storm and its breakers have failed to cut the power.
As a precautionary measure, always plug electronic devices on surge protectors.
Send your printer to your nearest Brother Service Centers.
Jan 19, 2012 | Brother HL 2140 Laser Printer
Had a power outage for several hours. Power came back on but the printer came on with all lights blinking. Turned power off and back on but the same problem. What's happened, and what do I do?
Nearly all later printers have circuits that stay 'alive' even with the power turned off. Try pulling the AC plug overnight' this should clear most stored errors that may still be present.
Jan 01, 2011 | Brother HL 5250DN Laser Printer
Power outage and now my brother HL-5250DN Laser printer won't work. Removed it and plugged back in. It installed automatically but won't print. Using Win 7
Your printer may have experienced damage to electronic components with the outage, especially if due to a lightning strike causing the outage. You should have a shop troubleshoot and decide if it will need a new board, such as a formatter/logic board.
Jun 19, 2010 | Brother HL 5250DN Laser Printer
Brother HL-5250 printer toner Light on but Cartridge has Toner it
Try this....
1: Turn off power and remove toner/drum
2: Tape the little spring loaded lever just inside the printer on the upper left hand side in the *DOWN* position! Do not replace drum yet and...
3: Turn power on to printer and let it cycle. Status/Toner lights will come on as usual.
4: Turn off printer, remove tape from lever, replace drum and turn back on.
Mar 08, 2010 | Brother HL 5250DN Laser Printer
Brother HL-5250DN Laser Printer making noises and not printing
some gears are not in proper position , pull out the paper tray and closed it strongly .
Nov 17, 2009 | Brother HL 5250DN Laser Printer
Power overload with Brother HL-2170W
It might just have been that outlet in the surge protector is bad when you tried to use it, it might have shorted the system out
Aug 23, 2009 | Brother HL-2170W Laser Printer
All lights on solid, not flashing, wont print
Recommendation: See HL-5240/HL-5250DN USER'S GUIDE: Section (4), Control Panel: LEDs, (light emitting diodes) starting on pg. 44.
Apr 14, 2009 | Brother HL 5250DN Laser Printer
Brother HL-5250DN printer on Linux operating system
you have to set it in the printer settings to do that
Mar 05, 2009 | Brother HL 5250DN Laser Printer
HL-5250dn ona Bonjour network will not work with Leopard
Brother is totally fucked up under Leopard, found so far no chance to fix it.  Brother's own printer drivers are 10.4 only -- lame
Feb 24, 2008 | Brother HL 5250DN Laser Printer
Brother HL 5250DN Laser Printer Logo
71 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
