Question about Hoover V1 SteamVac SpinScrub Vacuum
I cant get the brushes to rotate and i cant get the vacuum to **** up water i tried changing outlets and cleaning the screen but nothing is working
  • 126 Answers
SOURCE: Brush won't spin when position of handle changes
The belt for this machine is very specific and only one size fits. It is not uncommon for vac shops to sell the wrong belt because the proper belt is not available from normal supply houses, so they will substitute something they think will work.
Also, assuming you do have the right belt, check the tension arm that drops down on the v-belt when the handle is brought back. This arm has a wheel/bearing with a plastic "tire" or trim that rolls on the belt to tighten it. Sometimes, this tire cracks and falls off and then the remaining bearing won't have the necessary tension to tighten up the belt.
Posted on Jan 27, 2008
SOURCE: brush won't rotate when pushed forward
I had the same problem . The reason it acts like that is due to the cable that runs from the vacuum motor to the brush assembly has an intermittent open. My fix was to find the small cable that was causing my troubles and splice it. Making sure that I recovered the insulation. Of course my local repair station wanted to replace it for $75 labor plus parts and keep it for 3 days. I took it home and did it in 30 minutes .
Posted on Dec 12, 2008
  • 294 Answers
SOURCE: carpet setting not working
there is a belt in the nozzle that is driven by a small motor in turn will drive the roller when set to carpet. did you completely dis-assemble the nozzle? ie, to remove the roller and clean the endcaps? this would also show the belt. The gear on the motor wears very easily and could also be worn. I would change the nozzle or get a new Flair. new nozzles cost about $25-$30.
I’m happy to assist further over the phone at https://www.6ya.com/expert/robert_b96ba3f038cf317c
Posted on Jan 17, 2009
sawdust46694
  • 398 Answers
SOURCE: Brushes wont rotate
the belt has streached go to walmart and get a new one.
Posted on Aug 13, 2009
Vac Belts
  • 701 Answers
SOURCE: the brushes will not rotate on my hoover vacuum.
Did you order the correct size of belt? These are the belts you should have:
Hoover Windtunnel Belts
Posted on Nov 08, 2009
Any ideas on why my vacuum cleaner would quit working?
the on off switch perhaps .then the motor itself
May 12, 2015 | Vacuums
How do i fix the brush on my babyliss rotating hot air brush as it has stopped working after two goes..
you need to replace the drive belt look for screws on bottom and access plate left or right.
Jan 21, 2015 | Filter Vacuums
Brush roller not spinning. belt, spindle okay. roller taken out and cleaned, no thread. replaced but no dice. ???
Use only BISSELL Style 10 Replacement Belts (#32074) in your BISSELL PowerForce Bagless.
  1. Unplug cleaner from electrical outlet.
  2. With Rotating Floor Brush removed from vacuum cleaner, grasp old Drive Belt and remove from Motor Pulley. Discard old Drive Belt.
  3. Place new Drive Belt over Motor Pulley and stretch other end over Rotating Floor Brush in the space between the bristles.
  4. Place ends of Rotating Floor Brush down into slots on sides as shown.
  5. Turn Rotating Floor Brush by hand several times in the direction of Motor Pulley. If properly installed, Drive Belt will center itself on Rotating Brush.
  6. Reposition Brush Cover and snap back into place. Check to be sure all three latches are secured.
  7. When you turn on the vacuum, do you see the motor that spins the belt spinning at the bottom? If not, it sounds like you may have a burned out motor.
If suggested solutions do not correct the problem, call:
BISSELL Consumer Services 1-800-237-7691
Monday - Friday 8 a.m. - 10 p.m. ET
Saturday 9 a.m. - 8 p.m. ET
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
Jun 01, 2011 | Bissell 6594 PowerForce Bagless Upright...
Hoover Mach 5 turns off after 5 minutes of using. Can you advise the problem?
5 minutes everytime? If so, raise brush all the way, and vacuum next to nothing. in fact, tilt vac up so the brush touches nothing. wait 5 minutes. If it doesn't shut off, your brush is set too high. if it does, the motor is over heating. make sure bag is empty, no debris in brush, filters clean and make sure you're not plugged into an outlet that a breaker on the outlet can pop too.
Sep 28, 2010 | Hoover U5194-900 Mach5 Multi-Chamber...
The suction is not working. we have tried all the
check RECOVERY TANK LID and DUCT
May be the duct is off the hook
Nov 23, 2009 | Hoover SteamVac F5914-900 SpinScrub...
Brush doesn't rotate
If the brush don't rotate.the first thing you need to do is check to make sure there is nothing jammed in the brush.Like a piece from a carpet,or hair.If it still don't work.then you need to change the belt inside the vacuum itself.
Jul 31, 2009 | Oreck XL Ultra Bagged Upright Vacuum
NO water coming out of Scooba.  It's moving and rotating, but not emitting water.
Here's what worked for me.
Use a drinking straw to blow on the solution valve (next to the battery under the tank). If that doesn't work, try blowing a bit of canned air on the solution outlets on the bottom of the unit (in the trough in front of the brush).
Others have suggested using hot water to clean the solution and dirty tanks.
Jun 27, 2009 | iRobot 5800 Scooba Vacuum
My Hoover steam vac is not spraying the water. Instead it is ejecting 5 streams. This is a new probolem and in the several years I have used it I haven't had this problem before. I can find nothing in the...
There is a filter screen under the plastic cover below the brush indicator. If it is dirty clean it. The solution pump works off of vacuum. If this screen is dirty then the pump does not work correctly. Funny, the manual says nothing about this, only that the plugged screen can affect brush operation. I had the same problem with my solution and as soon as I cleaned the screen ......vola, the solution dispenses great again!
Dec 22, 2008 | Hoover SteamVac F5914-900 SpinScrub...
DOES NOT VACUUM NOW
Several possible problems:
1) Did you clean the blue lower pickup container (dirty water) before putting it away?
Take out the pickup container and open it up, check the filter (under the little blue piece on top) and also open up the container itself and clean under the flapper on the "screen".
2) Look inside the housing and check the vac hose that goes from the front of the unit up to the rubber grommet where it goes into the lower pickup container. Is it clogged? If yes, take off the front pickup (the part the runs along the floor in front of the rotating brushes) and run a very narrow lint pickup brush (like for cleaning dryer vents) and clean out the hose. It works great.
3) Check the front pickup for clogs and clean
4) If you are trying to pick up water, make sure the setting is set to wet. If you are trying to use it as a vacuum, set it to dry.
Hope this helps.
Nov 09, 2008 | Hoover Floormate H3000 Upright Wet/Dry...
Hoover V1 SteamVac SpinScrub Vacuum Logo
90 people viewed this question
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
