Question about Acer AL2416W 24 in. LCD Television
I have an Acer AL2416W monitor which is playing up. When switched on it gets very bright after around 20sec and develops bright vertical lines. The images is frozen and the whole monitor goes dark (but backlight still on) within a minute. Seems like the t-con board? Has been serviced before with the same problem, but am not keen to put too much money in again. Likely to be the t-con, how much is it and where do I get it?
  • Acer Master
  • 1,606 Answers
The most common failure in LCD monitors is capacitor burnout in the power supply. If that was the issue, and the service tech used the same brand of capacitor or a substitute with an inadequate ripple current rating, the problem would happen again. I have had excellent results using Panasonic FR-series capacitors as replacements, especially if there is space to go to one with the next higher voltage rating (usually also has a higher ripple current rating). The price is not too high if purchased from a general components supplier such as Mouser Electronics or Digi-Key Corporation.
A burned-out capacitor would have a domed top and may show signs of leakage through the safety vent cut into the top. Compare the bad caps marked in red with the good one on the right:
Posted on Jul 25, 2017
  • 128 Answers
SOURCE: acer PD113 DLP Projector
If you can work an the micro level of troubleshooting, have access to the the necessary instrumentation and tools, have the proper surface mount soldering station, test jigs, and also be able to have the access to the factory diagnostics software, and required replacement parts, then I would say you can troubleshoot and service this module. The factory service centers replaces this module. They don't spend the time and cost to service it at the component level. I have serviced some types of projection screen systems. They are very complex, and are normally serviced at the modular level. After replacement of some types of modules, some factory adjustments are required to match the new module, or parts. In the end you will have to send the unit out for factory service.
Posted on Feb 02, 2006
  • 5 Answers
SOURCE: Acer AL2416W 24" Monitor switches off and on after a few minutes
it must be your videocard. Also use a DVI cable, don't use VGA.
Posted on Jan 29, 2009
  • 86 Answers
SOURCE: al2416w acer monitor comes on says acer then goes black
dose the standby button go orange, if it dose then the screen is going back in to standy, its possible that your graphics card is having problems, maybe if you put some more informationt about what happens then you could get better help.
Posted on Aug 11, 2009
SOURCE: my acer AL2416w monitor turns on to a black screen
I have 2 Acer AL2416W monitors that i have been using for 2 years. There has been a handful of times i would turn my computer on in the morning and the screen would be black and Acer would lightly flash on the monitor 1 time. Typically a restart would take care of the problem. Last week the monitor blacked out and i can't get it to work. Any suggestions?? I switched ports on the computer to verify it wasn't the video card and tried new DVI cables to verify it wasn't those? Is this fixable??
Posted on Dec 14, 2009
Sprint_6
  • 16 Answers
SOURCE: I have an Acer AL1912 that when you plug in the
If it is still in warranty call the manufacturer.
if not give more info elah4@zoominternet.net. May be somthing simple like a cable
shutdown computer unplug then disconnect the video cable on the computer from the monitor, plug monitor back in and turn it on, there should be a display that says no video source within a few seconds, if unit is working properly. shutdown and connect video again and then reboot computer. sometimes it just takes a compleat power disconect to reset things,
Posted on Jan 30, 2010
My crt acer ac512 monitar only centre line view,c"not full view why?
there are several reasons why picture of crt monitors did not display good picture. if your monitor had horizontal line at the center of the screen?...the faulty is in the vertical deflection, check the vertical oscillator also the fusible resistors & capacitors around that section. if there had vertical line at the center of the screen?..check the horizontal deflection, horizontal output transistor also check the YOKE.
Jul 31, 2014 | Acer Computers & Internet
Colored vertical lines on my monitor
Depending on the age of the monitor, it most likely will be Capacitors that are leaking. I have repaired many different brands of monitors and have seen problems very similar to yours. 99% of the repairs I do are capacitor Issues. It's well worth replacing them IF the screen is still in very good shape as far as brightness and contrast. most repair kits usually cost between 12 and 20 dollars.
Hope this helps!
Dec 08, 2013 | Acer Computers & Internet
My Acer AL2416W is showing a tint of pink in all images I try to display, I have changed the cables with no change. I have taken the monitor to a new computer and it works fine ( no pink at all ). Why is...
The problem is in your old computer, the video graphics card is faulty, you mentioned the monitor was hooked up to the new computer and worked fine.
Apr 17, 2012 | Acer AL2416W Monitor
Horizontal and vertical lines on ACER laptop
Hi there some how your laptop screen pressed & the screen is damaged. Just the option is replacing the screen. Another reason is over heating of screen by manufacturing default. Your laptop still under warranty so i suggest you visit the Acer service center & claim the damaged things if your screen does not have any over pressed symptom then. I hope you understand me. Thanks & waiting for your feedback.
Apr 02, 2010 | Compaq Presario M2000 Notebook
My acer monitor al2416w comes on then goes off after only a couple of seconds. I have been told its to do with the power inverter!
It most likely is. This is not a difficult repair and you can get an inverter for $10 - $20 off Ebay.
Jan 13, 2010 | Acer AL2416W Monitor
Monitor receiving signal, but no image
Hello!
I see many monitor with that trouble.
When you turn on comp., you can have a picture on monitor about 10-30 min. and that go in black screen, or If you change resolution again go in black screen.
You must repair monitor or bay another.
Nov 02, 2009 | Acer AL2416W Monitor
My acer AL2416w monitor turns on to a black screen
Sep 06, 2009 | AcerView 77E 17" CRT Monitor
LG-PHILIPS 15'' LCD MONITOR WITH BRIGHT STRIPES
Your screen is dieing your need to replace the screen the lamp are not working your screen has been damaged or they died they died ether way. I do refirsbeched LCD montiors and laptop screens.i've seen this before i have three line on my dell 17 i'm waiting for a laptop to come that got a good screen for mine. ou go on line and buy a screen for it shop around you know the drill.
please that me if I helped
Mar 21, 2009 | LG.Philips LCD LP150X05A2 Monitor
Al2416w acer monitor comes on says acer then goes black
Mar 17, 2009 | Acer Al2416WD LCD Monitor
open the monitor observe smps capacitor in primary filter may leackage if faulty replace it
Jan 17, 2009 | Acer Al2416WD LCD Monitor
Acer AL2416W 24 in. LCD Television Logo
85 people viewed this question
Top Acer Televison & Video Experts
Rommel Balcita
Martin Murray
Jaime Hernandez
Are you an Acer Televison and Video Expert? Answer questions, earn points and help others
