Question about Canon Office Equipment & Supplies
There are 27 "buttons" on th operation panel of my
    Guru:
  • 352 Answers
Part of the print head appeard to be blockes. The internal cleaning process is sometimes not strong enough to clean this.
Try this, Remove the Cartridges, The box that the cartridges sit in the printer has a green or orange lever on the right hand side, pull this leaver and the print head will come out.
Follow the instructions in the link below, it will tell you how to clean the print head more thoroughly.
http://www.fixya.com/support/r3986425-unblock_print_heads
Replace the Print Head and The cartridges when your finished, print approx 2-5 sheets and it should be fine.
If you find this information useful please rate my response, Thank you for supporting the FixYa Community
Regards GM
Posted on Apr 07, 2011
Panasonic TH50PE8U
Panasonic Product Support - TH-50PX80U
shop.panasonic.com > Get Support
PanasonicOwner's Manuals. Owner's Manuals and Documentation. Operating Instructions Manual- TH-50PX80. Warranty. Warranty information. Warranty - TV Plasma ...
Panasonic TH-50PE8U Flat Panel Television User Manual
tv.manualsonline.com > ... > Panasonic Flat Panel Television
... and free pdf instructions. Find the user manual you need for your TV and more at ManualsOnline. ... Panasonic TH-50PE8U Flat Panel Television User Manual ...
Oct 29, 2015 | Panasonic Televison & Video
Tip
How to Block a Phone Number With AT&T
<a><img src="block-phone-number-at_t-200X200.jpg" /></a> Call blocking is an easy way to deflect unwanted calls. <span></span> jQuery(document).ready(function(){ jQuery('.intro .thumbnail a:first').attr('href','http://i.ehow.com/images/a04/th/aq/block-phone-number-at_t-800X800.jpg'); }); <p>If you're an AT&T customer and you're tired of receiving calls from companies that try to sell you things you don't want or from people who simply pester you over the phone, the solution is simple. AT&T has a call-blocking service that you can activate in a few simple steps so you won't have to ignore the phone or hang up on people.<br /> jQuery('.intro .thumbnail').each(function(i,e){ jQuery(e).find('img').one('error',function(){ jQuery(e).remove(); }); }); <span>Difficulty:</span> Easy <span>Instructions</span> <ol> <li> Dial "*60" and listen to the voice instructions.<br /> </li> <li> Press "3" to turn your call-blocking service on.<br /> </li> <li> Press the "#" button.<br /> </li> <li> Dial the telephone number that you want to block.<br /> </li> <li> Press the "#" button again to block the number<br /></li></ol>
on Jan 12, 2011 | AT&T Blackberry Curve 8300 Smartphone
I have a Kenwood TH-78A. The nut holding the antenna barrel in place worked its way loose, causing the soldered connection to break. i can't determine where the wire from the barrel needs to be...
I have a schematic diagram of your unit. There are lots of pictures for you to follow on how to re-soldered your device.
Please just click HERE so that you can be in the right page.
I hope you find it very helpful.
Aug 08, 2011 | Kenwood PB-18,...
I'm having trouble installing my canon mp390 all in one printer to my computer, tried installing some software, but still no luck
First uninstall your old driver or the failed installation. Download an updated driver and software for your printer and operating system from this website:
http://www.usa.canon.com/cusa/support/consumer/printers_multifunction/multipass_series/multipass_mp390#DriversAndSoftware
Recommend downloading and following the instructions in the Setup Sheet
You may have tried to do the installation in the wrong order or have an outdated driver for your operating system.
Trust this is helpful.
Dec 29, 2010 | Canon MultiPASS MP390 All-In-One InkJet...
How repair print head for Canon MultiPASS MP390 All-In-One InkJet Printer
Select the "Menu" button on the printer's control panel. Select "Maintenance" on the display screen by using the arrow keys.
Step
Press the "Set" button on the control panel. Select "Nozzle Check" by pressing the number 1.
Step
Press the arrow keys until you highlight your desired level of cleaning. Press the "Set" button to begin the cleaning process.
Step
Wait for the printer to complete the print head cleaning. Print another page and inspect it for signs of poor print quality.
Jul 31, 2010 | Canon MultiPASS MP390 All-In-One InkJet...
Mulitpass mp390
1) Push Fax button
2) Use number buttons to put in telephone number of where you want fax to go to.
3) Lay item to be scanned (faxed) face down on glass and press Start button (Black or Color)
4) Repeat step 3 for each item to be faxed.
5) When ready to send fax (done scanning) press Set button
Nov 26, 2008 | Canon MultiPASS MP390 All-In-One InkJet...
Mp390 waste ink tank...how do I get to the ink tank pads to clean them
to fix this problem you must completelt take the machine apart becuse the resevoir is on the bottom plate. There a 2 sponges that must be cleaned and dried. Also the head cleaning station below the print head assembly must be thoroughly rinsed out. Manually rotating the gear ssembly on the left side of the machine will operate th diastolic pump that drain into the bottom--it must run free and clear. This will take about 2 hours labor total. 1 hour to take it apart--rest over night to dry then 1 - 1 1/2 hours to dry. Print tech87
Mar 23, 2008 | Canon MultiPASS MP390 All-In-One InkJet...
26 people viewed this question
old marine
old marine
